S2000 will eventually be raced with NASA southeast in the ST2 class. Hopefully I can make it competitive.
Any thoughts of SCCA ITR? or are your mods more aggressive? I think it could win in ITR.
UPDATE (long overdue)
OK, so I'm woefully behind on the thread updates (as you may have noticed.)
Initially, the Mary Stuart work was to kept to 930-widths, in an effort to keep the project somewhat mild mannered. As things progressed, the client decided to go for it, and requested that the bodywork be made as correct as possible, to closely mirror the historic original car. Since we started this project, the Mary Stuart (Targa Florio winner) Martini RSR Prototype has changed hands, and neither the current, nor previous owners allow use of their molds or measurement-gathering for the purpose of creating replicas - which is understandable if you own a unique 1M dollar investment in automotive history, I suppose. So we worked from photographs that are in the public domain. - and quickly discovered that this body has changed more than once over the years. I think the quintessential MS is the fat fendered, 917 Center Lock equipped phase, so that's what we targeted: http://forums.pelicanparts.com/uploa...1306410226.jpg http://forums.pelicanparts.com/uploa...1306410267.jpg - meaty 15s barely covering the width of the wheels, all of which barely contained by the bodywork, very wide and aggressive. |
Understand that we moved into a new location and were in the process of upfitting our building at the time (actually, we're still running our 3-phase with the help of some Pelicanites - keep that under your hat) so the body re-work from Version 1 to Version 2 took some time.
We used the exisitng V1 architecture as a base for V2, actually building on top of it: http://forums.pelicanparts.com/uploa...1306410761.jpg http://forums.pelicanparts.com/uploa...1306410800.jpg here you can see that we top-coated the foam work to this point (so as to see the shape) and continued building out from there: http://forums.pelicanparts.com/uploa...1306410875.jpg |
If I were a smarter guy, I'd've done a time-lapse sequence of this work... :(
http://forums.pelicanparts.com/uploa...1306410982.jpg http://forums.pelicanparts.com/uploa...1306411056.jpg (Off-topic, you can see in the background of these photos the state of affairs in the Zuffenhaus build shop (now seperated by a wall from the service shop for noise/dust/environment control) - work benches being built, materials still finding homes, etc. It's amazing how long it takes to iron out the final layout of everything for a clean, efficient workspace.) getting wider: http://forums.pelicanparts.com/uploa...1306411096.jpg |
On V1, we had the liberty of making something referential - we could 'fix' aesthetic issues, determine the shapes to some extent and make a pleasant object. V2 needs to be as close as we can make it, so it requiredsome bulking up:
Infill http://forums.pelicanparts.com/uploa...1306411285.jpg http://forums.pelicanparts.com/uploa...1306411346.jpg http://forums.pelicanparts.com/uploa...1306411399.jpg [Nerd Intermission] For those of you who are wondering - yes, in these photos I am using: A) Hot Glue, B) Styrofoam Insulation, and C) Drywall Joint Compound. Much like the effort illustrated in Close Encounters of the Third Kind, the goal is to move as quickly as possible to the correct overall proportions/scale so the overall shape is not lost on the way to the finishing/detail stage. Bulk it up, cut it back, repeat. Clay could be used on top of the foam understructure for detailing work, but the sheer mass of this thing would be difficult to support were it not for lightweight materials. We ended up using the joint compound through to the end, as it provided benefits in the data collection stage (more on that later) over softer surfacing materials. [Nerd Out] |
http://forums.pelicanparts.com/uploa...1306412045.jpg
http://forums.pelicanparts.com/uploa...1306412116.jpg mmmm, Betty Crocker: http://forums.pelicanparts.com/uploa...1306412236.jpg http://forums.pelicanparts.com/uploa...1306412270.jpg At this point, the 12" wide CCW is mounted on over THREE INCHES of spacers to bring it out to the fender. (Theses CCWs are for sale, btw - PM ktr6 for details) Depending on the final wheel configuration (15" or 17/18" center lock, I believe) the offset will be planned in such a way as to 'fill' the fender while maintaining a sensible width. Should be very cool and liveable. You can also see that the underside of the wing has been bulked out somewhat - this determines the break-line between the trailing side of the fender and the wing, which needs to follow the same path as the original (from multiple angles/viewpoints!) This took a few sessions. |
Front work coming up (have to do actual work now)
Really cool update. I appreciate the process and your methods more than the final product, maybe, so thank you for all the details.
