| "Kid in a candy shop" |
			Thanks all for the feedback. I looked for Swepco 306 online and found it in a couple of places. The cheapest I found it for was $7.95 per Qt and couldn't find a price by the case. I will check the link provided above. Previous oil change and valve adjustment was done shortly before I purchased this car, at Brewsters automotive. They used Castrol GTX with the Swepco oil improver, I won't use Castrol as I've read it breaks down quicker (around 3000mi). The engine was rebuilt at Aase motors about 7,000mi ago. The notes I read from the shop recommend using Valvoline or Mobil 1. I have also reads that too much ZDDP can be a bad thing so I had better pay attention to how much I add if any to certain oil. My car recently started running hotter than I would like and the oil pressure stays too high (205-215 temp and 100psi oil pressure at 2,800-3,000 rpm) however the oil looks good and the levels are correct. I hoping I'll see more appropriate running temps and pressure after the change. Thanks again to all for the input.
|  05-06-2013, 05:56 AM |
| Functionista Join Date: Jul 2011 Location: CO
			Hmm.. not sure oil difference will change your temp/pressures much.  For reference my 74 is about 50psi at 3K rpm and 195F temp checked last Saturday.
				__________________ Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. | ||
|  05-06-2013, 06:50 AM |
			I read that the Castrol GTX suffers from viscosity break down quicker than other oils in this application (around 3000mi or so). My uneducated guess was that more friction = more heat, the pressure part has me stumped as I would assume pressure would go down with a higher oil temp. FYI the current oil has 2000 mi on it and the color is good but it's over a year old, maybe something about its age or possible moisture from condensation has affected the viscosity hence affecting the pressure. (?????)
|  05-06-2013, 10:21 AM |
| OCPO |
			O yeah, +1 with "Get the best oil you can find." If your oil is over a year old it needs to be changed due to break down and moisture but also acid build up over time running through the engine. Lots pelicans like Brad Penn and the others listed here on page one of this thread. My shop recomends Mobile 1 15w-50 only and BP for all the reasons you have already read about. Mobile 1 15w-50 lists is Zink content at 1200 on there FAQ but I think what they have published lacks credibility due to the API compliance for this grade. The oil pressure issue I am not sure is related to the oil its self but you might start a new thread on the subject to get some good info.
				__________________ 2018 X5 86 911 Targa 3.2 80 Mercedes 450SL 2006 530xi BillyBoat/H&R's....gone Last edited by Storage Man; 05-06-2013 at 11:45 AM.. | ||
|  05-06-2013, 11:32 AM |
			Thanks all. I guess I'll order the Brad Penn or Swepco 306 or Valvoline VR-1. But I'm thinking the Swepco 505 oil improver i have is redundant and possibly harmful to add. I'll have to research more.
|  05-06-2013, 11:45 AM |
| cycling has-been Join Date: Sep 2004 Location: Jersey Shore
				 | Quote:
 YMMV Bill K
				__________________ 73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 05-13-2013 at 03:13 AM.. | ||
|  05-06-2013, 12:22 PM |
| OCPO |
			Great info Bill. thanks! BP is good stuff. Based on my communications with people I am not sure why the one year guide line exists. Selling more oil?!
				__________________ 2018 X5 86 911 Targa 3.2 80 Mercedes 450SL 2006 530xi BillyBoat/H&R's....gone | ||
|  05-06-2013, 12:31 PM |
			Awesome. BP it is. This place is an great resource for info. You guys are smart and dedicated (or sick and addicted ) I'm not sure which LOL. Either way thanks for sharing your experience and knowledge.
