Lug Nut life span? Torque it twice and replace?
I was just told be a guy who seems to know a lot about pcars that you should only torque your lugs nuts twice in it's life span. After that you need to replace them with new ones. (assuming that you are using aluminum ones) Has anyone heard this before? This is really news to me.
Old 09-01-2007, 10:10 PM
slodave's Avatar
If that's the case, my wheels should have fallen off a long time ago.
Old 09-01-2007, 10:43 PM
Danny_Ocean's Avatar
Was he a lug-nut salesman (or a PCA member)?
Utter nonsense.
Old 09-01-2007, 11:35 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
I've heard the same about head studs, although in that case it seems to make a bit more sense due to your bringing the metal closer to the limit of permanent plastic deformation - not to mention they're in a much harsher environment from the point of view of temperatures.
I've never seen a lug nut fail - not even the aluminum ones - on Porsches. And I've torqued/untorqued my wheels many times.
That said, I'm open to the possibility that there might be some validity to this - does your friend have any numbers related to the metal strength, limits of deformation, etc. that would back up this recommendation?
Black Cars Matter
Old 09-01-2007, 11:46 PM
IMHO, his anal-retentiveness is showing.
Sherwood
Old 09-02-2007, 11:00 AM
abit off center
cgarr's Avatar
Give him my address and have him send me all his old ones, I will pay the shipping..
______________________
Craig
G2Performance
Old 09-02-2007, 11:17 AM
911quest's Avatar
Sherwood
I like that!!
Tony Proasi
1969S
1957 VW Pickup
Old 09-02-2007, 12:05 PM
AutoBahned
RWebb's Avatar
Eventually, they will get distorted -- more like 2,000 times tho not 2x. The Al seems to just give up after a while -- it is pretty soft. Just see if it snugs down well when hand tight & then don't worry.
Most people replace them due to surface cosmetic issues long before this happens. I think it can happen if you repaint them over & over again and are a real cheap a$$ SOB like me...
Old 09-02-2007, 12:06 PM
khamul02's Avatar
Dude, this may be this case on the paint or anodizing because it sucks. But I believe my lugs are stock and have been repainted many many times. Wheels haven't fallen off but I am do for a reTorque.
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 09-02-2007, 07:44 PM
Zeke's Avatar
And I'll finance the operation.
Old 09-02-2007, 07:54 PM
moneymanager's Avatar
This is just stupid. Lug nuts will go 50 years. Just torque properly.
Old 09-02-2007, 08:16 PM
Mammalian
96740's Avatar
+1
2007 Cayman
Old 09-02-2007, 08:22 PM
Non Compos Mentis
If he is working at a tire shop where they regularly use air ratchets to 250+ ft. lbs. of torque, maybe he's right.
Old 09-02-2007, 08:28 PM
Detached Member
Hugh R's Avatar
Yeah, they're like condoms, you use it once, turn it inside out and only use it one more time.
Hugh
Old 09-02-2007, 08:30 PM
Model Citizen
herr_oberst's Avatar
Maybe he has enough to go around? I only need 16, not 20.
Old 09-02-2007, 09:36 PM
old man neri's Avatar
Yup, also don't forget to replace the gas cap every time you fill up......................
Old 09-02-2007, 09:42 PM
I felt the same way when I first heard it. I just thought I would run it by the forum because crazy stuff does seem to come up here and there. The person I got this from buys and sells Porsche parts for people around the world and he has been right on with a lot of info. I guess you never know. My lugs look old and they have been fine so far. Knock on wood.
Old 09-02-2007, 10:51 PM
DzusFast's Avatar
Maybe I can hire this guy to spam forums, then buy stock in Lugnuts.......yeah.
Favorite car: '73 RSR
Old 09-02-2007, 11:26 PM
Irrationally exuberant
ChrisBennet's Avatar
This is so "out there" that I would suspect there was something lost in the translation or he was thinking something else (axle nuts, etc) when he said it. (I know I do that sometimes.)
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-03-2007, 06:41 AM
