AirCooledExcellence's Avatar
993 Conversion - Engine Tin
Hi Guys,
Has anyone got any detailed pics/plans on the engine tin modifications necessary? The engine's a 1997 Varioram, the car's an '84 Carrera.
I'm also planning on using the engine crossmember from the Carrera, I guess I just remove the alloy aircon bracket from the 3.6 and bolt the 3.2 straight on? BTW I have an RS crank pulley so no clearance issues down there
Thanks,
Tim.
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD
1987 930 - SOLD
1983 911 SC Targa - SOLD
http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else
Old 10-06-2007, 07:44 AM
Bill Verburg's Avatar
Originally Posted by AirCooledExcellence View Post
Hi Guys,
Thanks,
Tim.
No, if you aren't using the ac on the 993 engine you need either the 964RSRS
console or take a hack saw to the 993 AC console, after cutting off the AC pedestal it will look like the RS part.
Some pics of the tin on my '97 engine
Bill Verburg
Old 10-06-2007, 08:08 AM
Hi Bill,
Thanks for that! Any idea why the 3.2 crossmember can't be used, I've heard that it's been done before?
Cheers,
Tim.
1987 930 - SOLD
Old 10-08-2007, 03:00 AM
I am picking up a 1992 964 engine this weekend to transplant into my 1981 911sc. I would love details as well.
Here is the list of parts I would like included w/ the engine:
Throttle cable
Engine wiring harness
All Vacuum hoses
Smog equipment
Alternator (I think is behind the fan stuck to engine)
Flywheel and flywheel sensor for computer
Exhaust, muffler, cat w/ O2 sensor and wiring
Power steering w/ lines
Distributors
Coils
A/C and lines
Engine tin
Air filter hosing, etc.
Fuel Pump, filters and lines (if not too much trouble)
Starter
DME computer and wiring harness to engine and car
Motor mounts
Oil reservoir
Front oil cooler, lines, fan w/ wiring harness
Cruise control module (maybe part of trans?)
Other Desired items:
Front & Rear calipers and rotors
Steering wheel? gray?
oil temp gauge if it has #'s instead of lines
Anything I am missing that I can get off the car for my 911sc? Luckily the seller is being very cooperative.
Old 10-08-2007, 03:31 AM
ted ted is offline
likes to left foot brake.
ted's Avatar
From a 96 3.6 non vr installed in a 69 911.
With Plug wires.
Old 10-08-2007, 04:21 AM
Thanks Ted!
So you used your original crossmember, did you still need the spacers to lower the engine?
Thanks,
Tim.
1987 930 - SOLD
Old 10-08-2007, 04:30 AM
I used the original C3 carrier(several times) w/ a spacer
Bill Verburg
Old 10-08-2007, 06:01 AM
DW SD's Avatar
You can use spacers or make a "bubble in the rear window shelf. I did both 1/2" spacer and a bubble. My car is very low and I didn't want the engine hanging down below the car too much. I had the car on a lift and used a 4x4 with a floor jack to "bubble" the rear window shelf. It is not obvious with the RS carpet kit installed. The bubble is probably 1.5" at the peak and maybe 18" x 10" with a gentle curve.
If you run the single crank pulley (patrick motorsports or other), you can back-date the rear cradle mount and crossmember. (As shown by Ted and Bill).
Doug
1971 RSR - interpretation
Old 10-08-2007, 10:33 AM
If I decide to use the 3.2 engine crossmember does it need to be reinforced? If so, how?
Thanks!
1987 930 - SOLD
Old 10-10-2007, 01:58 AM
DW SD's Avatar
I did not use a reinforced crossmember and am not aware of others' reinforcements. That doesn't mean it is not necessary.
Old 10-10-2007, 07:05 AM
Anyone have any pictures or a description of the crossmember reinforcement?
Old 10-14-2007, 02:40 PM
DW SD's Avatar
I think the reinforcement is used on the 3.6 crossmember, when it is modified to fit the early chassis. Look at Timmons' website. You can find it through this board with the search function. G-force or something .com
Old 10-14-2007, 06:02 PM
Thanks for the posts so far guys! I'm doing the engine tin mods this weekend and would like to see some more examples if possible (especially the front right of the engine around the power steering area).
1987 930 - SOLD
Old 10-18-2007, 02:40 AM
Bill Verburg
Old 10-18-2007, 06:08 AM
