-   -   Here we go again! Zuffenhaus MS RSR project... (http://forums.pelicanparts.com/porsche-911-technical-forum/379658-here-we-go-again-zuffenhaus-ms-rsr-project.html)
eimkeith 07-21-2015 02:19 PM
Originally Posted by santagrant (Post 8719039)
Where did you find the jig to align the top? Wonder if one could be rented from someone in the SF Bay Area.
By the way, your project is coming along very nicely. You are very brave!
I couldn't find one to buy or rent! :(
(but I'm in the market if you come across any.)
eimkeith 07-22-2015 01:56 PM
More work on the shifter today (need to get back on welding, but it's hard for me to transition back & forth in the proper frame of mind, so I'm seeing the design work through)
http://images.tapatalk-cdn.com/15/07...3625c28ff8.jpg
http://images.tapatalk-cdn.com/15/07...3a7f94f34a.jpg
There's enough going on in the wacko G50 shift assembly as it is; much respect for Wevo and JWest for tackling this for such a small number of cars.
I'm making it worse for myself by putting a 915 shift tower on top - I've got to limit shift lever movement accordingly to work through the vertical 'tube', but still get the travel and angles needed in the tunnel.
The photos above are my 3rd version, 2nd revision (shown without the 915 tower installed.)
I'm printing revision 3 this evening. ;)
Closing in on it.
keith.
(sent from my rotary dial phone.)
eimkeith 07-24-2015 10:32 AM
Ok, revision 4 is a winner. Full fore/aft travel, ample degrees of rotation on the gear selector shaft.
http://images.tapatalk-cdn.com/15/07...246ae2b822.jpg
This is what it will look like with the 915 shift tower installed over it:
http://images.tapatalk-cdn.com/15/07...b88aa7e8b6.jpg
(Imagine a 915 shift lever installed, with boot.)
keith.
DaddyGlenn 07-24-2015 04:40 PM
I am so envious of you, Keith. To be able to spend your days doing design and fabrication on these cars .... and get paid to do it.... nice!
I know you must have bad days from time to time. But I sure it beats the hell outta my desk job.
Keep it up. I'm living vicariously through your posts.
eimkeith 07-24-2015 05:49 PM
Lol, glad you're enjoying the thread.
keith.
eimkeith 07-28-2015 08:24 AM
Quick Tuesday morning update:
I couldn't locate a good original RSR transmission cooler (the end of the road for the hard lines on the driver's side of the Mary Stuart), so I got started on converting an RS-style trombone cooler.
Here's the cooler and the reference photo (photo of '74 RSR):
http://images.tapatalk-cdn.com/15/07...5a2b3aa527.jpg
Right-hand brackets/tabs de-brazed.
http://images.tapatalk-cdn.com/15/07...0d3c8be3fb.jpg
So far, so good!
keith.
eimkeith 07-28-2015 11:06 AM
Back on the roof welding (1/2 completed)
http://images.tapatalk-cdn.com/15/07...683d097f9a.jpg
http://images.tapatalk-cdn.com/15/07...7e9f8deabc.jpg
keith.
eimkeith 07-29-2015 08:30 AM
Cleaning up some rocker rust this morning.
http://images.tapatalk-cdn.com/15/07...589cd25c20.jpg
A little disappointed with the patch panels available, though:
http://images.tapatalk-cdn.com/15/07...d4cd29b223.jpg
keith.
em78911 07-29-2015 09:54 AM
Would you mind posting any pictures you had of the sunroof weld up job you performed?
eimkeith 07-29-2015 02:05 PM
The previous time (welded in sunroof panel) or this time around (replaced roof skin)?
I don't have photos of the first time it was done (I wasn't the primary on this project until the carbon bodywork phase) - but I don't recommend the weld-the-sunroof-panel approach.
keith.
eimkeith 07-29-2015 02:12 PM
Almost wrapped the driver's side rocker repair today (misplaced the lower quarter panel face piece I removed several weeks ago, can't finish this until I find that damn thing!)
