-   -   Here we go again! Zuffenhaus MS RSR project... (http://forums.pelicanparts.com/porsche-911-technical-forum/379658-here-we-go-again-zuffenhaus-ms-rsr-project.html)
av winans 11-30-2007 06:48 AM
Originally Posted by Ouzo12 (Post 3612088)
Really great stuff! When is the next swap meet/drool fest scheduled for your shop. I remember coming to one a few months back and had a great time.
Ouzo
Zuffenhaus/Eurowerks will be having an open house and Porsche/ BMW swap meet/drool fest on Febuary 23 2008.
Aaron
CBRacerX 12-06-2007 06:01 AM
Sign me up for another neat build!
Joeaksa 12-11-2007 06:17 AM
Need to win the lotto so I can support Keith...
Slider79SC 12-11-2007 07:32 AM
any updated pictures?
eimkeith 01-04-2008 03:32 AM
Yep, we got the 335s mounted and the rear fenders rolled/recontoured to accomodate them:
http://forums.pelicanparts.com/uploa...1199446147.jpg
http://forums.pelicanparts.com/uploa...1199446175.jpg
http://forums.pelicanparts.com/uploa...1199446199.jpg
http://forums.pelicanparts.com/uploa...1199446233.jpg
next, we'll make fianl adjustments to the front fenders, set up the rough ride height, then begin disassembling for powdercoat. RSR coil over reinforcements on the rear crossmember come next...
ktr6 01-04-2008 06:55 AM
WOW! This project looks like its progressing nicely. Any ideas about which engine platform you will be using in this beast?
village idiot 01-04-2008 07:46 AM
that's just sick!
eimkeith 01-04-2008 07:50 AM
We're thinking mid-80's big block chevy, for torque. Maybe with NOS? SmileWavy
911 tweaks 01-04-2008 07:51 AM
you would'nt commit that sin now would you??
eimkeith 01-04-2008 07:53 AM
BTW, the previous engine from this car will be available for purchase.
It's an '87 3.2, from ECU to exhaust tips complete, with a 2 page build sheet!
This thing was built RIGHT. Low mileage.
Let me know if any of you want specs on it - I'll be happy to accomodate, as it becomes fund-raising for something seriously demented to power this car now that it has NBA-sized shoes...
Pete000 01-04-2008 07:58 AM
wow open the wallet and let it all :eek: hang out !
eimkeith 01-04-2008 08:06 AM
we take first-born children in payment also.;)
eimkeith 01-04-2008 08:17 AM
http://forums.pelicanparts.com/uploa...1199463163.jpg
http://forums.pelicanparts.com/uploa...1199463340.jpg
http://forums.pelicanparts.com/uploa...1199463447.jpg
:eek:
lateapex911 01-04-2008 08:35 AM
This car is cool, but the more distant picture which showed the shop and other projects shows me that you guys have your hands full! Great stuff! Winter is a busy time, eh?
ktr6 01-04-2008 10:17 AM
Sweet, does that mean me can expect to see this car on an episode of Pinks?
eimkeith 01-04-2008 10:41 AM
haha - nice.
911GT2 01-04-2008 01:18 PM
Nice work!!!
eimkeith 01-08-2008 12:21 PM
Original engine (for sale) specs here
HelmetHead 01-10-2008 05:43 PM
Keith,
I'm curious to know more about the powdercoating of the tub on this project and Matteo's car. Prior to PC'ing the tub do you complete your bodywork (all metal welding, etc) then bake the PC? When do the body fillers get applied if any are used...is this done after the coating? I'm considering powdercoating my tub once I complete my welding/modifications but am still confused about the sequence of steps.
My thought to sequence are:
1. Make changes to body such as flares/drip rail deletion/stiffening mods.
2. Hammer and dolly to desired shape/fit
3. Strip entire tub by either blasting/dipping.
4. Powdercoat tub (normal coating or primer coating?)
5. Finishing body fillers/smoothing of worked areas.
6. Base color coat/clear coat.
Again thanks for sharing the wonderful work you guys do!
Helmethead
Walko 01-10-2008 05:59 PM
This looks like a cool project
Michael
SteveM911 01-11-2008 01:27 AM
Subscribed
Jeez, that's a terrible job you have to go to every day. :D
www.impactbumpers.com
911teo 01-11-2008 02:12 AM
Originally Posted by HelmetHead (Post 3696765)
Keith,
Helmethead
Helmet
you basically nailed it. I am sure Keith will chime in with the details but the process is exactly the one you have outlined.
For the stripping of my car they used a baking procedure. Instead of blasting or dipping they baked the car at a very high temperature. This dissolved any possible residue of material attached to the tub (paint, glue, gunk etc).
The advantage over blasting and dipping was the fact that all the little spots could be reached without the risk of the acid getting trapped.
So from powder coating is basically downhill... it's just a question of putting it back together.
In my case we decided to swap to 930 trailing arms after the PC procedure.
So Keith had to move the pick up points for the TAs.
You can see the contrast with the rest of the car...
http://forums.pelicanparts.com/uploa...1200046204.jpg
Since it was back there it was not a big deal (even though they were painted over in Mex Blue anyway).
Make sure that you get a close match for the color. I remember it was not the easiest task.
eimkeith 01-11-2008 04:11 AM
Actually Matteo's car was our introduction into this process, so we do things in a different order nowadays...!