|  05-06-2013, 02:10 PM |
| AutoBahned | Quote:
|  05-06-2013, 02:53 PM |
| Senior Advisor |
			and with that, close the thread i think were done
				__________________ 08 Cayenne Turbo | ||
|  05-06-2013, 03:26 PM |
			referenced report: Bill K
				__________________ 73 911T MFI, 76 912E, 77 Turbo Carrera | ||
|  05-07-2013, 03:13 AM |
| Registered Join Date: Apr 2008 Location: Bolivia
			Since I analyze hundreds of oils every year, I'm going to add a comment to that analysis. The results may be within the averages they see, so they don't show them up as alarms, but on a proactive basis I will say that the lead and copper you see is corrosion from the bearings and pins, maybe oil cooler if it has one. I don't pretend to be an expert on the 930 specifically. Copper and Lead are abnormal in levels over 1 or 2 ppm for good engine life. Amounts over that are caused by low viscosity when fuel gets in, or by sitting for long periods with oil not circulating. Yes, there is still TBN left. But when the oil sits for a long period (I too have cars that sit), there are areas where a few molecules of acidic oil are sitting in the bearings, or the turbo or cooler drains and lets air at the brass bearings. Corrosion grows at those points. It is especially accelerated if the engine is started frequently to charge the battery or circulate the oil, but not driven a good 10 to 15 miles to burn off the moisture. I used to do that (or have someone do it). Now I just park it and disconnect the battery, telling my brother-in-law that if he can, once a month drive it the 15 miles to the city and back. Those are highway miles. Also important is (when you can) that when you are going to store it for the winter or something, you change the oil first, let is circulate, and turn store it. Never store with old oil.
				__________________ Taking care of Cars and Industry in Bolivia Richard's Corvair Selection of the Right Motor oil for the Corvair | ||
|  05-07-2013, 07:05 AM |
			Thanks for the feedback Richard. Your insight is always welcome. Bill K
|  05-07-2013, 07:12 AM |
| Registered Join Date: Jun 2008
			FWIW, I just came out of NAPA 20/50, which I found leaked out of the engine seals quite a bit more than the Castrol GTX that preceded it.  I'm now running VR1 and the drips have greatly reduced. An extra bonus along with the zinc...
|  05-07-2013, 02:29 PM |
| Registered | Quote:
				__________________ Patrick Youtube 333pg333 86 modified 951 | ||
|  05-11-2013, 08:51 PM |
| Registered User Join Date: Oct 2010 Location: 100km west of Sydney, Australia
			If you're in Australia, I'd recommend Penrite HPR30, which is appropriate for our cars, and is often on special at very good prices: Penrite Oil - A Better Class Of Oil (Repco is Sydney recently had it on sale at $28 for 5 litres.) In case the fact that it meets the API SM specification scares you, read the following technical bulletin from Penrite, which is a good deal clearer than much of the loudly-expressed opinion in this thread, IMHO: http://www.penriteoil.com.au/images/PENR0138_Penrite_Zinc%20Tech%20Bulletin.pdf
				__________________ 1980 911 SC Metallic Blue Euro spec, 'Greta'; 1986 944 Euro spec Light Bronze Metallic, 'Sabine II' 1986 944 NA Euro spec Guards Red 'Sabine I' - RIP, gone but not forgotten 'Hell is previous owners.' (anon.) | ||
|  11-08-2013, 08:01 PM |
| Registered Join Date: May 2002 Location: Portland, Oregon
			CatsEyes Thanks for the information. You are correct that many of the heavier oils can have enough of the "good stuff" but many of the oils offered have the same additive package regardless of weight. One needs to be diligent to ensure you get a product with shat you need. | ||
|  11-08-2013, 08:19 PM |
			Thanks for posting that Penrite article. It is probably one of the most comprehensive and correct summaries of the real formulation and protection advances.
|  11-09-2013, 02:19 AM |
| Banned Join Date: Sep 2013
			I am sorry if this repeats something I missed form reading this very long thread, but what is the least-expensive, most-easily available oil I can use for several thousand miles without draining it?
|  12-16-2013, 04:18 PM |
| Green Skull 006 Join Date: May 2002 Location: Rhode Island
If you are in the US, Brad Penn is probably your best bet.
				__________________ S Reg 823 R Gruppe 246 1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha" "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field. | ||
|  12-16-2013, 04:31 PM |
