Anachronistic Anomaly
Will this heater backdate part work on an SC?
This part number is listed as fitting an 84-89 Carrera. Does anyone know if it will also fit an SC 3.0?
Part number: 930.106.321.02 Here's a link to the part: http://www.pelicanparts.com/cgi-bin/ksearch/pel_search.cgi?please_wait=N&forumid=&threadid=&command=DWsearch&description=930.106.321.02&I1.x=15&I1.y=10&FILTER_911E=ON&FILTER_911M=ON&FILTER_911L=ON&FILTER_996M=ON&FILTER_TECH=ON&FILTER_SUPP=ON&FILTER_ACCE=ON&FILTER_CARE=ON&FILTER_STUF=ON&FILTER_PERF=ON&FILTER_MISC=ON&FILTER_GADG=ON&FILTER_TOOL=ON
IG@ the_derek_whitacre |
would a picture help?
Mocha BAP
For an SC, I'd use this one:
930-106-321-01-PH
Scott 71 911T Coupe 3.0 Looks stock 79 911SC Coupe 3.2ss Nothing stock 02 996 C2 Cab Mostly stock 06 955 CTTS Super P!G |
You still have to get that part modified to fit around the 3.0 distributor.
Looking for a possible way around this.
Mocha BAP
carefull use of a BFH works well.
Senior Member
The part I used is for a Turbo. The indented part is large enough for the SC distributor. Other ones are not.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Intended part? You mean the one I started the thread with? Do you have the part number of the one you used?
I too used the Turbo left side hot air duct also: OEM-93010632102. Just FYI, the part you show above does not appear to be for a Carrera nor is it the Turbo part #...I think that's for an earlier car, maybe an SC.
