Forget it, the oil companies do not give rats ass about older cars or the folks who own or care for them. Notice the lack of warnings from any company about the potential damage from reduced zinc and phosphorous while they dumbed down their products? We're a small, insignificant part of the market.
IMHO, both Swepco & Brad-Penn are comparable products and we stock both of them for that very reason,...:) I think they are very close in pricing, especially when factoring shipping. We have Swepco in bulk for in-house use and stock quart containers of the 20w-50 Brad-Penn oil for in-house and mail order. |
Flat tappets
is a misnomer. All tappets have a slight concave or convex cut to allow the tappet to rotate and not stay in on place. In the 911 the contact point between the valve stem head an the adjuster are slightly off center for the same reason.
Thanks! |
Carnutzzz,
With the info shared by Wayne, Charles and others, I'd stick w/Swepco or Brad Penn! |
I'll probably just run the Shell for a few months, then drop in some BP or Swepco. Are we all comfortable with that? Should I drop in some additive? I do like the idea of properly greased internal shiney bits. |
Stuff like the Shell Rotella T seemed to be good for a while, but even that seems to now be reformulated. Charles Navarro, last time I have seen, seemed to say that Castrol GTX has the right amount of zinc and phos. But I'm not sure anymore! Fuch it, I just ordered 2 cases of Brad Penn. All the stuff other than Brad Penn or Swepco make me nervous now to use in my expensive engines. |
I totally agree with BP or Swepco appears to be the best choice. There are other factors like how much mileage per year, what climate do you live in, track-time or just street driving. I still favor Diesel oil even though Steve points out that Diesel engines don't rev above 3000 RPM. Like Charles said: "The Swepco 306 is a CI-4 15w40 diesel oil that is a phenomenal product in it's own right." |
The last time I took the time to read through all the posts in the various oil threads, Castrol GTX 20/50 high mileage was a recommended oil because the high mileage additives were considered beneficial. Is this no longer the thinking of all the oil gurus?
Please, please, please does someone have a list of approved oils for early air cooled cars? Something that lists oils from best (I'm guessing Swepco 306 15w40 or Brad Penn Racing 20w50) to recommended only if you can't get or afford the other stuff (perhaps Castrol GTX 20w50 or Kendall GT-1 20w50)? Maybe like a top 10 list in order. Sure would help us guys who just want to put quality oil in and drive (not necessarily race) our cars. Thanks. |
Per Cnavarro, Mobil 1 V-Twin 20w50 is the best overall choice, and I've been using it in my 3.2 for the last 8k miles with good results. It has some of the highest levels of Z & P of all the oils tested...
David - make it easy on yourself and use one of the two oils you listed. Brad Penn or Swepco.
Or use any of the old M1 you have lying around - I plan to do that then switch (assuming this is not completely resolved by the time for my next oil change - and I'm sure it won't be). |
From what I am seeing, the "best" is Brad Penn or Swepco. If you need to use another brand due to some issue, Castrol 20W-50 is ok but allow no more that 3,000 miles between changes. The current Kendall 20W-50 is not the same as the stuff that made their name in the '60s. The stuff in the Brad Penn can is what used to be in the Kendall can. |
I need to add my .02 here as well. This last weekend I checked my oil level after 2000 miles and found it three quarts low. The motor only has 9500 miles on it total. I have been running Mobil 1 15/50 except for the 1000 mile break in period which I was using Kendall 20/50. Since then it has been Mobil 1 15/50 with GM EOS added to it. I think the damage was done in the first 1000 miles. It is driven on the street and never beaten. I think I have been stung on the oiling issues being discussed here. I need to do a little more home work before I dive in and tear the motor apart again but I am pretty sure my valve guides are toast. Will post again when I've checked the guides for wear.
Shell
I just bought Shell Rotella T Synthetic 5W40 for my '86, it is rated CI-4 and CI-4 Plus. Is it on the "approved" list? I have been using Mobil 1 0W40, gonna get it outta there ASAP.
Syncroid - any problem you may have would not have been caused by your oil selection, particularly since you added EOS which would have resolved the problem of low ZDDP levels in reformulated Mobil 1.
Brad Penn.....Bradford, Pennsylvania......
....see online American Refining Group, Inc. (for your reading pleasure and info.) with facts, history, etc. ...In part, formerly "Kendall"... ...Penn1 20W50 Racing Oil.....good stuff. :) ...the "Green Oil"... In the Puget Sound area Fred Williams (Freddy's Engines) in Snohomish will deliver at a good price. :cool: No affiliation. |
for 1st 1k miles the assembly lube and Mb should he really high & at least partially ameliorate using 'normal' oil
All the innards and turbochargers held up very well given the operating environments and temperatures and a lot of other IMSA racers had similiar experiences. IMHO, its better than many so-called synthetics. |
| All times are GMT -8. The time now is 06:57 PM. |
