-   -   Word from Shell and Castrol re: ZDDP etc. (http://forums.pelicanparts.com/porsche-911-technical-forum/375427-word-shell-castrol-re-zddp-etc.html)
Emission 11-05-2007 04:09 PM
Originally Posted by Steve@Rennsport (Post 3570824)
We ran the old Kendall GT-1 20w-50 (now called Brad-Penn oil) in our 935's for many years and nothing generates peak oil temps like a 700-800HP 3.2 @ 1.5-1.6 bar,...:)
All the innards and turbochargers held up very well given the operating environments and temperatures and a lot of other IMSA racers had similiar experiences.
IMHO, its better than many so-called synthetics.
800 hp? Yeah... that is a validated endorsement. I appreciate it. SmileWavy
- Mike
Zeke 11-05-2007 04:18 PM
I have no empirical info about Kendall, but I always liked the stuff. Thanks to this forum, I know now that Kendall is made somewhere else by someone else. Not saying it's not as good and not saying BP is a substitute, because I don't know. But, I will be using dino oil for some time to come on my old 3.2. So, I guess it's either V-twin or BP. I'll see what I can buy w/o incurring shipping charges.
York 11-05-2007 04:36 PM
Anybody know about the Rotella T Syn 5w40 CI-4?
HarryD 11-05-2007 05:29 PM
As far as I know, if the oil does not have the CJ-4 rating also, you should be ok.
KobaltBlau 11-05-2007 07:35 PM
IMHO, [kendall gt-1 is] better than many so-called synthetics.
Steve, your statement seems to leave the door open for some synthetics. If a person has preference for synthetics for some reason (very cold starts in the winter time, for example), do you have a recommendation?
Cheers,
Steve@Rennsport 11-05-2007 11:00 PM
Hi Andy:
There are several "real" synthetics that have all the "right stuff" for these engines. :)
Some of them are:
Mobil 1 V-Twin 20w-50
Royal Purple Max Cycle 20w-50
Royal Purple Racing
Redline oils
Joe Gibbs Racing oils
Motul race oils
A note,......some of these racing-specific formulations have little or no detergents to reduce/eliminate foaming at high RPM and should not be used for street use unless changed within 500-1000 miles. Redline offers both street and racing oils. Joe Gibbs oils are primarily for competition.
cnavarro 11-06-2007 11:57 AM
Originally Posted by Gunter (Post 3567033)
Shell.ca was very open and forthcoming.
SHELL REPLY:
Rotella T 15W-40 meets API CJ-4, and supersedes CI-4 and previous specs. Maximum allowable Phosphorus content for API CJ-4 specified oils is 1200ppm. Phosphorus (S) and Zinc (Zn) comes from ZDDP additives used in the oil.
I thought I would point out that the CJ-4 standard limits P to 1000 ppm. Not even the person from Shell that was writing you could get that fact right :-)
cnavarro 11-06-2007 12:01 PM
I found our field tests from early '06 where we ran gtx, brad penn, m1 vtwin, and rp on a cross country drive, oil changes every 800 mi, with complete drain of oil system (recaptured oil into the bottles for later sampling). The Brad Penn had the best UOA. I'll need to scan them in and I'll post them. (check the ultimate motor oil thread, as that's where i'll post the link)
I too believe that it's the formulation of the oil that matters the most and that you can refine a petroleum product to perform as well as a syn if you really care to, like Brad Penn and Swepco do.
the 11-06-2007 12:12 PM
Charles - thanks for all of your work in this area and taking the time to post. It is incredibly helpful!
I am going with Brad Penn for my 911s. But what about for modern cars like current BMWs and MBs, which call for thin synthetic oils?
cnavarro 11-06-2007 12:23 PM
Email me or call me for specifics for other cars. With some makes, like BMW and VW, there are also warranty considerations and such, just like with the new Porsches.
I have had quite a few people buy the Brad Penn 0w30 (has 30-40% pao group 4 syn base stock blended in) in lieu of using 0w20, 5w20, 5w30, and 10w30 for their new cars. Excellent formulation with excellent TBN and a film strength (HTHS viscosity) higher than M1 0w40.
Wayne 962 11-06-2007 12:35 PM
Pelican sells the Swepco 306, and that's what I'm using on my cars these days:
http://www.pelicanparts.com/catalog/shopcart/CARE/POR_CARE_swepco_pg7.htm
-Wayne
Gene Wilkes 11-06-2007 12:39 PM
I'm using the Brad Penn 10w30 in my 92 BMW 325is. ;-)
RWebb 11-06-2007 01:42 PM
How are the detergent levels in the Brad Penn?
cnavarro 11-06-2007 01:58 PM
The multigrade Brad Penn is ~10 TBN; the monogrades are in the ~7 TBN range.
Johnb911 11-14-2007 02:16 PM
If you are in Canada and want Brad Penn I may have the answer
See this thread:
http://forums.pelicanparts.com/porsche-911-technical-forum/377414-brad-penn-oil-just-may-available-canada.html
Johnb911 11-17-2007 10:07 PM
LORDCO Autoparts stocks GM EOS
Just so you western guys know.
I was at the Maple Ridge store today and they had lots.
Jeff Alton 11-17-2007 10:23 PM
Hmmm, I tried them a while back when I started the "has the formula for GM EOS changed" thread. I guess they got some more, off to the store I got tomorrow!!
Cheers
