| Max Sluiter |
			Whatever. Castrol doesn't work well FOR ME. It gets very thin and runny quickly. I like the viscosity of the Brad Penn much better. And the fact that it stays nice and clear and green. The Castrol was all black and smelled of fuel. I am not going back. My oil pressure and temperature is better with Brad Penn and it even seemed to leak less. I believe Charles when he said that despite the Zinc and Phosphorous in it, the base stock is not tough enough.
				__________________ 1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance | ||
|  08-28-2010, 09:52 AM |
| Registered Join Date: Feb 2006 Location: Ontario Canada
			I have read some of this with interest .. all i can add is my opinion .. had the top end of my car done at 90,000km .. i run only brad penn 20 /50 in the summer and 15/40 in the spring and fall .. I put in VR1 racing when i run out of b/p . i no whave 225,000kn onmy car and don't even burn a quart between 5,000km oil changes and runs like a dream .. just one data point but a data point none the less..
				__________________ 1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) | ||
|  08-28-2010, 11:36 AM |
| Registered Join Date: May 2002 Location: Portland, Oregon
				 | Quote:
 My head spins too. Folks, I can no longer edit the first post. Some things to consider. As some noted above, it is not just ZDDP but the entire package. As you note, Brad-Penn, Valvoline VR-1, Kendall GT, many motorcycle oils, Shell Rotella, Exxon Delvac, Chevron Delo and the Botique (Redline, Motul etc) oils are all fine. Mobil 1 may be a fine oil as well but due to their sporadic updating of formulations without notification and (in my mind) a failure to present their data in their Product Data Sheets (PDS) makes me wonder whats up. Given this lack of transparency, I prefer to deal with those who would prefer to update their data as things change. Sadly 20W-50 oil is not all the same. If you need to be convinced, take a look at the Valvoline web site and compare their VR-1 20-50 with their "regular" product. The VR-1 has higher levels of ZDDP and a different additive package.
				__________________ Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic | ||
|  08-28-2010, 11:50 AM |
| Registered |
			VR1 20w50    | ||
|  08-28-2010, 04:11 PM |
| Registered Join Date: Aug 2002 Location: Galivants Ferry, SC
			VR1 20W-50 is good.  I've been a fan of the Shell Rotella T 5w-40 synthetic during the SL days and now am not so sure. Updates? Seems they have a few formulas in this range like T6 and something like tri-protection or whatnot. What's that all about?. Would like an update of all the 15W-40 diesel truck oils too ( Delo, Mineral oil Rotella 15W-40, etc). Factoid....during the later 70's when Porsche didn't trust multi-viscosity oils....summer oils recommended were straight 30W. If you buy that today, you will notice none are SM and will likely have good ZDDP at a reasonable price, too.
				__________________ Wil Ferch 85 Carrera ( gone, but not forgotten ) | ||
|  08-29-2010, 04:55 AM |
| Registered User |
I'm new here but I own a small Cessna and I concur. Do NOT use aviation oils for street use. For one thing, av oils are run at very constant rpms. The only time it's stressed is for the take off which lasts about 4-5 minutes at WOT at around 2,750 RPMs. Air temps are always cool except taxiing on the ground. I don't think av oil hold up to 5000 rpms sustained and beyond.
|  08-29-2010, 10:53 PM |
| Registered Join Date: Nov 2001 Location: Santa Cruz, Ca
				Ultimate motor oil
			By far, I think the best oil out there is SWEPCO.  Southwestern Petroleum Corporation - SWEPCO Been using it in racing applications for years. It is all that Jerry Woods/Smart Racing Smart Racing Products - Home of SmartStrings, SmartCamber, and other quality performance auto parts uses in their engines. There are dealers everywhere, and a lot of weights. Jerry Woods is a dealer as well as others. Swepco will ship your first order free. From then on to get free shipping a minimum charge is $500.
				__________________ ___________________ Steve- 62 356 S90 Sunroof-sold 11/16  73 911 No longer Targa-3.2L Running GT4 88 Carrera G50 sold 2019 2015 Cayman GTS | ||
|  08-30-2010, 07:56 AM |
| Registered Join Date: Jul 2000 Location: So. Calif.
			Probably should remind that lubricants for racing, per say, are not necessarily optimized or recommended for normal street driving.  Sherwood | ||
|  08-30-2010, 09:01 AM |
				Ultimate motor oil
			Sherwood While that may be true, SWEPCO is not a 'Racing Oil' only. That can be seen by review of their website. I use SWEPCO exclusively in all of my vehicles, from daily drivers to tow vehicles to antique cars and race cars.
|  08-30-2010, 09:37 AM |
| Registered |
			For those folks who have ordered SWEPCO direct from the company for the first order with free shipping and now need more, identifying the field service rep in your area might help you save shipping cost on reorders.  I recently purchased a case from my area field rep who keeps some local inventory; we met in a shopping center parking lot at an interstate exit convenient to both of our locations. From the web site: To locate the field service representative nearest you, give us a call at 1.800.359.LUBE or email us at the address below. Send mail to lube@swepcousa.com David P.S. No company affliliation; just use the oil.
