Bill Verburg's Avatar
'95 vac res
993.110.140.02
Bill Verburg
Old 09-10-2007, 08:07 AM
AirCooledExcellence's Avatar
Nice one, thanks Bill
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD
1987 930 - SOLD
1983 911 SC Targa - SOLD
http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else
Old 09-10-2007, 08:08 AM
dickster's Avatar
There's no stopping you Tim
Good luck with the install.
Rich
'86 coupe
"there you are"
Old 09-10-2007, 09:20 AM
Hey Rich, where have you been lately?
1987 930 - SOLD
Old 09-10-2007, 02:04 PM
Jon Merck's Avatar
Exactly what I did, the top connection goes to the brake booster if you have one...the throttle cable that fellow pelican DS DW recommends is much better than the Timmins kit one. Here is the link How To Convert Throttle Linkage on 3.6 Transplants?
Jon
Old 09-10-2007, 07:04 PM
Send a message via Yahoo to Larry_Ratcliff
Wow already making good progress. I am jealous. I looked at the Timmons exhaust they have some nice concepts. The 3/4" headers with heater tin welded around to allow for cats or cat bypass. Very nice idea. I wonder if those with cats would pass Ca. smog referee inspection.
Old 09-10-2007, 07:55 PM
You can take the power steering bracket and simply cut out the 3 bolt area that seals the cam. I did that on my install way back in the mid 1990's before Timmins had kits / pieces available.
Also, I found the cruise control cable worked perfectly as a throttle cable with simple modifications to one (bell housing) end.
Never had any issues with these modified pieces.
Tinker
Old 09-10-2007, 10:00 PM
dickster's Avatar
Hello mate,
Taking care of a two year and a four year old! Between them and work not much free time these days
Your car is looking great.
Rich
'86 coupe
"there you are"
Old 09-11-2007, 12:06 PM
Had a nice little delivery from Patrick Motorsport this afternoon:
Looks like nice quality kit!
I've sold my 3.2 so will be dropping that out over the weekend. Once that's done the gearbox is being shipped off for a rebuild (MB Engineering in Cumbria, UK is doing it). Things are moving along nicely
1987 930 - SOLD
Old 09-18-2007, 02:29 PM
Wow! I am going to be following in your footsteps almost to the letter. I pick up my 96 vram on Thursday. I already talked with Jim at Patrick Motorsports about the parts and the right exhaust for california. The PM quality cant be beat ... glad to hear and see your progress.
Old 09-18-2007, 08:33 PM
coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
Nice project. Good luck!!
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 09-19-2007, 09:47 AM
OK, Dropped the engine today, my first time! I followed the Bentley manual and everything went without a hitch. Took about 3 leisurely hours.
Some pics:
The engines off to it's new owner next weekend, destined for a 72 car
Anyway, I'm pleased with todays progress! Another step closer to 3.6 power
1987 930 - SOLD
Old 09-23-2007, 11:08 AM
Good work Tim!
Looking forward to getting a PAX lap in this at a track day next year mate ;-)
Old 09-23-2007, 12:14 PM
jevvy's Avatar
good effort mate - that 3.6 is never gona fit!
'89 3.2/3.6 coupe
Old 09-23-2007, 12:26 PM
MrPerkles's Avatar
Send a message via MSN to MrPerkles
go for it Ace !
www.facebook.com/pages/Bournville-Frameworks
Old 09-23-2007, 01:43 PM
No problem mate
1987 930 - SOLD
Old 09-24-2007, 08:26 AM
Still moving forward with this (albeit slowly!), and have a couple of questions for the 3.6 swap experts!
The wiring harness that I got with the engine has one of the sockets removed leaving me with 3 wires to connect to something!
After some investigation I believe this to be the flywheel sensor connection (the white one is head temp, the green is knock). What I don't know is how to connect this up to the flywheel sensor! The sensor has a plug with 3 connections numbered 1-3, I need to know which colour wire goes where. Looking at the connection to the knock sensor, white=1, brown=2, 3=black
Is it safe to assume the Flywheel sensor is the same? Does anyone know for sure?
One other query, I'm planning on doing the engine tin modifications over the weekend. Does anyone have detailed information on how to do this? Some close-up pics would be great as well
Thanks!
1987 930 - SOLD
Old 10-04-2007, 09:11 AM
See if this helps
Bill Verburg
Old 10-04-2007, 09:30 AM
Originally Posted by Bill Verburg View Post
See if this helps
Thanks Bill. I guess it's called the "engine speed sensor" on the diagram. White = 1, brown = 3, so black must = 2. Don't know why it's called NCA though?
Does anyone know if you can buy the plugs separately from the loom?
1987 930 - SOLD
Old 10-04-2007, 09:42 AM
I think NCA means no color assigned, all the NCA's go to a central chassis ground
Bill Verburg
Old 10-04-2007, 10:06 AM
