-   -   This Autumn's Project - 3.6 Conversion - **Completed** (http://forums.pelicanparts.com/porsche-911-technical-forum/365384-autumns-project-3-6-conversion-completed.html)
hcoles 10-04-2007 08:20 PM
subscribed
skinnerd 10-04-2007 10:25 PM
subscribed as well
there may be a Varioram in my not-so-distant future as well
although i may upgrade to 3.8, cams, etc or the max effect of 330hp
i'll have some very good local help here in Portland as many of these conversions have been done recently
Bill Verburg 10-05-2007 05:26 AM
http://forums.pelicanparts.com/uploa...1191587182.gif
http://forums.pelicanparts.com/uploa...1191587198.gif
AirCooledExcellence 10-05-2007 06:21 AM
More valuable information, thanks Bill! I was just going to ask about the reverse light connection, I don't remember seeing it on the engine loom, guess it must be there somewhere!
The only info I need at the moment is Pictures/plans/templates etc.. for the engine tin modification, anyone? :D
shbop 10-05-2007 07:39 AM
signing up
DJQ911 10-05-2007 08:26 AM
subscribed.
AirCooledExcellence 10-09-2007 08:40 AM
More questions guys.....
Well, one more for now ;) What size belt do I need when running the RS Crank pulley?
hcoles 10-09-2007 08:49 AM
this may be an already asked question.... what is the weight difference if any 3.2 vs. 3.6 or 3.6 variram
Bill Verburg 10-09-2007 08:55 AM
10x785
AirCooledExcellence 10-09-2007 09:05 AM
Bill to the rescue again, cheers!
Gertvr 10-09-2007 02:48 PM
In my future
Subscribed
AirCooledExcellence 10-16-2007 01:32 PM
Any ideas what's supposed to happen with this hose (marked with red dot):
http://www.zen78885.zen.co.uk/ForumP...93Engine14.jpg
I'm about 2 weekends from installing the engine now :D
MrPerkles 10-16-2007 02:22 PM
hurry up and get it off that crate Ace :D
AirCooledExcellence 10-23-2007 11:17 AM
Done some more jobs over the last few days!
Fitted the clutch:
http://www.zen78885.zen.co.uk/ForumP...93Engine34.jpg
Installed the Patrick Motorsport conversion harness:
http://www.zen78885.zen.co.uk/ForumP...93Engine32.jpg
There's just 4 wires to solder, they connect to existing wires that run from up front to under the seat (if you were doing this in a SC or earlier car you have to run wires up to the fusebox area). The wires are permanent live, switched live, tacho and fuel pump.
http://www.zen78885.zen.co.uk/ForumP...93Engine31.jpg
I fabricated some sheet metal plates to cover up the holes left where the power steering pump was located:
http://www.zen78885.zen.co.uk/ForumP...93Engine33.jpg
Then re-united the engine with the gearbox:
http://www.zen78885.zen.co.uk/ForumP...93Engine35.jpg
We are definitely GO for installation on Saturday!
village idiot 10-23-2007 11:34 AM
Good, now that you have all that done crate it up and send it to me:D Threads like this keep me looking to the future. Eventually I'd like to do a 3.6 swap into my 79SC then the leftover 3.0 would go into the 914
johndglynn 10-23-2007 12:00 PM
Ace, did you buy a new baby starter for it or is that one of our hotrod ones?
Also he is neglecting to say that he has just had the trans rebuilt.
AirCooledExcellence 10-23-2007 12:03 PM
It's the same starter mate!
Oh yeah, forgot to mention the tranny rebuild, it's just had all new syncros, bearings and a dog ring :D
AirCooledExcellence 10-29-2007 11:00 AM
Well guys, it's in and it's running :D
Jevvy arrived on Saturday at about 10, we had the engine bolted up by 11, All fuel/oil hoses and electrical connections were made by 12. Then we turned it over without the DME relay to get some oil sloshing around.
First attempt at starting failed, straight away Jevvy knew what it was and the fuel rails were bled (loads of air in there). Next attempt and vroom!! Sounded great (hadn't fixed up the heat exchangers at that point ;)).
Sorted out a few more problems and it's running as sweet as a nut now.
A couple of pics:
http://www.zen78885.zen.co.uk/ForumP...93Engine39.jpg
http://www.zen78885.zen.co.uk/ForumP...93Engine41.jpg
Video:
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/mhbITRHd_oQ&rel=1"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/mhbITRHd_oQ&rel=1" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
I've not had much time to work on it since Saturday, but managed to get the clutch adjusted today. First drive tomorrow hopefully!
village idiot 10-29-2007 11:14 AM
Nice! the only thing more satisfying than the the first time you fire a new engine is the first drive.
Congrats,
Tom
NoEardGoat 10-29-2007 11:51 AM
This is my current project as well. But much further behind. I am very jealous.
