2 wire cyl head temp sensor ?
i know the single wire sensor's will eventually fail but what is the life expectancy of the 2wire replacement? Anyone have one fail? tia.
Old 08-20-2007, 10:03 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Unknown, If you live in Garden Grove Cali, you need to be cautious of extremely hot weather. I read that CHTS will burn out the older single wired ones.
With the new CHTS you should go many years without replacing it unless you ride in extremely hot temeratures consistantly. Be aware of symptoms after the hot weather drives.
'85 Carrera Targa
PCA/POC
Old 10-01-2007, 06:41 PM
Large Registered Member
PatrickB's Avatar
I sure hope the new 2 wire sensors are better...
My OEM single wire sensor only lasted 18 years and 120k miles... Unacceptable!!
'85 Carrera Coupe, Marble Grey #118 JP/R6
'93 Lexus SC400, '00 Ford F-150
'70 911T- 2.7 (SOLD)
Old 10-01-2007, 07:44 PM
Still got the original sensor on mine. Seems to work fine...it reads a tempurature, anyways...
But I do need to change it...
'85 911. White - 53,000 miles bought 3-16-07. "Casper"
'88 924S. Blue - 120k miles bought with 105k miles.
'94 968 Coupe - White - 108,000 miles bought 9-28-17
'09 Cayman - Grey - bought 9-8-20
Old 10-01-2007, 11:19 PM
slodave's Avatar
Are the temps abnormally high? I replaced mine and the temps are the same. 226,0++ at the time and the oem was still good.
Dave
Old 10-01-2007, 11:23 PM
Dave
Not at all. In fact, it rarely goes above the first line on the meter unless I sit in traffic awhile. NEVER more than halfway. Even on a 1000 mile, 90+ degree run over the Summer, it was running nice and cool According to the meter.
Old 10-01-2007, 11:48 PM
slodave's Avatar
Unless you really want to spend money, keep driving. If you have reason for a partial or complete engine drop, then, I'd replace the CHT sensor.
Dave
Old 10-01-2007, 11:57 PM
