Rear Fenders
More body work now that the rear fenders are finally bonded to the car:
http://forums.pelicanparts.com/uploa...1569370088.JPG http://forums.pelicanparts.com/uploa...1569370088.JPG http://forums.pelicanparts.com/uploa...1569370088.JPG http://forums.pelicanparts.com/uploa...1569370088.JPG |
The rear quarters and duck tail portion of this car has always been fascinating to me. I would love to see the additional aero coefficients comparing a standard RS/RSR factory design that has the basic duck tail, versus this car with it's additional "spoilers" and wider stance. |
Inner Fenders
Before we bonded the inner fenders were sanded and painted.
http://forums.pelicanparts.com/uploa...1569419828.JPG http://forums.pelicanparts.com/uploa...1569419828.JPG |
More rear fenders
More Rear Fender Work
Primer. First image shows some marks where Keith wanted the edges sanded a little smoother, his attention to detail is second to none:
http://forums.pelicanparts.com/uploa...1569420220.JPG http://forums.pelicanparts.com/uploa...1569420220.JPG http://forums.pelicanparts.com/uploa...1569420220.JPG |
And paint. Tub is going all white as Porsche delivered them, then painted appropriate exterior colors:
http://forums.pelicanparts.com/uploa...1569420443.JPG http://forums.pelicanparts.com/uploa...1569420443.JPG |
Nice 58 Cameo back there. Is it real?
Steering Wheel
Progress on the body work continues. In the meantime the next detail to be worked on is the steering wheel. The R7 used the same wheel used in the 910/917 as seen here:
http://forums.pelicanparts.com/uploa...1569678088.JPG http://forums.pelicanparts.com/uploa...1569678088.JPG |
R7 Steering Wheel
Steering Wheel
We were unable to find a readily available wheel for the project so we decided to make our own. After much research Keith found that a Momo Jacky Ickx wheel, although slightly smaller diameter, had similar proportions and look to the 910/917 wheel:
http://forums.pelicanparts.com/uploa...1569679231.jpg |
Steering Wheel
So research began and Keith was able to develop the proper dimensions and hole sizes that would need to be drilled for the wheel to be correct. After modeling in the virtual world he made an overlay/template to make sure that the machine work was correct.
http://forums.pelicanparts.com/uploa...1569679734.JPG http://forums.pelicanparts.com/uploa...1569679734.JPG |
Steering Wheel
Holes drilled and the hub adapter fits nicely. The wheel will be painted satin black and sent out for recovering. Currently researching the correct stitching and leather.
http://forums.pelicanparts.com/uploa...1569679878.JPG http://forums.pelicanparts.com/uploa...1569679878.JPG |
Rear Bumper
Rear Bumper
Rear Bumper
Rear bumper exhaust cutouts done and bumper reinforced:
http://forums.pelicanparts.com/uploa...1570896216.JPG http://forums.pelicanparts.com/uploa...1570896216.JPG |
Paint
And last but not least, the tub is in the paint booth for paint on Monday!
http://forums.pelicanparts.com/uploa...1570897221.JPG |
I've only just run into this thread. Don't have time to read through it now, just had a quick look at this last page when the steering wheel thing caught my eye.
I guess one of these is what you may have needed. https://i.ibb.co/sjDhX9h/917-Momo-Pr...petition-0.jpg |
Thanks for all the updates. As a general comment, it's in interesting push pull, I'd think....exactly how do you go about this project? the originals were, I bet, not symmetrical, and less than perfect. They obviously could have done certain things better...matching transitions, a ducktail that actually fits (LOL) and so forth, but back then it was a case of getting idea on the track ASAP....races to be won!
So, I'm sure the originals had low spots and weird transitions and such. How much of that do you try and copy? Or do you say, "well, that low spot/dent in the middle, they obviously didn't intend that, (the other side looks fine) so we'll make it smooth"? The transitions/areas where the stock duck and the modded quarters, (for example) and edge matching sections, I guess you'll mimic the original. |
Yea, that is the best path I'm sure. Its not an eay process no matter what though! I like the line up in your sig, pretty unique stuff!
Paint
Cool!
that is a thing of beauty.
regards, al |
Awesome!!!
Wicked
will be WELL wurth the wait...!!
Small update, engine lid grill is coming together:
http://forums.pelicanparts.com/uploa...1574610017.JPG |
Now I'm up to 11 years since first laying eyes on it. Body and paint look great. Hurry along and finish it before your are forced to use an electric motor by some government decree. ;)
Just a quick update, wiring has begun!http://forums.pelicanparts.com/uploa...1584832355.jpg
I too have been following this from the start. Great to see it’s still alive. The paint looks fabulous
http://forums.pelicanparts.com/uploa...1586960065.JPG Reproduction covers sourced from pelican member Timmy2 are fantastic: http://forums.pelicanparts.com/uploa...1586960768.JPG http://forums.pelicanparts.com/uploa...1586960768.JPG |
Master cylinders are installed and a good fit. Reservoirs have arrived as well. I hope everyone is doing well and staying healthy.
http://forums.pelicanparts.com/uploa...1586961132.JPG http://forums.pelicanparts.com/uploa...1586961132.JPG |
Wow, love the updates!
nice. look forward to seeing progress!
Great project Keith, we can't wait to see the final result !
CDI Boxes
6 pin CDI boxes are ready to go!
http://forums.pelicanparts.com/uploa...1589027972.jpg http://forums.pelicanparts.com/uploa...1589027972.JPG |
| All times are GMT -8. The time now is 11:08 PM. |
