MBruns for President
AC question - It's getting around that time.
Yes - my car still has AC - yes it still works - that is until the freon escapes from the original hoses. No I'm not going to bag the whole unit to lose weight. It's a cabriolet and I live in Florida.
I sold some old sails on ebay - who would have thought they were worth so much. Anyway - I planned on just replacing the barrier hoses with the rennaire ones - but now I have a little more cash. I'm now thinking of doing the: Rennaire RennAire High Efficiency Serpentine Evaporator $269 Rennaire RennAire Barrier Hose Kit $339 Rennaire Desert Duty front condensor $259 Anybody have the front condensor? it looks like it drops below the bumper a little bit more. I already have a new drier. Thoughts on this? Will it enhance my current system? Should I bag the front condensor and spring for the pro-cooler instead? My goal is to replace all these, then have the whole system recharged at a proper AC shop. Dooable?
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
I would put the condenser & procooler ahead of the evaporator if you're not going to do all of them. I think the lack of condenser area is the weakest link in the system.
The front condenser will be lower than the existing one. On mine it hangs just a shade below that crash bar, where the old one did not. It is almost twice as thick. ![]() The procooler also replaces the reciever/dryer. My system didn't work at all prior to my upgrade so it's hard to compare, but it works fine now & I'm running 134a. Replacing the hoses is tedious & time consuming, not to mention dirty, but it's certainly doable.
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
Thanks Barrpete - did you go with the procooler too?
Barrpete: Is the thicker condenser now at risk of being smashed when the car goes up or down a step driveway, or over a parking stop?
1984 Targa |
Take it to a shop and see where it's leaking. Could be seals.
Find out what's wrong before you start throwing parts and labor at it. The stock system actually works pretty well if it's working per spec. Keep R-12. It cools noticably better than 134a. Do you have a front condenser now? If not, get one. Don't know how much more effective area the renn front condenser has. Make sure the condenser fan in the front of the trunk is working - makes a huge difference. Check that stuff before barrier hoses, procooler and evaporator. |
Throw it on the ground!
I think I've read the thicker desert duty unit comes with spacers to drop the protective cage down and protect the unit from debris. Anyone got a pic of the front with the desert duty condenser installed?
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
JeremyD,
Yes, I have the procooler as well. I went with the Rennaire System II kit plus the Desert Duty front condenser. Scottb, Possibly, but in addition to that crashbar there is a protective cage as well. The condenser is still inside the cage and pretty well protected. I think you'd have to hit it pretty hard to damage it. I don't have a pic but I'll try to get one tonite & post it when I get home.
It has a front cooler, and yes, the fan works, and yes, it has an inline fuse. The other I see as upgrades - regular to serpentine - and the bigger front condenser (which I know is what is lacking in these cars)
abides.
Good luck with the hose replacement. I removed my compressor, condensers, drier, and hoses this weekend, and those hoses are a serious PITA.
Only when I had everything laid out in my driveway did I realize how ridiculous our AC really is.
Graham 1984 Carrera Targa |
Good luck. |
Jeremy you know how friggen hot and humid it is here and for long periods of time. Do it once and do it right, do everything you stated AND the procooler and be done. You will have a system that will last a long time and cool well.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Sorry tcar for the grumpy response - rfuerst911sc - yes - it has been extra hot this year. I don't drive this daily - in fact from mid July - to the end of september maybe once a month to keep the fluids circulating - Kind of the reverse from some of our polar brotherhood.
Looking forward to seeing the "desert duty front cooler" Thanks for the responses - I'm really looking forward to having AC that works again.
OK, here's a couple of pics. Would have done it earlier but Murphy's Law held true & the camera battery was dead when I got home. Two hours of charging & it's all good.
![]() ![]() You can see that it does hang a bit below that crash bar, but probably less than an inch. BTW those scratches on it were by one of the PO's.
It's pretty easy to add spacers to the front condenser guard bar and lower it. Longer bolts plus spacers; may not be quite as strong, but if you're careful.
Yes, if I do the desert duty front cooler - I'll also look at extending the font bar down another inch or so just to be safe. I do have a steep drive.
Spacers would work, I never really thought about moving the bar. That's not a bad idea. On the other hand, I've had it in now for over a year and no problems so far.
thanks barrpete for posting those
so, should I go with the procooler instead of the evaporator?
Jeremy,
I think both are worthwhile improvements, and either one will be an improvement. But my personal opinion is you would get more improvement from the procooler than the evaporator. Basically because it functions as an additional condenser. Another thought would be leave the existing front condenser for now & do the procooler & evaporator. Since you're changing the hoses already you will have to access the evaporator anyway which is a bit of a pain. So if you wait until some other time to change the evap you'll have to tear into that again. And if you wait & do a procooler later you will have to change some of the hoses out which would mean getting at the evaporator again. But replacing the front condenser at a later date would be simple compared to either of the other two. Just a thought.
Do you know how much more effective area the new front condenser has than the stock condenser? If it's, say double, I'd do that before the evaporator. Condenser area is the biggest failing with our systems.
How does the procooler function as a condenser? Not questioning, just don't understand how it does. |
