dtw dtw is offline
GAFB
Internal thermostat opens partially - ~2/3 - toss?
Wonder what y'all think about this. I've asked locally and gotten opinions on both sides.
Have been chasing an overheating problem. I know my mixture or ignition is part of it, my CO is like 1.8%. That should be easy enough to solve. However, while covering my bases, I pulled the internal thermostat to check it out. It seems to function properly, it begins to crack around 140 deg F and stops opening at around 185 or 190 deg F. However, it only ever opens about 2/3 of its 'window'. Took it up over 200 and it did not open any more. Is this restricting flow to the cooler and costing me potential cooling capacity?
Several BMWs
Old 10-08-2007, 07:22 PM
Paul Thomas's Avatar
Dave,
I would start with the mixture and go from there, 1.8 is very lean. I try to eliminate every possibility before throwing money at it.
Are you going to RR3?
Paul
My ignition is retarded.
Old 10-09-2007, 08:02 AM
dtw dtw is offline
GAFB
Hi Paul,
Yep, I'm going to RR3. At this time it looks like I will need to work Friday so I'm planning to fly in Friday night. Dustin and Tim should already be down there so I'll ride home with them. I can't wait!
I've got the engine out right now doing some work to it. While out I'm trying to do a few things to maximize cooling, like doing the cooling tin mod and changing pulleys. The Targa does not have a front cooler so I'm trying to maximize cooling at the back of the car. If I am leaving additional cooling on the table by installing a worn-out or malfunctioning thermostat, I want to replace it now while it is easy to get to. This is on the '76 CIS that is a PITA to access in situ, not the '72 MFI car.
Several BMWs
Old 10-09-2007, 08:07 AM
dweymer's Avatar
Dave,
I am cheap when it comes to buying parts; BUT, if you are cutting off 1/3 of the flow through the system, you are also risking not oiling the rod bearings enough right?
Replace it, you are already over budget anyway
Donnie
Currently Porsche-less.....
Old 10-09-2007, 08:25 AM
dtw dtw is offline
GAFB
I don't think there would be any oiling issues, as any oil blocked from entering the cooler would just be bypassed. At $129, I don't want to replace this thing if I don't need to do so.
Several BMWs
Old 10-09-2007, 09:41 AM
304065's Avatar
Thermostats for a modern car like that (not SWB) are cheap, replace it.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-09-2007, 10:46 AM
dshepp806's Avatar
Beg the money from someone and get that POS out of there! 100% or nothing!!
Best!
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 10-09-2007, 12:06 PM
dweymer's Avatar
oh, just ignore me I am sick this week.
Donnie
Old 10-09-2007, 04:29 PM
