A good example of this phenomenon is Mobil 1 0w40. It's barely a 40wt. After very little use, it sheers down to a 30wt. Castrol GTX 20w50 in our testing sheered down to a 30wt in just 800 miles. That would suggest the base stock has a low ISO viscosity with LOTS of viscosity improvers (which sheer down). Hope that helps clarify things a little.
Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution |
Unless your ambient air temperatures are very high AND you have very high oil temperatures, I wouldn't recommend running viscosities that high because you'll actually cause more problems that solving. A good example of this is the new LS7 Corvette engines. They call for a 5w30 oil. If you put in a 15w50 (or 20w50), oil temperatures actually jump 20-25F under the same conditions. Unless your engine is built with clearances designed to use very thick oils (60wt, 70wt etc), you shouldn't.
AutoBahned
I tried BP 20/50 after years of M1 use. The BP was definitely more viscous in the pour, and the engine cranked slower and took longer to reach temp. I also had a lot more oil smoke which is why I switched back to M1 (50% 15/50, 50% 20/50 Mcycle).
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
Both temperature and pressure. For lack of a better description, viscosity improvers are little bits of springy plastic that curl up and stretch out, changing the viscosity of the oil. Under sheer or high temperature, they loose their spring. The oil then reverts back to the viscosity of its base stock.
AutoBahned
thx
I always use the Slinky analogy... |
just me
I just took the royal purple plunge with a napa gold filter. I did the change today. This is my first change since the engine was rebuilt and broken in this spring. I was running mobil 1 20w50 and mahle filter. Since the weather is cooler now I went with 15w40.
The only difference I saw was a slightly higher oil pressure. The engine runs great before and after the change. An excellent rebuild by an excellent shop. The oil came out dark and there were minimal shavings on the magnetic plug for the crankcase.
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
Here's an interesting link. What do you think to this?
http://www.blackstone-labs.com/Newsletters/Gas-Diesel/November-1-2010.php
Patrick Youtube 333pg333 86 modified 951 |
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
AV oils use a different additive package to provide anti-wear protection (The anti-wear/anti-scuffing additive- Lycoming stock number LW 16702), and is not visible in UOAs. Another such additive is polyisobutene, which greatly reduces lifter wear. Just because you don't see it, doesn't mean it's not there.
I know the sound factor can be subjective, but the difference between this oil and others in every motor I've put it in is- other synthetics, a stressedout POS, RP= a smooth-reving race machine! Lame, I know... But this is what I've heard, others with me have made similar comments. |
just me
Royal Purple 15w40, sorry for the confusing post. and I am using a napa gold filter.
Charles, thank you for your answer.
Looks like I'll be switching from Castrol 20w-50 Syntec to either V-twin 20w-50 or Motul 300v 15w-50 in my '85 911. Funny thing is, Motul isn't that much more than V-twin. Just not sure how much ZDDP Motul has or even if it's necessary with that formulation. I haven't run into any oil temp issues since putting the big MOCAL up front even after 30 minutes of track session in Florida!!
Under the radar
Any comments on Mobil racing? Advertised as twice the zinc.
Mobil 1 Racing Oils
The new racing oils are likely non-detergent or very close to that, with even higher levels of anti-wear additives. Kind of pricy though.
My (and others) thought can be seen here: Blackstone and ZDDP
Charles, Doesn't the quality of the VI additive add in as a factor? Don
72T Coupe - SOLD :-( |
That's a great question and one for the real experts. I would imagine there just might be a difference, but since there are only several manufacturers of base stock as well as additives (4 come to mind), anything is possible.
1) If you had a product with a base stock combo that was a 60 wt, how could you create a 20W-50? 2) Could you provide additional detail on the 800 mile shear down on the Castrol 20W-50? Test conditions, for instance. Appreciate your knowledge! |
I'm not saying that you could start with a 60wt and have a 20w50 (well technically you can), but that the spec for a 50 wt has a range as does 60 wt, and the high end of one can cross over into the low range of the other.
