| AutoBahned |
			surely a big burg like Vancouver, BC has some good oils available(?)
|  05-13-2010, 09:35 PM |
| Registered Join Date: Jul 2001 Location: Portland Oregon
				 | Quote:
 I think the hardest thing for many people is understanding that the FLAPS is no longer the best place to find a quality lubricant for their car and the convenience factor may be gone. Its going to get worse in October when the new standard API-SN takes affect. Its just me, but given the financial consequences of a bad choice and what I've seen, I have no issues with mail ordering oil (or anything else for that matter).
				__________________ Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com | ||
|  05-13-2010, 11:46 PM |
| Registered |
			Same here,..budget it (cheap, relatively speaking) and go the mail order route if not conveniently available right down the road.  Doyle
				__________________ Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia | ||
|  05-14-2010, 01:08 PM |
| sancho Join Date: Sep 2008
			I don't know how available it is in the USA, but Penrite HPR15, is 15w60 with semi synthetic formula specially designed for older engines and has a zinc content of 0.110% which is more than enough for a full protection and it is mineral based with semi synthetic formula....... I have been using it for years and my car does not smoke on the startup since i started using it, I don't know if that has got anything to do with it or just a coincidence. we have a climate similar to California.
				__________________ 1980 SC targa blue-SOLD 1986 Carrera wide body white | ||
|  05-15-2010, 05:04 AM |
| Registered Join Date: Feb 2001 Location: Los Angeles & Central Coast CA.
			Subscribed!
				__________________ Thanks, Dave 3 Things To Live By - You can't be Too Rich, Too Thin, or have Too Much Horsepower!   | ||
|  05-23-2010, 09:42 PM |
| Registered Join Date: Apr 2010 Location: Houston, Tx
				 | Quote:
|  06-12-2010, 02:23 PM |
| Registered | Quote:
 If I'm unable to source a good, ready supply them I'm switching back to Mobil 1, which as you rightly said is available at local parts stores.
				__________________ SAM DACOSTA 1990 Porsche 911 Cabriolet (964) 2000 Porsche Boxster (986) 2002 Porsche 911 C4S (996) | ||
|  06-12-2010, 02:29 PM |
| Registered Join Date: May 2002 Location: Portland, Oregon
			Valvoline VR-1 should also be readily available at your FLAPS and Kendall GT appears to be a good alternative as well.
				__________________ Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic | ||
|  06-12-2010, 02:36 PM |
| Pre Registered Join Date: Dec 1999 Location: Out of kindness, I suppose.
				 | Quote:
 Additionally, Mobil 1 V-Twin 20w50 is always available at any local AutoZone or Advance Auto Parts store, among many others. Tim | ||
|  06-12-2010, 08:15 PM |
			I need to find a good oil for my wife's 2003 530i.  It takes 10w-30.  I've switched over to Royal Purple, but i prefer the brands that actually manufacture the oil as opposed to boutiques, i.e. RP, red line& amsoil.  I think i'll try the mobil 1 mxt 10w-40.
|  06-13-2010, 05:15 AM |
| Registered |
			Just about any brand oil will be fine for a 2003. Mobil is good. As is Valvoline VR 1, which comes in 10w30 and is available at autozone.
				__________________ 83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. | ||
|  06-13-2010, 05:33 AM |
Unless you car has some type of special race build, it (like all cars after the mid-90's) has roller tappets which are ok with the newer formulations. Pick a brand you like and  "don't worry, be happy".
|  06-13-2010, 07:08 AM |
| Registered |
Absolutely, and you don't want a high ZDDP oil in that car. "Regular" Mobil 1 10w40 is fine and available everywhere.
				__________________ Gary R. | ||
|  06-13-2010, 07:13 AM |
			Brad, I'm in the Houston area as well (missouri city) and just got my car, an 89 coupe, 2 weeks ago. Do any pelicans and r-listers get together for coffee around here? Need to get the inside scoop on DE and 911 events too.  Alfonso | ||
|  06-13-2010, 07:18 AM |
|  06-13-2010, 07:20 AM |
| Registered |
			Because it will destroy your Cat and those are expensive on that car.
|  06-13-2010, 07:22 AM |
| Registered |
			Yes there are four cars and coffee events every month. You a member of the Lone Star Region of the PCA? The main one is Uptown Square. There is also one at Starbucks at 290/Spring Cypress and one at the Starbucks at the Marketplace by the woodlands mall and one at paradise coffee in clear lake as well. Cheers and welcome!
|  06-13-2010, 07:25 AM |
			I had a 2000 528i with 190,000 miles and have a 1988 635 with 210,000 miles and have been using oils with higher ZDDP content....no issues at emissions testing.  I had been using 20w-50 in the 528, but as stated earlier, wanted to use the recommended grade 5 or 10w-30 oil with higher ZDDP content in the new-t0-us 530.  I figure a cat is much cheaper than engine rebuild.
|  06-13-2010, 07:38 AM |
| Registered |
			SAM DACOSTA says: Quote:
|  06-13-2010, 09:34 AM |
| Max Sluiter | Quote:
 I give you alot of respect for that. It is good to hear someone with mechanical sympathies. Good going on keeping the BMW engine healthy when so much of BMW maintainance is "run it into the ground, then replace" nowadays. However, if the contact pressures in the engine are not extremely high, then the ZDDP will not be degraded as fast and therefore you can get by with less zinc and phosphorous. At a point, more is not necessarily better and it can actually start being worse in extreme concentraions.
				__________________ 1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance | ||
|  06-13-2010, 09:40 AM |
