Wildman Emeritus
Engine Yoke
I have recently purchased an engine yoke & will be doing a drop shortly. Exactly what additional hardware do I need to buy or fabricate to use this device? It looks like the studs will need some sort of spacer set up due to their length or the yoke will not clinch tightly.I have not seen a kit of hardware listed here or anywhere else that sells P201.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 10-29-2007, 10:16 AM
not sure what exactly you are asking but if you need to borrow anything I have a stand and a yoke here
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 10-29-2007, 12:48 PM
Work in Progress
Rich76_911s's Avatar
I think I have heard of people using some washers and one of those worthless english sockets as a spacer. Others have cut a length of metal tube to fill some of the space in. If I am picturing what you are talking about correctly.
Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 10-29-2007, 12:51 PM
Mitch Leland's Avatar
Engine Adapter...
Howdy,
What you need to do is to remove two of the long bell housing bolts from the back of the engine. I was told to use the left side bolts (on the oil cooler side), however the adapter that I bought was more for a VW (it had 4 spokes, not 5) did not have the relieve for the over hang of the oil cooler housing. So I removed the long studs on the right hand side and installed the adapter. To remove the studs I would use some "mouse milk" or equal then run on two old nuts to the stud, lock them down against each other and remove the stud. This works well and won't destroy the stud. The adapter is made so that you can split the engine while on the stand, so the half arc of the adapter is in the vertical position.
I can take a pix of my engine on the stand if that would help...
See ya,
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 10-29-2007, 12:56 PM
Wildman Emeritus
Mitch;
That would, indeed, help.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 10-29-2007, 12:59 PM
Mike,
I'll get a pix to ya this evening... Is your adapter a 4 or 5 spoke? I bought mine off of e-bay from a guy in California for $90. However it's a 4 spoke and doesn't have the relieve for the oil cooler that the $240 model has. Since I'm not a professional I think the the cheaper one will work for me.
See ya,
Mitch Leland
Old 10-29-2007, 01:26 PM
Wildman Emeritus
5 spoke from our host. I will look for a photo.
Thanks again.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 10-29-2007, 01:43 PM
Mike,
I didn't realize that our host carried the adapters... Do you still want a pix of the adapter attached to the engine?
Mitch Leland
Old 10-29-2007, 01:53 PM
Engine Adapter...
Mike, here's a couple of pixs for attaching the engine adapter. Also a way you can remove the tranny mounting studs.
I hope this helps...
Mitch Leland
Old 10-29-2007, 05:31 PM
2nd Pix...
Mike, here's another pix that didn't come through the first time...
Mitch Leland
Old 10-29-2007, 08:11 PM
Wildman Emeritus
Thanks,Mitch.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 10-30-2007, 05:12 AM
Forced Induction Junkie
WERK I's Avatar
Hi Mike,
I used sockets (S.A.E., of course ) as spacers for the yoke. Otherwise, you can remove the transmission studs and use shorter studs as mentioned and mildly torque them to the case.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 10-30-2007, 07:23 AM
Just to clarify the mounting of the engine adapter I used bolts rather than a shorter stud. Hey, it all works.
Mitch Leland
Old 10-30-2007, 07:31 AM
OldTee's Avatar
Originally Posted by WERK-I View Post
Hi Mike,
X2. First good use for my SAE tools in years.
Old Tee
all 911s sold
Old 10-30-2007, 12:57 PM
