Platinum Member
Electromotive TEC I Programming
I have a 2.7 with Electromotive Tec I (DOS based)...
PO gave me a floppy with a few configuration files on it. Is there any way to tell which is currently loaded? |
Navin Johnson
Tec 1 is quite primitive..... but there are bunches of cars running it and they run well..
Its been years since I played with a Tec 1 , but from what I recall, you cant save the bin file from the Tec, you can modify and reload the bin file (make changes>>key off>> key on>>up load> etc) Is the engine running now? if so how does it run? If its running well I take that floppy and toss it
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Platinum Member
Thanks Tim. I bought the car this spring. It runs well, but I wanted to check the programming.
