Chris Lovell's Avatar
How can I test brake calipers?
I am about to change my master cylinder and pads in an attempt to improve my brakes which have become less effective. I thought I would test the calipers for proper operation during this process. Is it possible to test brake calipers? Any advice is welcome.
CWL
'88 Carrera Cab
Old 11-16-2007, 06:08 PM
KTL KTL is online now
Schleprock
KTL's Avatar
-Pull both brake pads out of only one caliper.
-Press the brake pedal down about 1/2 way.
-Go look at the caliper and see how the pistons moved.
-If both extended out of the caliper somewhat evenly, without much pressure needed at the brake pedal? That caliper is fine. You may need to press the pedal a few times 1/2 way to get the pistons to retract a noticeable amount. This is especially the case for the front brakes where the larger pistons move less. Be sure to only press the brake pedal 1/2 way (it's very easy to floor the pedal) so you don't overextend the travel of the master cylinder- overextension sometimes causes the master to fail.
-Push pistons back into caliper and reinstall brake pads.
-Press brake pedal until pads press against recently worked on caliper.
-Go to next caliper and repeat the procedure.
-If you run into a caliper that has a piston(s) that don't want to come out? You've got a booged up piston that needs to be removed and cleaned or replaced. Possibly could need a replacement caliper dependent upon level of corrosion.
Before testing the calipers, test the master cylinder by pumping the pedal and holding the pedal down very firmly for at least 20 seconds. If you notice the pedal slowly dropping as you apply firm pressure? You've got a failed master cylinder that needs to be replaced.
Kevin L
'86 Carrera "Larry"
Old 11-16-2007, 06:18 PM
That is so simple and elegant. I will do just that. I am going to replace the MC so I will be sure to do your test pre-MC replacement. Thanks very much.
CWL
'88 Carrera Cab
Old 11-16-2007, 06:26 PM
BertBeagle's Avatar
For piece of mind, if the calipers are old or of unknown history as in you bought the car used, just rebuild them with new seals and bleed screws and replace any parts that show wear or damage (pistons, bridge pipes). It's not expensive nor time consuming and then you know what you have.
There really isn't a good on car test beyond checking for leaks and making sure you don't have drag or pulling under braking. Leaks and pulling are obvious. Drag can manifest by pulling while moving, off brake, in a straight line.
Old 11-16-2007, 07:42 PM
