				Still down on the dyno numbers :(
			OK, went back to CIS last week, driveability is perfect, hot cold starts are tip top, CO is dialed in perfect and hydrocarbons are low.  So today I went back to the dyno for another set of pulls, and I hit 150 instead of 138, AFR's are in line with other peoples posts.  I'll post the sheets in bit when my camera charges, however I'm disappointed, and I still think something is fundamentally wrong here.
				I'm down to the basics at this point, ignition, which is always suspect, and maybe my exhaust. I'm not concerned with the muffler, it's a brand new MK 2 in 2 out, the SSI's I am though. The SSI's are designed for the 3.2l, and have the sleeves that fit into the heads, didn't think this was an issue, however in reading some other posts maybe I should have ground them off? I really do feel like I have an exhaust restriction, or something. Everything else is so spot on, rock solid idle, smooth power. anyone know?
	2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab  |
			Have you rechecked the timing of your cams and double checked the lift/duration to make sure you have the right ones?
	Steve Sapere aude 1983 3.4L 911SC turbo. Sold  |
			Wow! Is there a correction for altitude or something? your at 10,000 feet or so? There will definatly be a difference compared sea level
	Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com  |
			Scot, what is your ignition timing like?  Can you post a link of what mods you have done to your motor?
	Aaron.   F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/  |
 Mods are as follows: 9:8:2 JE Pistons on new Nikisil bores 964 Camgrinder cams ARP hardware, rod bolts and ect 1980 CIS system all numbers verified 3.2L SSI's M&K Gen 4 2 in 1 out Freshly rebuilt 915 Everything else new, plugs, wires, anything that was removed at time of rebuild, sans the distributor. EDIT: Sorry ignition timing is 5 deg before, per the sticker.
			2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab Last edited by Scott R; 10-27-2007 at 01:21 PM..  |
			Per this Link: http://wahiduddin.net/calc/calc_hp_dp.htm and todays weather, the dyno correction factor for Denver is 1.21
			Therefor your 150 hp is really 181 at sea level, which is equivalent to 207 at the crankshaft Seems like you engine is running great.
	Mike '82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar.  |
			It appears to be corrected for STP already.  Have you checked that you are getting full ignition advance?
			Cheers
	Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3  |
Yes, 33 deg give or take a smidge.
			Looks OK to me, given the late CIS (small runner) airbox and manifolding and considering your location.
			Without question, those SSI's are sometimes a tad small for a 3.2 but your torque and HP curves look real nice for acceleration and "area under the curve". Thats a nice setup for a car living at 5000 ft+ altitude.
	Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com  |
			Scott,
			Your adventure is going to further inspire me to have an engine dyno available here again. Someone ‘borrowed’ my Stuska after I retired in ’86. I want to have another professional engine dyno setup available here. My plan is to have one available to all the shops. I have discussed this with several owners. My goal is to have all the current diagnostic technology available to everyone. My nice old Stuska helped hundreds (perhaps thousands) at Rennenhaus. I want to pass on what I learned. Steve, Jerry, Dieter and many others discuss the use of an actual engine dyno compared to a chassis dyno. When researching an issue such as Scott’s and others, there is no comparison. An engine dyno tells the story and allows immediate adjustments. Best, Grady
	ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50  |
