hillelson1's Avatar
Send a message via AIM to hillelson1
turn signal problems
not sure y my turn signals stoped working. heres the scoop. the 4-ways work still but do not register on the speedo. when i turn my lights on the 4 ways turn on and stay on do not blink. the turn signals do nothing with the lights on or off. all the fuses are good. what should i check?
Love cars lucky i got an early start
1989 911turbo project
1928 rolls royce
Old 09-18-2007, 05:40 AM
Retired Member
Brian 162's Avatar
Check the grounds (brown wire). There may be corrosion. I had the same problem.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 09-18-2007, 06:27 PM
19 years and 17k posts...
azasadny's Avatar
Check the fuses and the turn signal and rear light assemblies. Be sure the wires all have good, clean connections and check the integrity of the bulb assembly.
Art Zasadny
Learning the bass guitar
www.ford.com
Old 09-18-2007, 06:37 PM
hillelson1's Avatar
where is the ground wire located for the turn signals? thanks for the info
1928 rolls royce
Old 09-18-2007, 07:43 PM
Retired Member
Brian 162's Avatar
The rear tail light grounds are behind the lens assembly and attached to the body.
The front signal lights are attached to the brown wire that hooks up to the body by the fuse panel ( in my cars case).
The grounds on my car were corroded on the front signal lights. If you disassemble the lens while in the car you can acess the ground connection.
If I unhooked the front signals the rears worked propoerly with lights on or off.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 09-19-2007, 05:43 PM
