Norm Faustino's Avatar
cv axle question: search was no help
I have to know because this is bugging the hell out of me
What is the difference between the 4 bolt and six bolt cv axles? I have a 78 sc 3.0 liter with the 4 bolt axles, is this normal for my year and model? I just read where the 4 bolt axles were only on the early cars.
Someone help please I need to know if I should buy 6 bolt axles before I put my motor back in.
78 911 SC "Scratchy"
2004 Mini Cooper S "Pele" (gone but not forgotten)
1979 classic mini clubman-"Coolio"
Old 09-19-2007, 06:51 PM
disband
juanbenae's Avatar
mine is a very early sc, build date of sept 77 and it has six. you got somethin fishy.
Old 09-19-2007, 09:21 PM
disband
juanbenae's Avatar
dweymer's Avatar
ain't that easy! You have to check the trans output flanges first. They are either 6 threaded holes, or 4 threaded and two not. The two not are for the dowel pins. If you only have 4 threaded, no sense changing to a 6 bolt cv right?
Donnie
Currently Porsche-less.....
Old 09-19-2007, 09:27 PM
barney911rs's Avatar
The 4 bolt version is a larger diameter bolt then the 6 bolt. So it's not possible to swap one style for the other. The flange and the CV joint have to match. I have the 4 bolt on my race car. There is nothing harmful in having these.
Check the numbers on the transmission to see if that is correct for your year car. (I don't know how to decode them, but others on this forum can) If it's the correct period transmission, then the flanges were changed for some reason. Could be the transmission was swapped for an earlier model and they swapped the CV's rather then doing the flanges and keeping the newer style CV's. These are just a couple of possible scenarios. If you are not having any issues, I would not worry about it. They will work just as well as the 6 bolt versions.
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 09-19-2007, 10:15 PM
dweymer's Avatar
Thanks John, learn something new daily!!
Donnie
Old 09-20-2007, 06:51 AM
Thanks very much for clearing that up.
Old 09-21-2007, 02:47 PM
