LinkBack Thread Tools Rating: Thread Rating: 26 votes, 3.77 average.
Air Medal or two
afterburn 549's Avatar
Pardon my amature engimneering here....But I think most A/C engines have the cam shaft located below the crank in the bath of the oil...(immersed) most the time,,,,they are not dry sump systems..I think the data from this engine used as a "control" is flawed"
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 12-04-2010, 02:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1521 (permalink)
dshepp806's Avatar
Rest assured, ours IS dry sump!
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 12-04-2010, 05:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1522 (permalink)
Some are and some aren't: Continental's are usually below the crank, Lycoming's are above the crank. All horizontal engines are wet sump, radial engines are all dry-sump.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-04-2010, 05:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1523 (permalink)
Air Medal or two
MY point is....if the control engine is wet sump and a cam below the crank, the experiment in words is a wast of time,
A/C engines run modest lift and sloppy tolerances, Would make a Harley engine look good
Old 12-05-2010, 09:56 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1524 (permalink)
As we debate the SM oils and the merits of ZDDP.....let's look at this paragraph from a leading oil journal that publishes in the indiustrial arena,... note the bolded highlights ( by me)--->
"..... The most common anti-wear additives include ZDDP, tricresyl phosphate (TCP) and other phosphorus compounds. These additive materials form stable inorganic films (Zn phosphides, Fe phosphides, etc.) under boundary lubrication conditions. Environmental concerns have put pressure on the lubricant industry to reduce the amount of phosphorous and sulfur in lubricating and hydraulic fluids. One way to address this problem is to take advantage of the synergistic effect between ZDDP and organic molybdenum compounds that reduces the amount of ZDDP a lubricant requires......"
Anyone who is "well-versed" on this topic care to comment that maybe lower ZDDP all by itself may not be so bad afterall if we know more about the "brew" used in the oils we're investigating???
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 12-22-2010, 05:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1525 (permalink)
HarryD's Avatar
Hi Wil:
Good point. I do not think that Moly is a bad thing. In post 623, Charles Navarro said:
Originally Posted by cnavarro View Post
I've been doing more reading into moly based anti-wear/friction modifier additives, and there are quite a few different species, some that provide better wear than others and some that even interfere with the Zn and P. It's a very complicated subject, and delving into areas of proprietary formulation that VOAs can't even begin to answer. We will have to assume that the moly, if used, is optimal for wear reduction even at the tradeoff of not giving the best friction reduction (HP gains). So just because an oil makes more horsepower over another of the same viscosity because of reduced friction, that doesn't necessary translate to better wear. I think that's one of the many hurdles you have to get over when trying to make heads or tails of this whole oil mess.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-22-2010, 06:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1526 (permalink)
Max Sluiter
Flieger's Avatar
So ZDDP gives anti-wear and less friction than Moly, even though Moly keeps the cams protected just as well?
Old 12-22-2010, 10:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1527 (permalink)
Fleiger:
I wouldn't make that great a leap....look at my bolded info above. The oil companies horse around with their brews and I'm sure it's not as simple as all that....otherwise this kind of thread wouldn't have over 1500 entries. My point was to get someone "inside" the industry who reads this...to comment on the basis that reduced ZDDP, that we all are worried about since the advent of the latest oil formualtions.....might not be all that bad once we know the synergistic affects of other elements ( like certain Moly compounds, and maybe not pure moly) that are added. Maybe we're OK.....would like some oil experts to chime-in.
Wil Ferch
Old 12-22-2010, 10:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1528 (permalink)
Kaliv's Avatar
So I'm looking for an oil in my area, and I can't easily get Swepco or Brad Penn. So I'm looking at this site that I got to my way on link from lnengineering, and I'm putting together 20w50 oil with non- CJ-4, SM, or SL ratings.
cOMPANY Search Results
What I find is O'Reilly oil...which isn't really a popular brand name, but I know I can find it...and as a side bonus, it's cheap. Opinions on if this would be a decent oil? Or should I stick with more popular brand names to be a reliable oil? I think also on the list was Shell Performance. I think I might be able to find that.
-= Kaliv Farstryder =-
'87 Porsche 911
Old 01-18-2011, 09:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1529 (permalink)
AutoBahned
RWebb's Avatar
use VR-1 or mail order Brad Penn - $5/qt. free shipping at Amazon, or support Charles by mail ordering from him
or get Swepco from Wayne
everybody needs a few cases of oil in their garage
Old 01-18-2011, 09:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1530 (permalink)
Super Moderator
nize's Avatar
can you provide a link for this price? all of the ones i've found add shipping extra.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 01-18-2011, 10:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1531 (permalink)
AutoBahned
RWebb's Avatar
no link but it's what I did - just get into Amazon & search
but like I said, others have since picked up these oils as mail order offerings: think about helping out Charles who did all the research on this & Wayne who provides this forum, depending on which oil you get - one concours guy on here only uses the Swepco
Old 01-18-2011, 11:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1532 (permalink)
brads911sc's Avatar
GT1 (Kendall) and VR1 Racing (Valvoline)... both tested fine in Charles tests. No need for mail order or shipping.
GT1 can be gotten at Most OReilly and VR1 can be gotten at most Autozone's. $10 cheaper per case and no shipping is a secondary advantage.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 01-18-2011, 01:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1533 (permalink)
brads911sc's Avatar
Not true (today). When you order from Amazon you are ordering from Hoerr Racing Products... the shipping was $6.80 for a single quart of oil. They only had two quarts in stock (20w50).. so that was all you could even attempt to order.
VR1 or GT1 are much more convenient and are listed as good choices by Charles... we have some choices...
Old 01-18-2011, 02:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1534 (permalink)
AutoBahned
RWebb's Avatar
it was true when I ordered it - I just checked the online receipt
no idea what the situation is today as I'm still working thru my oil stockpile
IRC, Shell Rotella T tested out fine -- you can get it all over
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1535 (permalink)
brads911sc's Avatar
Agree. These deals change fast.
You might also call them and ask them for a local supplier. That is also constantly changing. When I first looked for Brad Penn... there was no one in Houston that sold it. Now there is and its only 10 min from my house... They arent selling it for $5 a qt, and I have had alot of good experiences with GT1, but I might have to rethink that now that I am in the middle of a total rebuild... But the point is to call them once in awhile to find out if a distributor was added...
Old 01-18-2011, 02:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1536 (permalink)
AutoBahned
RWebb's Avatar
IIRC, people near PDX can get it from Steve W.
bring your own wine barrel...
Old 01-18-2011, 02:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1537 (permalink)
Bye, Bye.
Scooter's Avatar
I have my local supplier. His price is a little higher than $5 and he doesn't take credit.
Old 01-18-2011, 02:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1538 (permalink)
There are ways to get SWEPCO at a good price. Someone becomes a dealer. You buy for several of your friends. Cases at time. If you buy over $500 worth at a pop, SWEPCO does not charge you shipping. SWEPCO will put you in touch with a distributor.
I am just placing an order for 7 cases at $142 per case. SWEPCO will also send you your first case without charging shipping. After that you pay shipping.
___________________
Steve- 62 356 S90 Sunroof-sold 11/16
73 911 No longer Targa-3.2L Running GT4
88 Carrera G50 sold 2019
2015 Cayman GTS
Old 01-18-2011, 04:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1539 (permalink)
Checked out
McLovin's Avatar
I ordered Brad Penn 20/50 off Amazon a week ago (received very quick), it was exactly $7.00/qt, free shipping.
Old 01-18-2011, 04:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1540 (permalink)
