LinkBack Thread Tools Rating: Thread Rating: 6 votes, 4.33 average.
very nice view of warm up ... looks like the afr is only recorded with a resolution of 0.1 afr. not that this is any type of issue just curious.
Old 11-18-2008, 01:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #141 (permalink)
scarceller's Avatar
First, I respect your opinion here.
Take a look at these runs http://911chips.com/dyno.html on Steve's web site and you will find many of the runs have a very flat AFR=13.0 or so for WOT runs across the RPM range. In general the target is in the 12.8 to 13.1 range but I do tend to agree that in certain parts of the RPM range at WOT you may want to go richer. The only way to know what works is to test on a load dyno.
Originally Posted by jpahemi View Post
This has been a very interesting read. One thing I found confusing was the idea that a constant AFR value @ WOT was needed for optimal performance. Once the WOT map is activated (as discussed), essentially the chip's value points (as programed) try to obtain this ratio without system feedback. From what I've learned, the 911 engine functions optimally by having specific AFR values @ different rpm points, so the theory of having a fixed AFR value across the rpm range is counter productive. My manufacturing skills are not up par with Sal's, so I just purchased the LM-1 with the required accessories, and proceeded to plot the stock chip. I managed to plot AFR, WOT switch activation, rpm, and AFM voltage. Now I was able to see the 911's proprietary AFR line. Shorty there after SW was contacted and I bought one of his chips adjusted to the mods my motor. Again I log AFR values, as instructed by SW, and the logs emailed to Steve. Low and behold Steve sends me a chip spot on with a much smoother AFR line, set to the ideal value. One thing to note here is that the AFR line is not flat across the rpm range; between 5000 and redline you see the AFR value deviate. I believe this is done to optimize torque and keep the engine from pinging.
jp
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 11-18-2008, 01:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #142 (permalink)
scarceller's Avatar
Correct! I record .1 resolution for AFR and I can easily record .01 if I wish. I just figured .1 was good enough for my purpose.
Sal
1964 356SC (SOLD)
Old 11-18-2008, 01:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #143 (permalink)
jpahemi's Avatar
Sal,
In your logging, have you noticed a certain AFR pattern in the 5-6.6K (while running the engine in one gear from 2K to redline, WOT) , where the mixture tends to go a point or two richer?
Regards,
jp
Old 11-18-2008, 05:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #144 (permalink)
scarceller's Avatar
Sal,
Regards,
jp
JP,
I tune my AFR at WOT and can make it look anyway I wish but to your question I have noticed and seen other runs that tend to put more fuel into the engine at max torque (5-5.7K) range. In this area right around 5K I have seen folks bring the AFR richer about .2 points. I think this is not a bad idea because more fuel reduces cyl head temps as well as detonation. Keep in mind that max torque is the most stress on the engine.
In my car right now I run about 13.0 on cold low humidity days and tend to run in the 12.8 range for hot humid days. The motronic has this built into the system via the Air Temp Sensor on the AFM, by default the maps for this sensor tend to richen the fuel with hotter air temps. This is why you MUST take into acount the air temp and humidity on the day of the tune.
With that said I have toyed with AFRs that tend to richen in the 5-6K range or simply above 5K but I have not had any dyno time yet so I'm not sure if this makes any diffrence?
Sal
1964 356SC (SOLD)
Old 11-18-2008, 05:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #145 (permalink)
jpahemi's Avatar
Sal,
My first chip had a slight dip (rich) in the 5-6K range, after submitting AFR logs to SW, I found the tuned chip had a slightly more pronounced dip, which also went a little farther 6.6K rpm. I didn't get a chance to do back to back tests between the two, and I don't think the difference is noticeable by the butt dyno. My final AFR readings are very similar to yours 12.8-13.1. I tried experimenting with the DME fuel/timing pot, but didn't find any discernible difference aside from the AFR readings.
I'm very impressed with your logging data, it gives excellent feedback to what is going on within the engine.