Here's some pictures of today's work.
http://images.tapatalk-cdn.com/15/07...e694d60964.jpg
http://images.tapatalk-cdn.com/15/07...cd2bb70bf1.jpg
http://images.tapatalk-cdn.com/15/07...1b6cf5fb70.jpg
http://images.tapatalk-cdn.com/15/07...1d81aad510.jpg
http://images.tapatalk-cdn.com/15/07...96ef716960.jpg
http://images.tapatalk-cdn.com/15/07...5e7bcfe1af.jpg
(Had to slit this piece to narrow it to fit)
http://images.tapatalk-cdn.com/15/07...827464dc76.jpg
http://images.tapatalk-cdn.com/15/07...a68a4e255d.jpg
http://images.tapatalk-cdn.com/15/07...fdfc27dfb3.jpg
Now to find that missing piece.. >:(
keith.
em78911 07-29-2015 06:34 PM
keith.
Hey keith,
yeah , was wanting to see the first plug up.. when you welded a plug in the sunroof... not so much the reskin... thanks.
eimkeith 07-29-2015 07:06 PM
Originally Posted by em78911 (Post 8731528)
Hey keith,
sorry; I don't have any photos of that previous work.
I can tell you that filler strips were used, and a lot of forming is needed to control distortion - that method requires welding in the middle of a relatively flat plane, no natural curvature to resist drawing of the heat affected zone (plus there are two closely spaced parallel lines of weld around the sunroof - making the draw worse.)
hope that helps in some fashion?
eimkeith 07-30-2015 04:21 PM
Worked on the passenger side rocker today (funny how the one with less rust took longer; didn't quite finish it)
http://images.tapatalk-cdn.com/15/07...25d97e32e8.jpg
Down to the good stuff
http://images.tapatalk-cdn.com/15/07...3850ffd733.jpg
Fitting the patch
http://images.tapatalk-cdn.com/15/07...14a1cb8fec.jpg
http://images.tapatalk-cdn.com/15/07...9a68ea513c.jpg
http://images.tapatalk-cdn.com/15/07...c6342d7d5e.jpg
Fitting the top layer
http://images.tapatalk-cdn.com/15/07...1bd176c0b6.jpg
Didn't get a shot of that welded in, but finished the day with welds that need to be ground & finished, then primed.
keith.
eimkeith 08-04-2015 01:28 PM
Working on the 930 trailing arm mount conversion today, but never posted the finished rocker repair on the passenger side, so here it is:
http://images.tapatalk-cdn.com/15/08...11aad4c7b0.jpg
OK, trailing arm mounts.
You'll recall that we're using 930 trailing arms (wider track, massive bearings, etc.) on this build, so we need to modify the pickup points on the chassis.
I modeled up a conversion that visually references the RSR solution in 1973:
http://forums.pelicanparts.com/uploa...1429797196.jpg
I started making the pieces today, using templates I'd printed out to mark the material for drilling & trimming.
http://images.tapatalk-cdn.com/15/08...6a8974ab3d.jpg
Make a pilot drill jig
http://images.tapatalk-cdn.com/15/08...642fc67935.jpg
http://images.tapatalk-cdn.com/15/08...8baf71d9fd.jpg
http://images.tapatalk-cdn.com/15/08...d6d79b60d1.jpg
Similar tolerances to original trailing arm bolt holes.
Here's the fitting work on another G50 housing:
http://images.tapatalk-cdn.com/15/08...df24b2305f.jpg
http://images.tapatalk-cdn.com/15/08...48532dd484.jpg
keith.
eimkeith 08-04-2015 01:36 PM
My (symmetrical) installation tool doesn't line up with the transaxle mount on one side of the mock up torsion bar housing, surprisingly.
http://images.tapatalk-cdn.com/15/08...ef87e7a374.jpg
I'm assuming there are deviations during manufacturing so I'm modifying the file and printing another install tool, this time with slotted holes at the transaxle mount.
