P:icture needed please... behind rear reflector
I have been searching tonight and cannot seem to find this. I need a picture of the area behind the reflector when it (reflector) has been removed... I have an 83. I am planning a small project but would prefer to see what this area looks like before I take the chance of prying mine carefully off. Thanks in advance
Shane - 1984 928S |
I will get you one tomorrow off my 84 if you still need it by then....
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Here you go:
It's held on with nuts. Don't pry it off.
'69 911 Targa w/ 3.2 |
Retired Member
To acess the nuts you have to remove the muffler. Once the muffler is removed you will see a sheet metal panel. Remove that panel and you will see the reflector nuts.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
Champagne on Beer Budget
Nice looking rear Larry!!!!! Which white is that?
Hope to have mine lookin like that sometime in the next couple of months. Helmethead |
I thought the later ones (like 78/79 and later) had platic barbed clips. Did I get some wrong info?
Shane - 1984 928S |
Yours uses plastic studs on the reflector which go into metal barbed clips in the panel shown.
The only way I've found to remove the reflector without breaking it is to use a thin sharp awl or even an ice pick to spread each individual barb open to release the reflector stud. There is a top and bottom barb for each stud. You can reuse the clips by bending them back into place. |
I am not sure what it is called but it is the same white off of a '96 Twin Turbo. It just so happened that the owner of the shop had a gorgeous white Twin turbo and I said use that color.
Barbed clips. Gently pry it off.....
Cheers
Definitely the barbed clips. I've got an 83 also and disassembled mine a couple months ago.
Brian Starr Alabama Region PCA 1983 911SC/Rebodied as 993 w 3.6 1995 911 C2 (Sold) |
Sorry, my mistake. I have only seen the earlier ones with nuts.