It's interesting how you see the temp changes while operating the engine under less than optimal conditions; it confirms that the engine works best in the "sweet spot" of the rpm range. I don't understand how some people operate the engine in 5th under 4K rpm???
Regards,
jp
Old 11-18-2008, 06:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #146 (permalink)
jpahemi's Avatar
Sal,
Do you adjust the DME mixture/ignition pot depending on ambient temps? I know the Motronic adjusts for temp fluctuations during the part throttle maps, but during WOT, the mixture is set by the chip's burn. It would seem that ambient temps would have an affect on the AFR in WOT mode.
Regards,
jp
Old 12-01-2008, 09:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #147 (permalink)
scarceller's Avatar
Sal,
Regards,
jp
I never move the fuel quality switch on the DME, I leave it set in Pos 0. I have toyed with this switch in the past with no real good results.
Then, the AirFlowMeter has a built in Intake Air Temp Sensor this helps the DME calculate/adjust fuel based on intake temps. This must be done because the Barn Door AFM is NOT a MassAirFlow sensor it is only a simple air flow sensor and does not measure mass of the air (density) so air mass must be calculate from air flow and air temp. There are maps in the chip that use intake air temp and adjust fuel based on the combination of air flow measured by the barn door and air temp measured by the sensor. Simply cold air is more dense than hot air so this means cold air requires more fuel to achive target AFR than hot air needs. Simply as air gets colder fuel needs to go up. The required fuel difrence is not much but does need to be adjusted. If this adjustment where not done and the car was tuned at WOT for 13.0AFR on a 90 deg F day then the same car would lean out at WOT on a very cold 20 deg F day, I would suspect it could lean out as much as 13.5AFR which would not be good.
In contrast the new style Hot Wire MAF devices truely measure air mass and don't need to be corrected based on Air Temp. But even with a MAF you often still see a Intake Air Temp Sensor because in general you want to add a little extra fuel on very hot days. For example; at WOT on a 20deg F day a AFR of 13.0 may be a good choice but the same car on a very hot 100 deg F day is also under higher stress and higher CylHeadTemps at WOT and it's just a good idea to add some fuel under these conditions just to be safe I'd bring the AFR to 12.8 under these very hot days.
This idea of brining AFR richer on hot days is already pre-built into the DME maps via a special fuel trim map that richens mixture as air temps get colder based on the IntakeAirTempSensor.
The Bosch engineers really did there homework here.
Sal
1964 356SC (SOLD)
Old 12-02-2008, 08:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #148 (permalink)
jpahemi's Avatar
Sal,
Is the intake temp sensor in the AFM "active" during WOT? I was under the impression that these sensors were bypassed when the TPS clicks the WOT switch??
Is just the O2 sensor ignored during WOT?
Regards,
jp
Old 12-02-2008, 05:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #149 (permalink)
scarceller's Avatar
Sal,
Regards,
jp
There is much mis-undertood info on the WOT mode of these DME boxes. From my personal research I have found that even in WOT mode the AFM signal is used and so is the AirFlowSensor. However, one truth is that the AFM barn door is for the most part fully opened at about 5200RPMs under WOT conditions, you can find some graphs I posted earlier in this thread that show this, this means that after 5200RPM the DME calculates fuel based mostly from RPM.
Then, you are correct that the O2 sensor circuit is completely ignored as it must be because if it where not the closed loop mode would try to bring the AFR back to 14.7 and this is not the case. I know for sure that the AFR at WOT is in the 13.0 range.
Sal
1964 356SC (SOLD)
Old 12-03-2008, 03:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #150 (permalink)
Sal,
just asking... do you think the stock DME outputs 13.0 at WOT all the way up to ~6300?
if yes, then does this somewhat discount the discussions of the AFR dropping to way rich at the higher rpms? E.g. I saw my AFR drop close to being in the 10's at higher rpms..and WOT.
