Factory Coil Output
Does anybody have any specifications on the factory coil output? For a 85-89 Carrera, Like in...............
Primary Resistance Secondary Resistance Maximum Voltage Inductance Turns Ratio Peak Currant Spark Duration
85' Carrera 92' Mustang 5.0 02' Focus ZX3 08' FJ Cruiser |
No, but I can tell you that the factory 3.2 DME coil has enough oomph to fire my plugs gapped at 0.060". My guess is 35-40 KV needed to jump that gap.
stlrj
What kind of benefit did you get with .060"? better throttle response, more power, better fuel consumtion, one or all of these? Do you still run them gapped at .060"? or did you play with gap for best performance? Thanks
As to Bentley data for coil resistance specs for primary and secondary windings:
Primary (terminals 1, 15): 0.4 - 0.7 ohms Secondary (terminals 4, 15): 5.0 - 8.7 Kohms (Bentley 280-9) Will have to research the other items... Best,
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
I wouldn't push any significant increase in the plug gap because you will put more stress on the other ignition componets risking failure somewere along the line. Maybe your coil can handle it but your rotor, cap, or wires (including resistors) may not.
Thanks dshepp806, I didn't even think to look in my Bentley manual for at least some of the information, when I find out the rest I'll post the info if anybodys interested.
Bump
I gap all my cars at 0.060" for all the above benefits but I also had to upgrade my ignition components to HEI which came standard on my Grand Caravan, Chrysler Concorde and '86 Olds 98. I also tried a gap of 0.080" but had problems missing above 5k. Cheers, Joe |
