Wildman Emeritus
Engine Yoke
I have recently purchased an engine yoke & will be doing a drop shortly. Exactly what additional hardware do I need to buy or fabricate to use this device? It looks like the studs will need some sort of spacer set up due to their length or the yoke will not clinch tightly.I have not seen a kit of hardware listed here or anywhere else that sells P201.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
not sure what exactly you are asking but if you need to borrow anything I have a stand and a yoke here
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Work in Progress
I think I have heard of people using some washers and one of those worthless english sockets as a spacer. Others have cut a length of metal tube to fill some of the space in. If I am picturing what you are talking about correctly.
Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
Engine Adapter...
Howdy,
What you need to do is to remove two of the long bell housing bolts from the back of the engine. I was told to use the left side bolts (on the oil cooler side), however the adapter that I bought was more for a VW (it had 4 spokes, not 5) did not have the relieve for the over hang of the oil cooler housing. So I removed the long studs on the right hand side and installed the adapter. To remove the studs I would use some "mouse milk" or equal then run on two old nuts to the stud, lock them down against each other and remove the stud. This works well and won't destroy the stud. The adapter is made so that you can split the engine while on the stand, so the half arc of the adapter is in the vertical position. I can take a pix of my engine on the stand if that would help... See ya,
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
Wildman Emeritus
Mitch;
That would, indeed, help. Thanks
Mike,
I'll get a pix to ya this evening... Is your adapter a 4 or 5 spoke? I bought mine off of e-bay from a guy in California for $90. However it's a 4 spoke and doesn't have the relieve for the oil cooler that the $240 model has. Since I'm not a professional I think the the cheaper one will work for me. See ya,
Wildman Emeritus
5 spoke from our host. I will look for a photo.
Thanks again.
Mike,
I didn't realize that our host carried the adapters... Do you still want a pix of the adapter attached to the engine?
Engine Adapter...
Mike, here's a couple of pixs for attaching the engine adapter. Also a way you can remove the tranny mounting studs.
I hope this helps... ![]()
2nd Pix...
Mike, here's another pix that didn't come through the first time...
Wildman Emeritus
Thanks,Mitch.
Forced Induction Junkie
Hi Mike,
I used sockets (S.A.E., of course ) as spacers for the yoke. Otherwise, you can remove the transmission studs and use shorter studs as mentioned and mildly torque them to the case.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Just to clarify the mounting of the engine adapter I used bolts rather than a shorter stud. Hey, it all works.
X2. First good use for my SAE tools in years.
Old Tee all 911s sold |