I've also concluded that I will in fact need to cut welding access holes in the rear seat pan (thought I could avoid that) to install these mounts properly.
Such is life!
keith.
eimkeith 08-05-2015 05:40 AM
Alright, back at it with new install tool (12 hr print)
http://images.tapatalk-cdn.com/15/08...745c00cf42.jpg
Hard to see here, but ample clearance for locating hole now.
http://images.tapatalk-cdn.com/15/08...cd00ce5663.jpg
keith.
eimkeith 08-05-2015 06:11 AM
Access!
http://images.tapatalk-cdn.com/15/08...582fb715c2.jpg
Fitting to the cast portion of the torsion bar housing:
http://images.tapatalk-cdn.com/15/08...021778e03e.jpg
http://images.tapatalk-cdn.com/15/08...539fab35b6.jpg
More work needed here for proper fit.
keith.
eimkeith 08-05-2015 07:26 AM
And tacked in.
http://images.tapatalk-cdn.com/15/08...a8e5ada1fb.jpg
Now to mock assemble the suspension and set up the car to verify alignment before finish welding and adding the bracing.
keith.
jjeffries 08-05-2015 01:05 PM
Fascinating, superb and overall uber-cool design and workmanship. John in CT
eimkeith 08-05-2015 01:58 PM
Ha! Thanks John.
keith.
scootermcrad 08-06-2015 05:45 AM
Now THAT'S some bad ass work, right there! Nice job, Keith! I have got to try and get over there, next week.
I have to replace a Torsion bar tube on my '70. Maybe I can pick your brain on this topic...
eimkeith 08-07-2015 07:59 AM
Sure thing.
keith.
eimkeith 08-07-2015 08:06 AM
Working on prepping the suspension today; hoping to assemble to near final setup at this point to make final car assembly more efficient later.
The objective is to put the suspension on the car, install the engine and transaxle, rough in the ride height and corner weights and do an alignment prior to finishing the trailing arm mounts to verify the design work. Then it will come back apart and go ont the rotisserie for final metalwork.
Here's is what is being replaced in the rear:
http://images.tapatalk-cdn.com/15/08...84e7fb2218.jpg
We love this Elephant/Fox combination but it isn't visually compatible with the project goals.
Yesterday I soda blasted and cleaned the 930 arms, today Ido a final clean and begin assembly.
http://images.tapatalk-cdn.com/15/08...c81f952ab0.jpg
keith.
eimkeith 08-10-2015 09:45 AM
Reworked my RSR Spring Plate Bushing Cover over the weekend after meeting with the pattern maker (of course he wanted more draft.). ;)
Here's where the solid model stands now:
http://images.tapatalk-cdn.com/15/08...603d40a2dc.jpg
I'm printing it to double-check my critical dimensions and general proportions, then it's off to the pattern-maker & foundry.
(If I can get these turned around in time, I'll take one with me to Rennsport in case any of you want to see it in person.)
keith.
scootermcrad 08-14-2015 03:59 AM
I've gotta' bump this up to say how incredible this car is. I got a chance to see this thing in person yesterday and the details and thought put into this build are above and beyond!
Well done! My hat's off to ZUF!
eimkeith 08-25-2015 01:27 PM
Thanks!
keith.
eimkeith 08-25-2015 01:42 PM
Have I mentioned the '73 RSR transmission oil cooler in the left front fender (wing?).
The original looks very much like the RS trombone oil cooler with the mounting tabs relocated.
Did I forget to mention my first attempt with modifying a new Porsche cooler? It went well at first; I successfully removed the brazed steel tabs (higher temperatures needed for this) from the brass cooler, then fumbled the re-brazing:
http://images.tapatalk-cdn.com/15/08...ebe3de0896.jpg
Ouch.