				__________________ 1997 Carrera 993 coupe - Slate Grey Metallic / Classic Grey 1989 Carrera 3.2L coupe - departed - Stone Grey Metallic / Silk Grey | ||
|  08-30-2010, 04:45 PM |
				Ultimate motor oil
			David Good point. I have a group that uses SWEPCO and I order for them, There are about 7 of us and when we are in need, I place the call. A typical order is in the range of 10 cases. The Swepco rep drops them at my house and when I see the folks they get their oil. We get5-30, 10-30, 15-40, and 20-50 as well as gear oil. The savings are huge. Final cost is about $6/qt
|  08-30-2010, 05:41 PM |
| Make Bruins Great Again |  Something new?
			I'm not changing from Brad Penn but, I recently found Accel Motor Oil  (produced by Warren Performance) at Wal-mart.  It is labeled as SF grade multi-viscosity oil "for cars 1988 and older".  Accel also sells semi-synthetic in lighter weights.  Found this info on it: http://www.wd-wpp.com/specsheet/accel002.pdf No telling what the additive package is like. Thoughts?
				__________________ -------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera | ||
|  09-09-2010, 01:56 PM |
| Registered |
			I'm looking for a fitting oil for my 1980 911 SC (no cat) readily available here in Sweden (which rules out most discussed above). I've read parts of this thread and the LN Engineering article. Right now I have found three possible candidates but would appreciate any comments on each of these. 1. Mineral 20W50. Certification; API SJ/CF, ACEA A2/B2. 2. Semi-synt 10W40. Certification; API SL/SJ/CF, AECA A3/B3/B4, CCMC G5/Pd-2/D4, VW 500.00/505.00, BMW, Porsche. 3. Mineral 10W40. Certification; API SH/CD, AECA A2/B2, CCMC G4, VW 501.00/505.00, MB226.5. From what I've understood each of these should be OK but are there any reasons to choose one before the others? The car is only used during the summer and late spring/early fall.
				__________________ 1980, 911 SC. Ex-US car in Sweden since June 2010. Insta: @911scowner | ||
|  09-19-2010, 02:08 AM |
| Registered Join Date: Apr 2010 Location: Houston, Tx
				 | Quote:
 I don't know enough about the API designations to recommend any of the above. However, you could also e-mail Charles Navaro at LN engineering. He's a very nice guy, and I'm sure he would give you some good feedback. | ||
|  09-19-2010, 02:43 AM |
			The problem also is that common brand names and types don't translate well among the various countries. For example, USA allow highly refined type III mineral based oils to be labeled "fully synthetic"....whereas this wouldn't be allowed in other countries, where only PAO or similar true synthetic oils can be labelled "full synthetic". Because of this.....whatever brand name and type is recommended in one country may NOT follow in another country. Makes these decisions even more difficult..... Later EDIT...changed PAG to PAO in my sentence above
				__________________ Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 09-25-2010 at 12:35 PM.. | ||
|  09-19-2010, 03:58 AM |
				 | Quote:
 You can always have a virgin sample of the oil you are considering, analyzed. Determine if it has the right composition based on the recommendations in this thread. If so, use and then re-analyze. Bottom line is, a good maintenance regimen will include oil analysis. Even if you use a recommended oil, you need to use oil analysis to determine the best oil change frequency. You can then test once a year to get an idea of engine wear. | ||
|  09-19-2010, 05:29 AM |
| Registered |
			I mailed the company selling one of the oils mentioned above. Apperently they are in the process of updating their products so the ones I looked at are not yet available. They did, however, recommended one of their current products.  It is a mineral 15w-40 oil made for diesel engines. It has the following certifications, API CD/CE/CF-4/SG, ACEA E1/E2/A2/B2. They also sent me a list of additives (ppm): Al 2 Fe 3 Cr 0,3 Ag 0 Cu 0 Ni 0,6 Ti 0 Pb 2,2 Sn 0 Mo 1 V 1 Si 11 Mg 496 Zn 1156 P 1219 Ca 1784 Na 2 B 0 K 4 It looks good to me, any comments? Cheers, Björn
|  09-25-2010, 01:14 AM |
| Registered Join Date: Oct 2001 Location: Momence, IL 60954
			Nice balance of Zn/P to detergents, less Ca blended with Mg detergent, and a decent amount of anti-foaming agent (Si). Doesn't appear to have any friction modifiers either. Don't know what to say about the base stock itself though.
				__________________ Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution | ||
|  09-25-2010, 04:27 AM |
				What about Schaeffers?
			Charles: based on your data I've been using Brad Penn 20W50 and am pleased.  I had a slight bump in oil pressure, a slight bump in temp (maybe 10 degrees) and the oil coming out is much thicker than GTX.  Recently, I witnessed a demonstration by a Schaeffer rep using a machine that tests lubricity.  There seems to be significantly more lubrication with their S7000 oil with a ratio of  80% mineral and 20% PAO group 4.  The rep claims that the difference is due to two items in their additive package: moly, and "Penetro" (their own brand of magical mystery additive).  The price is between BP and Mobil 1. So the question is: have you tested their oil? Tech Data: http://www.schaefferoil.com/datapdf/705.pdf
				__________________ -------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera Last edited by Por_sha911; 09-25-2010 at 03:41 PM.. | ||
|  09-25-2010, 08:52 AM |
			Any machine that an oil rep uses to prove their oil is better is just false advertising. You can Google this. One such machine is a Timkin/Falex Bearing Tester. How the operator uses the machine (progression of loading from low to high) can skew results, favoring oils with high levels of EP additives. I have not used any of Schaeffer's oils or tested it. I did test their Micron Moly additive and found it not to have much, if any, Moly. That's the limit of my experience with them.
|  09-25-2010, 10:48 AM |
