Twin plug stuff. Need help to ID
I found a bag of ignition parts marked twin plug dist parts. Inside I found 2 brass gears in the oem packages showing part # 547.09.248
Also found 2 caged bearing assemblies also in oem bag and with part # 900.052.007.00 Lastly there is a neat looking plate with two sets of points mounted but no part #. See pictures Who has the knowledge to id this stuff? ![]() ![]()
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
points plate
that looks like the fuel injection trigger points for the 914-4
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
That would make sence because the terminal plug looks kinda new to be a twin plug part. Do you know for sure or does it just ressemble a 914/4 setup? What about the bearings?
points
There should be a bosch part # on the piece something like (0 xxx xxx xxx x )
post the # and we can figure it out. I can't tell by the pic what they are. Mike