Old 12-03-2008, 03:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #151 (permalink)
scarceller's Avatar
Sal,
I really can't comment much on the stock setup since the car I bought is not stock. But I suspect that maybe the AFR at WOT that came from the factory may not be a pin straight line of 13.0 across the RPM range. I have heard that the stock chip setup does actually run slightly rich in the 12.5 to 12.8 range but I have no way to verify this.
But I can tell you that if you are seeing AFR in the 10s anywhere in the RPM range at WOT you are WAY rich and will never produce max power with AFR in the 10s. The only time I have ever seen AFRs in the 10s in my car is at very Cold initial startup on days where temps are below 50deg F. Something is very wrong with your setup if you are seeing AFRs in the 10s at WOT. You can see plenty of dyno runs with AFR values on Steve Wong's site http://911chips.com/dyno.html you will also note that most of the tuned runs have very straight flat AFRs in the 12.5 to 13.0 range. I suspect your Cyl Head Temp Sensor could be bad and indicating that CHT is much colder than it really is, test the CHT sensor.
Sal
1964 356SC (SOLD)
Old 12-03-2008, 04:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #152 (permalink)
Steve W's Avatar
Stock chip programming on 911 motors are far from optimal at WOT. They are mapped to be lean at low and mid rpms for emissions, and very rich at upper rpms to a)keep the cat cells from melting down on extended WOT runs on the autobahn, and b) for the worst of conditions with low octane fuel to minimize warranty claims. This is especially true with the 3.2s and 993s. As you know Porsche has to warranty emissions systems including the cat for 10 years. The following dyno data is very typical of a stock 3.2 motor showing the AFRs of the stock programming, and the AFR and power gains after AFR optimization and reprogramming for 93 octane fuel.
Old 12-03-2008, 04:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #153 (permalink)
Steve W's Avatar
Old 12-03-2008, 04:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #154 (permalink)
scarceller's Avatar
Steve,
Nice graphs. I would never had thought the stock setup dips close to 11.0 AFR at high RPMs, nice to know.
Thanks for your input here, glad you pitched in on this topic.
Sal
1964 356SC (SOLD)
Old 12-03-2008, 04:56 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #155 (permalink)
scarceller's Avatar
I know the thread is old but here's my entire WBO2 system in action along with my EPROM emulator working hand in hand:
https://www.youtube.com/watch?v=OYgYEoQkjT8
I've been using this setup to live tune for a few years now.
Thought I'd post an update.
Sal
1964 356SC (SOLD)
Old 06-09-2014, 10:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #156 (permalink)
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Sal, that was a nice video. I like where TunerPro shows what area of the table it accesses in real time. It makes tuning a lot easier. It reminds me a little bit of the Megasquirt setup.
Does TunerPro support self-optimization of part-throttle maps? In Megasquirt you can create a part throttle A/F map. Then you drive around and MS will log A/F data as you drive around. After enough driving it will suggest changes to the PT fuel map to meet the target A/F ratio table. With that you can tune to maximize fuel efficiency at lower RPM ranges and then gradually step up to optimum power in the higher load/RPM areas all the way to WOT where all you want is maximum power.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 06-09-2014, 03:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #157 (permalink)
scarceller's Avatar
Ingo
Ingo, the emulator can only do hit trace it can not do any self tuning. But I use the setup often for dyno steady state tuning and it works wonderfully.
Sal
1964 356SC (SOLD)
Old 06-09-2014, 04:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #158 (permalink)
1984 Porsche Carrera
ozracer's Avatar
Nice work sal didnt realise it was so cheap and easy to interface the stock ecu. I have an 84 carrera as well and will look at this shortly seems quite cost effective.
Old 06-10-2014, 06:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #159 (permalink)
scarceller's Avatar
This thread is a few years old and the WideBand I used 2J1 is no longer available but the best unit for the money now is the 3A2, it has a ton of inputs and supports the better LSU 4.9 wideband sensor that needs no free air calibration. The 3A2 also has a native built in true USB port.
http://wbo2.com/3a1/default.htm
Sal
1964 356SC (SOLD)
Old 06-10-2014, 06:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #160 (permalink)
