19 years and 17k posts...
azasadny's Avatar
What a difference new spark plug wires make!!
Wow!! I just replaced my 3-year old Jacobs spark plug wires with a nearly-new set of Magnecors that were kindly give to me by Jay Laifman (a fellow Pelican) and I simply cannot believe the difference! Better throttle response, smoother and more powerful acceleration, everything! This is the second best thing I ever did to my car, the best thing was the Webers! I didn't know a set of spark plug wires could make such a difference, but I'm a believer now!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 09-18-2007, 04:46 PM
azasadny's Avatar
The Jacobs wires were fully seated on the plugs and nothing else changed. Could there really be that much difference between plug wires?
Art Zasadny
www.ford.com
Old 09-18-2007, 05:52 PM
Komenda Fan's Avatar
I'm highly skeptical of the performance claims made by some wire manufacturers. You seriously feel there was a difference? Considering that your old ones were only 3 years old, they couldn't have been in that bad of shape, could they?
2012 911 Black Edition Cabriolet
2008 Cayman S Grey on Black - flooded, written off
1977 930 Turbo Carrera Black on Red #411
1987 951 Black on Black - sold to make room for the 930
1972 911 2.7 - I regret selling her every single day....
Old 09-18-2007, 06:21 PM
azasadny's Avatar
Komenda Fan,
I agree with you, I don't believe the hype, but the Jacobs wires didn't appear to be damaged and they were on the plugs correctly. The difference is substantial and quite noticeable! I wish I knew what to attribute the difference to...
Art Zasadny
www.ford.com
Old 09-18-2007, 06:36 PM
azasadny's Avatar
Nobody else noticed a dramatic difference after replacing their spark plug wires?
Art Zasadny
www.ford.com
Old 09-19-2007, 02:15 PM
Did you do anything else to the engine while you were in there? Did you install new plugs, perform a tuneup, anything?
At the end of the day, all the wires do is transmit an electrical current a very short distance to the sparkplugs, I am certainly not questioning your integrity here, I just can't imagine that the wires could make much difference...
Maybe I will have to try a set!
Old 09-19-2007, 02:28 PM
azasadny's Avatar
I didn't change anything else or touch anything at all, just the plug wires. The Jacobs wires looked fine and had about 8000 miles on them. After putting on the Magnecors and going on a very spirited 18 mile "shakedown", I threw out the old wires!
Art Zasadny
www.ford.com
Old 09-19-2007, 02:38 PM
Senior Member
Superman's Avatar
I'm not surprised. Replacing a 30,000 mile-old cap and rotor will have a similar effect. High voltage signals are finicky. On a six cylinder engine, at 3000 rpm, there are 150 firing signals PER SECOND.
Mocha 1978 911SC. "Coco"
Old 09-19-2007, 03:00 PM
azasadny's Avatar
The car starts much easier now, too.
Art Zasadny
www.ford.com
Old 09-19-2007, 04:03 PM
sudo apt-get purge 930
equality72521's Avatar
I didn't notice a difference between my original factory OEM wires and my new Magnecors. In fact, I put my old original factory OEM wires back on since they fit better.
--clutch-monkey
Old 09-19-2007, 06:42 PM
DanielDudley's Avatar
Wires get tired.
Old 09-19-2007, 06:58 PM
Smart quod bastardus
fredmeister's Avatar
Yeah it helps too when you put them on in the right firing sequence, help to have them all firing at the right time.
Wonder if you drove around for 3 years with them all out of whack?
Old 09-25-2007, 04:35 PM
Or maybe one that wasn't completely seated? It is easy to run on 5 cylinders and not be aware of it.
Old 09-25-2007, 06:01 PM
azasadny's Avatar
All of the old wires were on nice and tight and on the correct plugs, so no misfiring was occurring. The car ran fine before, but much stronger and with more acceleration with the Magnecors. It's been a few weeks now and the difference is pretty significant.
Art Zasadny
www.ford.com
Old 09-25-2007, 06:05 PM
Maybe the wires were all wrapped around the throttle linkage, and now they are free.
Did you notice anymore gas pedal travel lately?
Should run strong enuff now to pull a trailer with.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 09-25-2007, 10:16 PM
Thus, Magnecores provide 10 hp more than Jacob wires. Is that the answer?
Or perhaps something was wrong with the Jacob wires and the Magnecores were just doing their job like any other normal spark plug wire.
Sherwood
Old 09-25-2007, 11:34 PM
Autodidactic user
David E. Clark's Avatar
Art,
I made the exact same change (Jacobs for Magnecor) about 18 months ago. The biggest difference I noticed was that the Magnecor wires are better made and fit much better. The Jacobs wires were very difficult to get properly seated and, once seated, were extremely difficult to get off for a tune-up.
I highly recommend the Magnecor wires but I doubt they will give you any noticeable performance gain over other high quality wires if they are properly installed. In fact even Magnecor states that the wires will not give a performance gain. The following is from their website:
Claims of Horsepower Gain
Every brand of spiral conductor ignition wires will perform the function of conducting coil output to the spark plugs, but NONE, despite the claims made in advertisements and other promotional literature, will increase horsepower. Independent tests, including a test performed by Circle Track Magazine (see May, 1996 issue) in the USA, show that NO "low-resistance" ignition wires for which a horsepower increase is claimed do in fact increase horsepower - the test also included comparisons with solid metal and carbon conductor ignition wires.
Magnecor does not claim its Race Wires increase horsepower, and any horsepower gained by the use of Magnecor Race Wires results entirely from the ability of the wires to maintain full conductance and suppress EMI that previously robbed the engine of horsepower.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 09-26-2007, 04:04 AM
It's me, the guy mentioned up on top. I think the answer is pretty clear. There was something wrong with the Jacob's wires. Even so, I'm glad to have caused a positive result.
Old 09-26-2007, 08:15 AM
azasadny's Avatar
Jay,
Thanks again! The car is running great and the Magnecor wires fit better (shorter and less slack) and all is well!!
Art Zasadny
www.ford.com
Old 09-26-2007, 01:43 PM
Nine9six's Avatar
Sherwood
I'm with Serwood on this one...Mishandled new wires can have the carbon broken on the inside, and perform poorly.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 09-26-2007, 05:51 PM
