GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
Setting Webers - Off Idle problem
My weber 40ida's are having a difficult time coming off of Idle when accelerating.. Any quick adj..
I have the Air screws turned all the way in and the Mixture screws 2 turns out.
I have them set for E spec cams.
Old 11-07-2007, 02:59 PM
I would rather be driving
jpnovak's Avatar
First, have you balanced the throats with the air bleed screws and linkage? Do this first with a synchrometer. Afterwards, if you still have the problem do they:
1 - pick up then bog down or
2: just stumble
1 means your accelerator pumps are dumping too much fuel and the engine goes way too rich.
2 means they are likely not dumping enough fuel and the engine goes lean.
Look down the throats and make sure that all the accel pumps are giving fuel.
Old 11-07-2007, 03:39 PM
Mark S
To add make sure you have no more than 3-3.5 PSI fuel pressure going to the carbs.
Old 11-07-2007, 04:46 PM
Alan L's Avatar
The above replies are all good, but really need more info. Could be a host of things.
Do they cough and then come to life? Having the air screws turned right in sounds odd. My initial thought would be an air leak which means the mixture is disproportionately lean at low load/openings. I had this issue with a set of Webers once - not that it is peculiar to Webers. I found a manifold leak after hours of blaming the carbs/timing etc. If they have been running good previously, what have you changed, since the settings are largely fixed.
Alan
Old 11-07-2007, 05:37 PM
Make sure the throttle linkages are properly adjusted. Use the hand throttle to get the speed to 3K and check the right to left airflow with a synchrometer. It may be balanced right/left at idle, but changes once off the idle stop screws.
'72 911T
'73 MGB (sold)
'71 Alfa GTV (sold)
Old 11-07-2007, 06:28 PM
initial timing affects my take off.
and
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-08-2007, 12:07 PM
gigem75's Avatar
try this
71 T still backfires
scroll down to weber set up....
I had and I say had the plastic meter from pelican. It became a great baby rattle when the throat it was on spit back.
I got the old metal style off ebay for 20 bucks
Old 11-08-2007, 12:50 PM
GotaT's Avatar
Thanks for the posts.. still adjusting everything..
Old 11-08-2007, 02:00 PM