That thing is wiiiide! How wide were the stock wheels? |
Keith -
Thanks for posting some insight into your process - it's interesting to see the steps it takes to get to the final product. Is your end result a scanned-into-a-computer form that can then be mirrored for the other side? Or do you have to create the other side 'by eye' too? Tom |
Man that looks great.
My targa is in your shop now, wish I could muster up this build! |
I am really interested to know what the next steps are - do you glass in the foam, or take a plug from the shape to make a new fiberglass rear arch for the car?
This is f*cking FASCINATING. I've never seen this process before, and I'm completely blown away by it. It looks to me like there are a series of measurements that you're writing on the foam and scribing into the sheetmetal. Where are these measurements coming from?
And the follow up...once this is done, will you do a fiberglass mold of the whole thing and make a sheet metal form, or what's the next step?
YES. You are correct, Sir.
Only the left side of the car is being modeled - for the purposes of digital capture and mirroring to create symmetrical right hand parts, for final production in vaccuum-bagged CF or pre-impregnated FG. Should be some top-quality stuff, with no more weight than it actually needs to be strong & rigid. And the marks & notations are my pseudo-mathematics, checking heights/dimensions, working out time travel, etc. You should see inside the walls of my house and my sketchbooks from college... :eek: The second round of scanning/digital data capture was completed just yesterday (there's a lot of contour on the rear quarters), so these posts are catching up to the present. |
Here's a shot that sort of illustrates how much wider it became for V2:
http://forums.pelicanparts.com/uploa...1306448502.jpg ... and starting work on the front (which HAS to be a relative of the 914 GT fender): http://forums.pelicanparts.com/uploa...1306449176.jpg and a guide coat on the rear for blocking/shaping work (one of many such sessions) - look how much more room is in the fender well - must be 4+ additional inches at some points. (Now that I think about it, this suddenly sounds like email spam) http://forums.pelicanparts.com/uploa...1306449288.jpg and even MORE bulking on the front of the rear fender. http://forums.pelicanparts.com/uploa...1306449364.jpg |
- and here is Bibendum, who turns up in the oddest places:
http://forums.pelicanparts.com/uploa...1306449716.jpg more later, leaving the office. SmileWavy |
Really enjoying the show guys! Thanks a lot for posting this stuff.
no problem - we appreciate the enthusiasm!
More front flare work: http://forums.pelicanparts.com/uploa...1306504369.jpg http://forums.pelicanparts.com/uploa...1306504431.jpg (you can see some additional girth on the rear flare in the above photo - starting to feel like the historic body work) wheel fitment check on front flare (not the wheels this car will run, but appropriate stunt doubles for size/width) http://forums.pelicanparts.com/uploa...1306504655.jpg |
MORE rear fender work:
http://forums.pelicanparts.com/uploa...1306504957.jpg http://forums.pelicanparts.com/uploa...1306505036.jpg and a comparison of the work so far: http://forums.pelicanparts.com/uploa...1306505123.jpg http://forums.pelicanparts.com/uploa...1306505184.jpg even with the bad angle on the last photo, you can see that the rear of the rear fender is too svelte - so here we go... |
http://forums.pelicanparts.com/uploa...1306505437.jpg
and http://forums.pelicanparts.com/uploa...1306505595.jpg - and the front fender top was wrong, so it gets amended: http://forums.pelicanparts.com/uploa...1306506058.jpg http://forums.pelicanparts.com/uploa...1306506135.jpg and that gets really close to final blocking/shaping/finishing work. |
Previously, I neglected to post one of E. Hegg's photos during a shop event:
http://forums.pelicanparts.com/uploa...1306506417.jpg |
Awesome
This is my favourite thread to follow What is the engine choice with the revised and authentic project goals? How did the factory do projects like this? Clay? How do massive rear spacers change how the car handles? ie will it be just the most awesome looking beast or still drive well on the street or just the track or some Sicilian street with a Ferrari trailing behind. |
This car will not run spacers. In fact, you can't with center locks...!
