Fishcop
Guest
Posts: n/a
Cornering Noise
Can anyone suggest what is making a banging noise from the rear of my 69T? It usually occurs whilst cornering left or right at speeds above 20mph. I've been told it could be a CV joint or suspension. I think I can feel something through the steering wheel at the same time also. How do I tell if the CV's are shagged, can they be rebuilt or should I replace them with new ones? I have no sway bars (front or rear...will get around to these), and I'm pretty sure the engine mounts are fine. Any ideas or suggestion would be great, Thanks.
Old 02-22-2001, 04:23 AM
marc weintraub
Guest
Posts: n/a
Make sure you don't have a lsd that is going bad. Look for the obvious with the CV joint and suspension, but I had a similar situation that only occurred when I accelerated very hard or made a sharp turn to the right. My limited slip needed to be rebuilt. Hopefully, your situation will be a less expensive fix.
Marc
Old 02-22-2001, 06:52 AM
Superman
Guest
Posts: n/a
Mine makes a banging or thumping sound when cornering to the right. Single thump. Sounds like a loose baseball.
This is not a CV noise. Some have suggested it is a loose/worn spring plate bushing. Sounds like it's happening on the rear deck, right behind my head.
'83 SC
Old 02-22-2001, 07:24 AM
David W
Guest
Posts: n/a
I had exactly this problem with my 72E. Drove me crazy. Only happend on sharp turns. Turned out to be a bad inner CV joint. Ball was popping out of race.
Old 02-22-2001, 08:53 AM
robfix
Guest
Posts: n/a
Same thing while turning left. I'm hoping it is the cv joint as when I went to repack them they had serious pitting. On one the grove was so bad I don't think the ball could rol by, when it did I think it made the loud pop. I have the new ones and will install this weekend. I'll let you know if this eliminates the noise.
Rob Fix
'78 SC Targa
Old 02-22-2001, 09:00 AM
tcampbell
Guest
Posts: n/a
Just wanted so say thanks for bringing this topic up. I JUST started hearing this exact symptom on my car last week. You guys are great!
Old 02-22-2001, 09:51 AM