I ordered another cooler from Porsche and after wringing my hands for a few days, managed to screw my courage to the sticking place and go at it again this morning.
I cautiously removed the tabs from the replacement cooler as before
http://images.tapatalk-cdn.com/15/08...447722dbf9.jpg
http://images.tapatalk-cdn.com/15/08...52745edb62.jpg
And proceeded to braze the steel tab back on the other tube:
http://images.tapatalk-cdn.com/15/08...e6282d1d0b.jpg
Success!
http://images.tapatalk-cdn.com/15/08...19a745891d.jpg
That was a nail-biter. I'd like to think I was a better brazer in college, but that might be romanticizing the good old days...
keith.
eimkeith 08-25-2015 01:47 PM
I tested the cooler for leaks in a bucket of water, using the 2 plastic caps that shipped with the cooler, poking a hole in one for pressurizing with compressed air. Aaron (the other half of the Zuf Army) and I were peering down into the bucket looking for bubbles when the pressure in the cooler finally overwhelmed the other shipping cap and lodged it into our ceiling (23 foot tall ceiling) - so I'm considering that as passing the pressure test.
keith.
eimkeith 08-25-2015 01:52 PM
On to mounting. This cooler has to fit against the contoured section of the G Chassis trunk wall that accommodated the battery, whilst also clearing the fender/bumper mounting flange, the turn signal assembly, the curve of the bumper, and the headlight bucket.
http://images.tapatalk-cdn.com/15/08...392dd5b2a4.jpg
http://images.tapatalk-cdn.com/15/08...d7123c6c89.jpg
http://images.tapatalk-cdn.com/15/08...5d35923ec1.jpg
The preliminary position was marked, the brazed tab heated and re-shaped a bit, and the fender was pulled for mounting.
http://images.tapatalk-cdn.com/15/08...daae2de843.jpg
http://images.tapatalk-cdn.com/15/08...1ba9f2640a.jpg
http://images.tapatalk-cdn.com/15/08...f8e25728d4.jpg
http://images.tapatalk-cdn.com/15/08...0b84d37089.jpg
That'll do nicely.
keith.
eimkeith 09-01-2015 06:35 AM
Preparing suspension this morning (just got steel parts back from coat, installing with a combination of Elephant and Rebel bushings.)
http://images.tapatalk-cdn.com/15/09...331baa926a.jpg
http://images.tapatalk-cdn.com/15/09...d0e3ffb1d0.jpg
keith.
78-911SC 09-01-2015 07:24 AM
Keith as usual nothing but perfection. One thing I'm curious about is why the trombone over a radiator style?
eimkeith 09-01-2015 07:53 AM
Historical accuracy. I'll dig up a photo from a '74 RSR that I used for reference (which is a year off, but I believe is correct for this project.)
And thanks for the compliment; perfect may be a stretch, but I appreciate it!
keith.
ixxify 09-01-2015 09:27 AM
subs
eimkeith 09-01-2015 01:18 PM
So this has happened:
http://images.tapatalk-cdn.com/15/09...f922a69f70.jpg
:Beer:
keith.
lateapex911 09-01-2015 04:40 PM
keith.
Woof. Some nice looking parts there.
Love this thread.
eimkeith 09-02-2015 08:33 AM
Back on suspension fitting this morning.
http://images.tapatalk-cdn.com/15/09...c018a78723.jpg
Some clearancing needed for the Rebel parts.
http://images.tapatalk-cdn.com/15/09...e5fa31fec4.jpg
End result is fantastic.
http://images.tapatalk-cdn.com/15/09...6c8078a024.jpg
keith.
Shaun @ Tru6 09-02-2015 09:21 AM
Keith, is that black zinc or black oxide or powder coat?
eimkeith 09-02-2015 12:54 PM
On the suspension stuff? None of those. ;)
keith.
Shaun @ Tru6 09-02-2015 12:55 PM
black nickel?
do tell!
