Someone on the VW boards had posted a UOA on LubroMoly oil synthoil 5w-40.
Look at the Zinc numbers "after" use : ) VWvortex Forums: LubroMoly 5W40 UOA I am not going to steal his UOA but IMO that is an amazing looking oil and can be found at NAPA for like $36 in 5qts jug. What I like is how good this oil did with about 3800 miles on it and in a DFI motor that is known to tear oils apart at about 3k with the fuel dilution. I am currently using this oil in our Cayenne Turbo and may give it a try in my 87 Carrera or their 10w-40. It's a German oil. LUBRO MOLY - Lube Oils, Additives |
Happiest when Tinkering
I know everybody loves the mobil brand and I realize the oil probably comes from them anyway but for their part in the 5 dollar a gallon gas of past I wont knowingly give exxon mobil a penny of mine.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
I'll refresh everyone's memory that is not just the ZDDP content we're looking at, but also the choice of detergents and the ratio of the additives. The lower the detergency, the better the anti-wear additives work.
Also, using Mg or Na based detergents (which cost more) in conjunction with lower levels of the cheaper Ca based detergent also promotes better adhesion of ZDDP films on wear surfaces. The flip side is these oils with lower detergents that provide the best wear characteristics usually cost more AND have to be changed more often. I for one would guess the the M1 Racing 0w30 and 0w50 will be great oils, just like the VTwin 20w50 and 4T Racing 10w40 M1 products.
Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution |
So Charles are you saying you'd be happy for us to use those Mobil oils with such low viscosity (0w-30) in our motors, or that in general terms these oils will be good for non flat tappet motors?
Are you also happy to use an oil with such a large range such as a 0w-50?
Patrick Youtube 333pg333 86 modified 951 |
On the low viscosity oils, I don't think any of the older P engines should use anything less than a 40 weight oil. On the newer water cooled engines, it may be possible to run a 30 weight - I actually plan on testing these as well as the broad spectrum 50 weights of various API ratings to see how they all stack up wear wise.
P-Car
So I bought 11 litres of Castrol GTX Diesel Motor oil 20W 50. In honesty, this thread confused me more than it helped. And I tried my best to make sense of it; however, as a newcomer to Porsche I was heavily discouraged to post topics that have been covered. I hope this is acceptable to post here.
I bought a Bosch Oil filter and this motor oil. Meets the requirements listed on the first page, but the "diesel" aspect has me nervous to pour it in my 911 just now. Any help would be surely appreciated and sorry if I am asking questions covered a million times, but 68 pages on this thread is a bit too much reading. Thank-you -Tom |
Does this help? Quote:
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 05-12-2010 at 07:01 PM.. Reason: Add Steve Weiner note |
woywitka,
A search will always reveal much info but don't ever feel discouraged to ask questions here or anywhere on this board. Yes, the info on this thread can seem overwhelming. Thanks, Harry for the continual updating on the good stuff...
Kurt Last edited by KNS; 05-12-2010 at 06:03 PM.. |
P-Car
Chevron Delo 15W40 Exxon Delvac 15W-40 Shell Rotella 15W-40 SWEPCO 15W-40 It is not an issue of a "more durable" engine, it is more of an issue that for vehicle makers to meet new requirements for lower emissions and better fuel economy, they have needed to compromise the ability of motor oil to control wear on highly srtressed surfaces (cams and flat tappets). The API research is clear on the need.
Swepco is the oil diesel oil on that list I would use. The rest are reformulated products. Swepco 306 is still API SL/CI-4 rated.
Mobil One V-Twin 20W50 and have the best of both worlds.
Gary R. |
cycling has-been
I'm assuming this is a good thing? .....as long as change intervals are 3,000 miles or less? Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
One small note about diesel oils,....
These products are formulated to hold large quantities of soot in suspension for long drain intervals and their chemistries are specific to those operating conditions and demands. Further, diesel engines do not run at 6K RPM so they don't need anti-foam agents. My best advice is to use diesel oils in vehicles powered by those types of IC engines and use a good automotive product in a dry-sump 911. JMHO, of course.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
I have run Mobil 1 and Amsoil in the early 90's, as well as Redline Synthetic after that, with some Valvoline dino oil in between, and every time I ran synthetic oil, I had some oil leakage, not bad, but a few drips overnight. I recently changed to Amsoil V-Twin (after reading this thread), and have had no problems with leakage, so they must have done something to the formulation. BTW, my engine has about 140k on it.
1976 911S Targa, Carrera bodywork, 3.2l engine. |
P-Car
the reason I mention the GTX 20W 50 Diesel is it makes a claim that it meets all manufacturers requirements for Gasoline engines, and foaming at higher revs is not unique to only Porsche gasoline engines. This oil also meets the requirements on the first page. |
I'll stick with Charlie's data and recco's. BP 20W50,..every 3K miles (NO additives needed),..and could give a crap about what this oil's gonna' cost me (shipped to my door from Charlie).
As to concern, this USED to be one of my highest,...now, it's no longer a concern (and hasn't been, for a while now),..so I'm no longer an "overly-concerned-Porsche-owner", as to his oil selection. Removed oil is ALWAYS run for testing,..it's in my "budget"...... Thanks, Charlie, for all of your work and info. Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
AutoBahned
what exactly is the incremental expense from running Brad Penn??
work out the number rel. to a cheaper oil -- then divide by the total cost of an oil change - filter + any labor I don't find it real high... esp. when compared with engine rebuilds - tire replacements - tune ups - and all the cosmetic accessories that I see people using |
P-Car
This is not a question of saving money, this is a question of availability. I want a reasonable oil that is locally available and acessible.
Max Sluiter
You want just the right amount of detergents. Too little (like a full race oil) will allow gunk to build up in a street engine which sees limited use, cold starts, and long change intervals. Too much (like Castrol GTX (it even has "Ca" in the name )) will use up the Zn and P too quickly and will "clean" the ZDDP right off the cam or prevent it from forming proper films.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
