plymouthcolt's Avatar
Please help diagnose my spark plugs
I just changed my spark plugs today (2 years) and found a couple of plugs in not so great condition. I was wondering if I may ask for some help in determing what's going on inside the cylinder?
These are plugs from the left side. #1 on bottom, #2 middle, #3 on top.
Now the right side is where i almost had a heart attack. #4 on bottom, #5 middle, #6 top. Four and five are covered in oil. Possible valve issues?
Finally I noticed plug #1 and it's corresponding wire had some sort of green corrosion on them. Could this be from water somehow entering the chamber during washing or rain splash while driving? I had to crush the plastic in order to remove it from the wire.
Howard
2003 996tt
1997 911 Coupe Artic Silver (sold)
1988 Black 911 Coupe (gone but not forgetten)
Old 09-03-2007, 06:43 PM
Wow, at first I would have said oil fouled, but the plug wire looks to be corroded. I would change plugs, wires and run it. Are you seeing any oil consumption?
Mackskibum aka Dave Austin
'66 911 Work In Progress (#303734)
'85 911 Carrera
06 325XI
'05 Envoy XL SLT
Old 09-03-2007, 06:47 PM
Make Bruins Great Again
Por_sha911's Avatar
4 and 5 have issues. It appears that they are wet with oil on the threads. Could be valve guides (have they ever been done?), could be other things. How many miles on the car? How much oil is it using? How many miles since the plugs were put in? Does it smoke on startup or decel? You may want to do a compression and leak-down test to see wassup (not definative but can help narrow down your possibilities).
Joe
Old 09-03-2007, 09:15 PM
Dave, oil consumption is about a 1/2 quart every 600 miles.
Howard
2003 996tt
Old 09-03-2007, 09:44 PM
Joe the valves are original.
Using about a 1/2 quart every 600 miles.
Going through the records from the previous owner I see the plugs were last changed at 107,049 on Sept 2003. I purchased the car at 111k on Feb 2005. 118k on the car at this time. Way over the two years recommended.
I do get white smoke on startup--never noticed any on decel.
Howard
2003 996tt
Old 09-03-2007, 09:57 PM
Early_S_Man's Avatar
Porsche Crest
Howard,
I don't see any oil on your #4 and #5 plugs ... what I do see is fairly recent carbon fouling that has come loose in a few spots. Defective spark plug cables could have caused the fouling I see.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-03-2007, 10:17 PM
Test results of ignition wires
I decided to test my ignition wires to see if they are not providing the necessary current to the plugs. Here are the results:
Spark plug connector ohm test (3k ohm per Bently)
#1 3.07
#2 3.05
#3 2.97
#4 2.78
#5 3.18
#6 2.94
I was actually happy to see #5 which might explain the carbon on that spark plug. As you can see #4 was lowest of them all?
So I reattached the connector to the wire and tested from the contact inside the cap to the end of the spark plug connector. The results:
#1 .99
#2 1.04
#3 .99
#4 .99
#5 1.00
#6 .97
So the results are:
#1 4.06
#2 4.09
#3 3.96
#4 3.77
#5 4.18
#6 3.91
I need to replace a few spark plug connectors, but should I still trying running in the dark to check for arcing or the corona?
Howard
2003 996tt
Old 09-09-2007, 03:22 PM
Howard,
Those resistance values are OK ... the actual value it isn't critical at all. What I was expecting to see were a couple of 'opens' instead of good readings for #4 and #5!
Now, you need to do a 'shake test' on the #4 and #5 connectors. With a good, secure set of alligator clip-leads attached to the Beru spark plug connector ... and with meter set to continuity ... hold the connector out in front of you and shake it up and down with accelleration/decelleration motion at right angles to the body of the connector ...while an assistant attends to the meter!
Warren Hall, Jr.
Old 09-09-2007, 03:43 PM
burgermeister's Avatar
Probably a dumb suggestion, but are all the plugs the same number/heat range? Just something easy to look at - sometimes auto parts stores are less than careful when dispensing plugs..
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 09-09-2007, 04:45 PM
Warren's right, I would replace those two bad plug wires (and the rest if they are old).
Personally, I would be using Bosch 6's (WR-6DC) instead of those 7's as they look too warm, overall.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-09-2007, 04:54 PM
Double checked all the plugs and they are all WR7DC
I will try the shake test tomorrow.
Howard
2003 996tt
Old 09-09-2007, 05:20 PM
Another thought - check the spark plugs for cracked insulators and continuity as well. 18 years ago I split the case on my freshly rebuilt bug engine to check for cam timing (The thing just wasn't making good power, even for a bug engine). I eventually found a brand new Bosch plug, no overt signs of trouble, that just wouldn't fire, for no apparent reason whatsoever... not likely you have two of those, but cracked insulators are not all that uncommon....
Old 09-09-2007, 05:21 PM
Previous records indicate these are the original wires.
Howard
2003 996tt
Old 09-09-2007, 05:23 PM
member Jesset pic
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-09-2007, 07:44 PM
[QUOTE=Steve@Rennsport;3470143]Warren's right, I would replace those two bad plug wires (and the rest if they are old).
Whoever heard about just replacing two bad plug wires? Don't they come in a set? Where can you buy them individually?
Even if you could find them individually, an aftermarket set might be a better choice as well as more cost effective.
Old 09-10-2007, 10:29 AM
Originally Posted by Early_S_Man View Post
Howard,
I did the shake test on 4 and 5 and the resistance held steady.
I couldn't get any continuity when stable or during the shake.
How can I get resistance but no continuity (Electricity makes my head hurt).
Howard
2003 996tt
Old 09-11-2007, 08:42 PM
throw away the resistor super bosch replace with platinum plus 4s. Replace the wires and use the brackets to hold the wires from contacting the motor that seem to always get lost----my 2 cents whatever thats worth
2006 mini cooper s, w/ all johncooper options( ex wife got it)1984 alfa(Alfa heaven)1964 mini cooper s(awaiting restoration)1984 carrera (still have her)
90 dodge 4 wheel truck, 200,000 miles that 318 keeps going and going( threw a rod putting in a long block)
2006 chrysler 300 srt-8, berrian sand rail twin turbo vortec v6
Old 09-11-2007, 08:52 PM
TibetanT's Avatar
This may seem like a dumb question but, how was the car running prior to the spark plug change? The reason I ask is, it would be nice to know what type of syptoms you were experiencing.
Second, I agree with Steve, plugs are a little on the hot side at least from what I can see in the photo.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 09-11-2007, 10:26 PM
TibetanT's Avatar
Forgot to mention this, but oil consumption sounds pretty reasonable at 1/2 quart every 600 miles, or at least normal for a 911.
Ed Paquette
1983 911SC
1987 944S
Old 09-11-2007, 10:28 PM
Continuity is arbitrarily defined in your VOM as a resistance smaller than [insert some value, probably < 100 Ohms]. Thus, resistance of 3 K Ohms probably won't register as continuity.
At this point, I'd probably run a compression test (while the plugs are out), put in all new wires, new stock plugs, put some Techron in the tank, and run it for a thousand miles. Then I'd have another look at the plugs. Assuming of course the car runs well with the new components installed ...
Old 09-12-2007, 02:52 AM
