I'm in the process of completing a brake upgrade on my '81 SC including caliper rebuild & paint & rotor/pad replacement. Found one of my turbo tie rod ends shot. I was able get it disconnected from the arm, but I can't seem to get enough leverage with a wrench to hold the rod still to unscrew the end.
Does anyone have any suggestions to loosen the end? Any tools that would help? |
there's a recess on the rod where 12mm open wrench snugs... if it is seized, grab the tie rod end side with a channel lock and twist. apply heat if stubborn...
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 2006 Sienna 5dr - the hauler 2004 Lexus GX470 2010 Cannondale Caffeine II - Lefty |
Thanks, I'll give it a try.
