dshepp806's Avatar
Are there differences between these driers?
Greetings to all.
Are there differences between the Hansa and Kuehl driers? (other than price..) I've an '89 Coupe and wish to install a fresh drier for upcoming AC work.
Thanks!!
Best,
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 08-22-2007, 03:31 PM
dshepp806's Avatar
Bump?
Middle Georgia
Old 08-29-2007, 01:34 PM
Scott R's Avatar
Not sure, but a little advice I got a new dryer at Advanced Auto Parts for $9. This is on an SC mind you...
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-29-2007, 01:41 PM
Detached Member
Hugh R's Avatar
I think a drier is a drier. Just make sure its for R-12 or R-134a, and the it screws in with the right threads.
Hugh
Old 08-29-2007, 02:51 PM
rnln's Avatar
$9? Did you miss a zero (0)? I replaced mine with Kuehl cost almost $100. Good thing is it works.
Fat butt 911, 1987
Old 08-30-2007, 10:07 AM
Scott R's Avatar
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=VST&MfrPartNumber=540030&PartType=397&PTSet=A
$14 online, was $9 in the store, I get 43 to 45 deg vent temps. System is stock, I rebuilt the compressor last year and replaced the shunt valves, but other than that it's original.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-30-2007, 10:28 AM
The drier is just silica gel pellets.... dry sand and its function is to absorb moisture from inside the sealed system (to keep ice from plugging up the lines). So $9 is reasonable for replacing the silica gel. You can probably just remove the solids and replenish with new silica gel from supply store.
Old 08-30-2007, 10:36 AM
rnln's Avatar
... and I got closed to 70 on 90+F day. The best I ever gotten was 55 on 80+F day. The average I normally get is around 20F to 25F below the exterior temperature
Fat butt 911, 1987
Old 08-30-2007, 11:44 AM
dshepp806's Avatar
Being a devoted customer to our sponsor..I see price differences on great orders between Kuhl and others,
I'll be using R12 for sure.
The one for R134A is 69.00 vs. the other at 152.00
therein the question...looks like R12 driers are more expensive? I s this the difference?
$9.00 drier? what?
Best,..and thanks
Middle Georgia
Old 08-30-2007, 03:29 PM
Scott R's Avatar
Originally Posted by dshepp806 View Post
$9.00 drier? what?
Best,..and thanks
Yea, or $14 at the link I supplied, they are nothing special and almost on the level of "consumable" given that the are normally replaced when the system is opened. I think the Kuhl allows for more system capacity, but not sure.
I also run R12, and I keep my condensers clean, and my system well maintained. My engine tends to run on the cool side after the rebuild and that's helped greatly. I may switch compressors next year just to get over the York engine lag issue. But that's no big deal when you own recovery equipment like I do.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-30-2007, 04:01 PM
dshepp806's Avatar
Think I'll digest some specs this evening on these dryers. I want to evacuate on this run and completely recharge, fully intending providing a fresh dryer. $9.00-14.00 is a far cry from $150.00. I'm out to note the differences,...as an engineer (moreso electronic) I would guess this rests with, either, specs,..or (simply) brandname.....you know the drill...
time for homework, I guess. Those who "know", please chime in.......for the record,..$150.00 is not a problem,
My best,
Middle Georgia
Old 08-30-2007, 04:30 PM
scottb's Avatar
Doyle: Give Charlie Griffiths a call. He's a straight-shooter and he'll explain to you why his product is more expensive. At that point, you can decide whether to buy from him or go elsewhere. I can tell you, though, that with Griffiths you know the product will be top-notch and fit correctly. You'll also have one of the country's most knowledgeable 911 a/c guys standing behind it. There's value to that....but you'll have to determine if it's worth the additional expense.
1984 Targa
Old 08-30-2007, 04:41 PM
