Todd Simpson's Avatar
Do I have a pedal cluster mismatch?
I'm using a '71 cluster with a mag case 915, year unknown.
Will the '71 cluster provide enough throw for the 915?
Old 09-28-2007, 02:44 PM
Huh? For the clutch? They are the same through 86 except for the power brake set up, but even then the cluster is the same.
Old 09-28-2007, 03:34 PM
vash's Avatar
not so sure about that. when the clutch cable changed so did the pedal cluster. helper spring vs. non helper spring 915. basically i dont know exactly what, but there are subtle differences.
poof! gone
Old 09-28-2007, 03:49 PM
Go for it,...you'll have no issues,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-28-2007, 04:13 PM
The position of the arm that the clutch cable attaches to on the pedal cluster changed when they introduced the helper spring in 77 or 78. Trust me, I went through hell trying to figure out the problem when I installed an aluminum 915 in my 76. I ended up having to change the pedal cluster.
Old 09-28-2007, 05:02 PM