When we're approaching a big build like this from the onset (project creep doesn't always allow for the correct sequence, mind you), we'll first totally disassemble the car to the unibody - and I mean totally. All that is left is factory undercoating, glue, and paintwork. Everything gets filed and binned by car and put on shelves here at the shop.
Then the car gets shipped to our bakeoff contractor, who puts the car in a large oven which turns all that good german goop into ash. They then pressure wash the entire unibody, every nook and cranny, with a zinc phosphate solution which acts as a temporary rust-inhibitor (like for several months to a year indoors, if necessary.)
Upon receiving the car at our facility in phosphate coat, the fabrication begins. By doing the bakeoff first, we save TONS of prep time over Matteo's project, where we had to do material removal in every area we were working. Additionally, there are no hidden suprises in the body in this method, as you are staring at bare metal - no fillers, no lead, nothing to conceal damage or rust.
The smaller parts - doors, fenders, hinges, hood, decklid, etc. go to a local e-coat facility to receive the industry-standard for corrosion protection, as the major car manufacturers utilize today. This is the black e-coat finish you see on panels in some of our threads.
Upon completion of the fabrication, pre-galvanized unibodies (like 1976 and prior, for instance) are now going to be shipped to a massive contractor that has the capacity to e-coat the entire unibody. Galvanized cars will have this option also, at customer's request, for additional corrosion protection. We are adding this step to the process so as not to have to rely entirely on the paintshop to be meticulous with the OEM-style waxy-goopy stuff that they spray into enclosed channels and whatnot to ward off corrosion. Although that process worked fairly well for the original cars, the years take their toll (even on the galvanized chassis, like my own) and we'd like to see more longevity and have better control over the product (as opposed to trusting the client's preferred paintshop to correctly protect the car against corrosion)
(As a side note, we are looking at keeping a small inventory of titled, repaired, stripped and e-coated unibodies available to individuals and shops to purchase for project-starters and restorations in the future.)
So, now you have a zuffenhaus-modified, stripped and e-coated unibody that can go straight to paint! Or powdercoat.
For additional weight savings (over using sound-deadening and undercoat on the underside) and better wear and tear in the trunk, cabin, and engine compartment areas, we offer the option of having the unibody powder coated. As Matteo mentioned, exact color match isn't always possible, and the powder coat has a different surface sheen than paint, but the color is uniform and the wear qualities exceed that of paint (although nothing is indestructable). the car we've done leave us looking like a big piece of colored-candy - everything coated uniformly with the powder coat.
The powder coat is not applied to the exterior panels, however - these receive traditional paint refinishing that we are all accustomed to. Powder-coat is not spot-repairable and is not an acceptable exterior finish.
As Matteo pointed out, further work can and does happen on the powder-coated areas - as he illustrated with the rear suspension pickup work on his car - the powder coat is ground away, then feathered, and paint is applied over the top for protection.
Did I leave anything out?
HelmetHead 01-11-2008 06:11 AM
Keith - Its no wonder you guys have a shop full of cars to work on with the attention to detail your work provides! :rolleyes:
Thanks again for the detailed information on the coating preparation and finishing proceedures.
Keep up the great work!
Helmethead
Rory Mckenna 01-11-2008 06:56 AM
What is that triangular template hanging off the rear deck area? .. it looks like the template for the tail that was used on the Targa Florio cars.... are you guys going to replicate that car with this one?
lateapex911 01-11-2008 07:12 AM
Hmmm...I thought it looked like the profile of a duck tail...
davisriley 01-11-2008 08:00 AM
I vote for flat black, that thing looks mean! As always keith, fantastic work. Now if I would only hit the lottery......
eimkeith 01-11-2008 08:24 AM
Hmmm.... could it have something to do with this...?
http://forums.pelicanparts.com/uploa...1200068685.jpg
wideRSR 01-11-2008 08:30 AM
This is such an excellent resource, Just want to say thanks for taking the time to post your work here. If I can ask, are the steel flares OEM?
eimkeith 01-11-2008 08:36 AM
Thanks guys for the compliments.
The flares are actually OEM 930 flares, massaged somewhat to fit 12" wheels...
Jeff Alton 01-11-2008 10:03 AM
You guys finally getting to understand the "MS RSR" part in the title of the thread? :)
Cheers
EarlySport 01-13-2008 02:49 PM
Subscribed. Excellent work!
Jon Merck 01-13-2008 04:32 PM
Ok, I'll ask... what is a "MS RSR"?
Wow! That is some meat on the ground... I can only guess what will be stuffed in the engine compartment :D
Sub'd...
ERH 01-13-2008 05:39 PM
Sub'd...
Another clue :)
http://forums.pelicanparts.com/uploa...1200274703.jpg
Ed
boba 01-13-2008 05:48 PM
That's to easy.:rolleyes:
ERH 01-13-2008 05:52 PM
Had the same problem when I was teaching..... :)
rennch 01-13-2008 09:06 PM
subbed.
barney911rs 01-13-2008 09:42 PM
Keith,
Must of missed this thread. I see on the first page what appears to be a Hargett shifter. I'm leaning towards getting one for my race car. I've heard both good and bad stories. What is your opinion on these?
ktr6 04-12-2008 07:40 AM
Keith, any updates?
FenderBender 04-12-2008 02:28 PM
sweet!!!!!
