Should I install the bump steer kit?
I am about to have the turbo tie rod kit installed. Should I have the bump steer kit installed at the same time?
Ride height on my car is 25.5 front, 25 rear.
Old 09-06-2007, 02:00 PM
durn for'ner
livi's Avatar
I doubt you need it with that ride hight, but difficult to say for sure.
Markus
Resident Fluffer
Carrera '85
Old 09-06-2007, 02:17 PM
Look at your tie-rod angles.
If they are not level at your current ride height and angle upward from the steering rack to the steering arms, install the rack spacer kit.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-06-2007, 05:33 PM
makotosun's Avatar
If you need it, do it at the same time - you'll be in there anyway.
I put one onto my SC along with the turbo rods and it made an amazing difference in the car. Much nicer to drive now.
SCWDP member #0034
'67 912 Restoration/Mod - SOLD
'80 911SC Targa -
Old 09-06-2007, 05:36 PM
If you need it, you can feel it.
Old 09-07-2007, 09:54 AM
Member w/ Title Problems
Jason Porter's Avatar
I tell most of my customers with your ride height to install BSK. Of course, most of my customers are running an 1/8th inch toe out in front, so it stand to reason that they'll have more need for it.
2023 Ford F-150 Platinum 5.0 Coyote FX4
2019 Toyota Sienna XLE AWD
Metal Building Erector, Recovering Porsche Guy
Old 09-07-2007, 08:35 PM
rnln's Avatar
Jason Porter,
Can you tell me why toe out?
Fat butt 911, 1987
Old 09-07-2007, 09:38 PM
Originally Posted by rnln View Post
Jason Porter,
The toe out is preferred by lots of driers for additional low speed stability and response when cornering. The down side is toe out almost always guarantees instability in the 80-100 range and bump steer. The bump steer kit helps alleviate the bump steer, but not the high speed instability.
For customers going higher speeds, alignment corrections are required.
Old 09-07-2007, 10:04 PM
rnln's Avatar
Jason, thanks.
Fat butt 911, 1987
Old 09-10-2007, 01:12 PM
Senior??? Oh very well
fly4val's Avatar
Went with the BSK and the complete turbo tie rods on my '88
two years ago...wow, what a difference ....couldnt figure out
how the PO could drive it the old way....but then he was a
cheapskate on maintenance....
Had to laugh...he said he had bought an airplane...wait
untl he pays for upkeep on it...yikes!
Old 09-10-2007, 02:01 PM
