| Taking it apart is easy Join Date: Nov 2009 Location: rural Quebec, Canada
			This thread is approaching 100 pages according to my computer.  This is beyond mind-boggling, so I've decided to switch to extra virgin olive oil.  Mainly I like the virgin part and, anyway, the engine will likely last as long on this as it would with some of the witch's brews people toss in there.
				__________________ Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com | ||
|  09-11-2012, 09:51 AM |
| Banned Join Date: Aug 2011 Location: The Wet Side
				 | Quote:
 And where in the heck does one find "virgin", let alone an extra one? Sounds like you'll need the unicorn tears additive. | ||
|  09-11-2012, 10:35 AM |
			No worries.  I bought some of that ZDDP additive, so this should take care of the flat tappets.  Also, it's good on popcorn.
|  09-11-2012, 11:07 AM |
| Registered | Quote:
				__________________ Patrick Youtube 333pg333 86 modified 951 | ||
|  09-11-2012, 11:16 PM |
| Registered | Quote:
 Reminds me of the Religion vs Evolution debate. Synthetic oils have their place for long drain interval modern cars ( not for my modern cars though..) All I know is Give me a Dino oil anyday for an older Porsche, with short Drain and filter intervals........ Works for me and I don't have to woory about major engine failures. Haven't had one yet.   | ||
|  09-12-2012, 12:59 AM |
| Registered User Join Date: Apr 2011 Location: Winnipeg, Canada
			does anyone use Motul Classic 20W50? its a dino oil rated API SF/CC so i assume it has adequate ZDDP. while its still expensive for a dino oil, its about half the price of the Motul 300V. Or is the Motul 6100 15W50 synthetic API SL/CF a better option? All Products — Catalog Products — CLASSIC OIL 20W50 2L | Motul All Products — Catalog Products — 6100 SYNERGIE 15W50 5L | Motul | ||
|  10-08-2012, 06:05 AM |
			oops.
|  10-08-2012, 06:06 AM |
| Registered |
			My 85 911 has had castrol 20/50 for almost it's entire life.  (records)    I switched to Valvoline VR1 on my last oil change.  My car has 143,000 on it now and passed smog last 7 checks and runs great.     Dang,  I hope the motor is not ruined!!!Glory be to the VR-1,  the Deep purple and the holy Brad Penn amen.
|  10-08-2012, 09:47 AM |
| Kind of Blue Join Date: Sep 2010 Location: Delaware
			Is there an appreciable difference between Swepco 15W40 and 20W50 for a 72,000 mile '89 driven in the Mid Atlantic/North East area?  I'm about to order some oil and I can't make a decision between them.
				__________________ 1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor | ||
|  10-22-2012, 04:17 PM |
| Registered | Quote:
 I would be using 20W50 as I am in a warmer and not cold climate   | ||
|  10-22-2012, 05:08 PM |
I have and either fit the temperature profile of my region. I was wondering if one had superior additives for our motors compared to the other or if it doesn't make a difference.
|  10-22-2012, 05:10 PM |
| Registered Join Date: May 2002 Location: Portland, Oregon
				 | Quote:
 As noted by others, you will need to decide what weight is appropriate for your climate and use. FWIW, I always use 20-50W in Portland Oregon.
				__________________ Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic | ||
|  10-22-2012, 05:27 PM |
| Registered Join Date: Mar 2004 Location: Republic of Texas
You shouldn't use additives in your oil.
				__________________ james www.gruppe9autowerks.com Its not how fast you go...its how you go fast | ||
|  10-22-2012, 09:27 PM |
James, I think he was asking about the additives that at included in the oil not additional ones the end user might add.
|  10-22-2012, 10:09 PM |
| Registered Join Date: Oct 2001 Location: Momence, IL 60954
				 | Quote:
 I wouldn't use the 20w50 for cold starts regularly under 32F.
				__________________ Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution | ||
|  10-23-2012, 03:39 AM |
| Registered |
What is the possible negative consequence of using 20w 50 below 32f? ie: damage?
|  10-23-2012, 03:44 AM |
			Yes, damage, as the oil gets too thick to flow properly.
|  10-23-2012, 03:49 AM |
| A fellow Pelacanite |
What's wrong with adding additives ourselves to our oil? Have I missed something?
				__________________ 1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg | ||
|  10-28-2012, 09:53 AM |
| AutoBahned |
			adding your own can upset the balanced package of additives that a group of experienced chemists and engineers designed for the oil
|  10-28-2012, 10:57 AM |
			I agree. What about adding ZDDPlus though? http://www.zddplus.com/
|  10-28-2012, 11:26 AM |
