At the track = great day
(1) evaporator (2) condensers (3) drier (4) compressor (5) hoses (6) a/c temp switch (7) variable speed fan and switch (8) center cooling vent The key thing I found was to run the new hoses as you pull the old hoses out by attaching the new hose to the old hose w/ twine or duct tape. Everything else came out pretty quickly and modifying the evaporator box to install the higher powered fan was not that difficult. I just read through the instructions a few times until I didn't need to look at them anymore, set up a pop-up tent over my car outside and went to work. A few hours later I had finished it all.
Lane 2011 Volkswagen Jetta SportWagen TDI Looking for another sports car.. |
gruppe f
Lane:
I've been thinking of doing that project myself. May I ask which system you installed? I have an '87. Mike
Mike Hinton '06 Cayman S Carmon Red, '05 Cayenne Turbo Black, '87 Carrera Granite Green, '72 911T Aubergine, '74 914 1.8 Marathon Blue, '64 356C Aubergine |
RETIRED
How much did ya spend for parts?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I bought the system from RetroAir/Mr. Jaguar (based in Dallas) and it came with everything needed -- except r134a. It works extremely well when the car had all its sound deadening, carpet, etc. As I've begun to strip everything out of the car, slowly turning it into a race car, its effectiveness is not near what it used to be.
gruppe f
Thanks. I'm currently leaning toward a Griffith's system with R-134a with added condensers, since I have a dark-colored car, and temps regularly exceed 100 degrees here.
Throw it on the ground!
Good Choice. You'll be very happy with Charlie's System!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
gruppe f
Mark:
Do you have that system too? If you're pleased with it, it bodes well for me, as my car is the same color as yours! Not many Granite Green ones around. Mike
Senior Member
My car has the same interior as Mark's and you do not see that very often. Outside was the copper colored version that is not seen often either. Now its silver on the outside and about to be black inside! Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
He makes good stuff. His instructions are top notch.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
gruppe f
Good to hear. Having working AC will increase marital harmony!
Mike, I do have a Griffiths System. Product quality, installation instructions and and after-the-sale technical support is top notch. Love the Granite Green!
gruppe f
I'm going to fill out their questionnaire today. I'll try to post some pictures during the install.
This thread might be a good addition to this list. An AC Evaporator Blower Fan Alternative.
AC Evaporator Blower replacement Idea
Jerry Baer 87 Carrera Coupe |
yogi,
Thanks for the plug. I'm the one that did that, and wrote it. Though of sharing that here as well. anything doesnt make sense to anyone dont hesitate to email or call.
Mike Valley Grande, AL 1987 911 Targa, White |
For some reason I can't edit this post to add this link to the top:
OLD Porsche AC DIY Air Conditioning for Old Porsches (Combined) Large center Dash vents: my dash swap (964 dash in 84 carrera) Update side vents to larger ones: The SC ac vent update to Carrera vents (so far) Parallel Flow Micro-Channel Condensers: I make Parallel Flow Micro-Channel Condensers for 911's front and rear Freaky!
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche Last edited by khamul02; 08-08-2011 at 12:23 PM.. |
Tom is my hero... I'm book marking this one!
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
khamul02,
Thanks! I found the 1st and 3rd links, but didn't see the 2nd one in my search. That's what I want to do. Since I have a full 86 system in good condition I have everything I need for an update of the center vents. The side vents would be nice, but it looks like a mess. Although the trunk lid pull could be moved to the side kick panel I would think without too much trouble. For me the motivator is obviously the heat and the idea of having good air flow in TX heat, but more so the savings on the dash! I have a great dash and they are so expensive. Since I have to pull the dash anyway I might as well update the vents and I already have all the tools. ++ Unfotunately I'm sure I will be doing this in the middle of the summer. Ick...
John- 78 Slick Top 930 "Illegitimi non carborundum" |
