nikita76's Avatar
While you're in there, b4 & after
Hey everybody, went to change a chain tensioner and ended up with this. Thank god my wife understands! Sillicone gaskets, completely rebuilt webers, powdercoated manifolds, cleaned inside walls, plugs, rotor, points,filter, oil,and new motor mounts. As soon as it started up, my clutch cable snapped!!! Don't ask why but, I had a brand new replacement in the basement...took me less than an hour to install! Nikita
1971 Volvo 142 (Fiona)
2004 BMW 525i (Ginger)
1973 BMW 3.0cs Bat Mobile resto (Gilligan)
1974 BMW 3.0cs (Penelope)
2004 Chevy Astro Van (The Skipper)
Old 09-06-2007, 08:39 AM
19 years and 17k posts...
azasadny's Avatar
Beautiful!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 09-06-2007, 08:55 AM
Designer King
Paulporsche's Avatar
Nice!
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Very well done!!! Good thing you were "just doing the tensioners". Couldn't imagine if you had to go in and check the rings!!!
Don
83 SC Widebody Coupe
86 Carrera Coupe
Old 09-06-2007, 08:59 AM
SCWDP911's Avatar
Wow! How long were you "in there"?
Shane
- 1984 928S
Senior Member
Superman's Avatar
New engine shroud? It looks like it would have taken about the same time and effort to replace the crankshaft. Good work.
Mocha 1978 911SC. "Coco"
Old 09-06-2007, 10:13 AM
nikita76's Avatar
Thanks guys! I took my time. One day to take apart, one day to reassemble. Parts were either refinished b4 disassembly or taken from my other motor.
Shroud was refinished as well.
Nikita
Old 09-06-2007, 10:35 AM