We're working on this wheel center in the background and would love to put them on this project: http://forums.pelicanparts.com/uploa...1306515729.jpg like so: http://forums.pelicanparts.com/uploa...1306515819.jpg That reminds me - we also protoyped a new hub design that allows the 380mm 911RS steering wheel to be mounted on the 1974-1989 911s without changing out the steering column - as seen on this build. http://forums.pelicanparts.com/uploa...1306515973.jpg http://forums.pelicanparts.com/uploa...1306516009.jpg The hub is a 2 piece design, aluminum core for strength/safety with a delrin outer shell (the same material we used to replicate the original nylon extensions for the early four-spoke steering wheels.) The shape mimics that of the early steering column cover, which 'flowed' into the steering wheel (look at a pre-74 car if that doesn't make sense the way I described it) - for an appropriate look and wheel position. We're currently working out the manufacturing strategy on the horn contact. I think this hub product (will be available soon) will be just the thing for backdaters who want a factory steering wheel (or a factory-looking one ;) .) |
Ooops! I posted a photo of an RSR center lock wheel (which we are also working on for modern sizes) when I intended to post this:
http://forums.pelicanparts.com/uploa...1306516546.jpg - which is obviously the front side of the 917 wheel, the back side section of which I posted an engineering drawing of a moment ago. Fat fingers today, it would seem. |
Have you seen Reaper 930's reproduction forged Magnesium 935 5 spoke wheels?
Regarding the engine question, here are a couple of photos of the 3.6/backdated fan FG shroud that we worked on with Series 900: (during prototyping)
http://forums.pelicanparts.com/uploa...1306522010.jpg http://forums.pelicanparts.com/uploa...1306522030.jpg This piece was shipped back to have production units pulled from it, for actual use. |
more nice stuff from you guys, LIKE!
Seems like you guys could both benefit from working together: http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/605086-teaser-vid-935-mag-5-spoke-reproduction.html
This project has been a long time coming and I really appreciate the guys at Zuffenhaus for their hard work and patience with me. I think Ive changed my mind 100 times on this project and its great to see the car take shape. Ive been in love with the original car since I was young and dreamed of owning something similar most of my life.
The goal is to have something that externally looks identical to the original 73 but is as powerful and comfortable to own as a new Porsche. Starting with an 87 allowed me to have a G50 and galvanized body. Engine will be a Zuffenhaus built 3.9 based on a 964 with PMO's. Ultimately this will be a great street/DE car. |
thanks, Keith!
we're fortunate to have opportunities to build cars like this - and its always your prerogative to change your mind, its your vision, after all! |
Have you guys ever thought of using a hand held laser scanner to scan the original? I think it generates a point cloud model and you can import it into CAD then you could CNC router a mold for for your vacuum press or whatever you use for production. Just a thought. It would make this project (and similar projects) much quicker. Here's an example of what I'm talking about... Portable 3D Laser Scanners, 3D Digitizing Systems, Handheld 3D Scanning devices - Toronto Ontario
And what trailing arms are you using? 930s? This is like my dream job. I use to do high end custom woodworking and cabinetry. Now I'm an engineer. This is like a combo of both of those. Cool projects. |
Actually Packy, our software/scanner/digitizer sub was going to use both a lazer and an arm to capture the data from our work (taking measurements/data from the original car being expressly forbidden) and for technical reasons above my pay grade, opted to use the arm exclusively.
I'm in BC for business this week, but will post pictures of that process upon my return. The data collected is actually being used to CNC plugs for mold creation, so you are on the money as far as process goes. ;) Current trailing arms are Carrera, but a move to 930 might be a good idea to help with the negtive offset of the rear wheels... |
As promised:
using the arm to capture the data up front http://forums.pelicanparts.com/uploa...1307557599.jpg http://forums.pelicanparts.com/uploa...1307558186.jpg crunching 1s and 0s, I imagine http://forums.pelicanparts.com/uploa...1307558276.jpg look! a fender appears where Pelican is supposed to be... http://forums.pelicanparts.com/uploa...1307558579.jpg |
That is pretty neat. Can you 'smooth' things out on that model in solidworks if you see a bulge or rough surface where you don't want, or in case you want something to be perfectly symmetrical?
Yes! In fact, during the modeling process the software guys do just that, plus mirror the bodywork for the other side (for symmetry.)
You can just see on the screen that we captured a "skirt" of data around the part that represents the contour of the fender - this extra material will aid in placement and fitment when the composites are mounted on cars down the road. On the rear, the entire quarter is being captured and reproduced. Might even save some weight on the right end of the car when everything is said and done. |
OK, I see. It is like a bunch of 3D splines forming a plane, with the arm defining the inflection points. I like how Solidworks can do all those computations for you. :)
If I had solidworks here, I'd be dangerous (and would accomplish many things unrelated to my job ;) ) |
| All times are GMT -8. The time now is 12:23 PM. |
