Kraftwerk's Avatar
1st time Bondo user... questions
I mixed up some bondo to patch some tiny holes, smaller than dime sized divots and chips in a f/g duck tail. But the stuff is as soft as ever after six hours! Not enough hardener..
My two questions are will it ever set? The room is about 65 degrees
and should I have used a different product? This is just surface stuff small holes about the size of a pencil eraser...
Must I start over?
Was going to post this elsewhere, but the other sections are pretty quiet: car & cruck , drivers forum etc.
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 11-29-2007, 03:15 PM
sudo apt-get purge 930
equality72521's Avatar
Sounds like you didn't mix it properly.
--clutch-monkey
Old 11-29-2007, 03:20 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Remove it, mix a new batch and try that. The stuff either cures or it doesn't.
Black Cars Matter
Old 11-29-2007, 03:24 PM
nameisbauer's Avatar
Send a message via AIM to nameisbauer
+1, more hardener next time.
Jim
911 Mint Green "RSC" #mintgrun
911 Gentlemen's Rallye 85 Carrera GP White
2012 C63 AMG Mars Red
Old 11-29-2007, 03:34 PM
haycait911's Avatar
make sure you get it ALL out, then wipe with lacquer thinner and sand. could use two component icing or glaze but if you already have bondo, use it. mix ratio is one inch bead of hardener for a golf ball of bondo.
Old 11-29-2007, 04:02 PM
3.2 CAB's Avatar
What brand/type of filler are you actually using? Does it have the red, blue, green, or clear catalyst? All that was applied should be removed and surface re-prepped before re-applying anymore filler to the damaged area. If you follow the directions on the can/package, you should get a good mix to use. But now, you need to start over and totally re-prep the places that you are trying to fill. Good luck!
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 11-30-2007, 10:39 AM
I assume you are not going to paint it yourself either? In that case have the person doing the paint do the filling if its simple divots and pins. Don't bother with mixing anymore. Bondo isn't really a professional filler anyway, just take the piece to someone and then pick it up later.
Old 11-30-2007, 10:42 AM
Kraftwerk's Avatar
I am using "Evercoat light weight" Yes, the mix is very easy to work with once you get a feel for the
proportions and set time etc. Thanks for the advice above. Removing the bad 1st mix was a
"dogs breakfast"
My friend is a pro who will spray it and we will build out the edges a bit in f/g so it will actually fit like the stock lid. This lid must have been from an older twisted car because the lid is a more of a rhombus rather than a trapazoid....
Bondo is not what the pro's use "Bondo isn't really a professional filler " I have heard that on another site. Why does everyone use it then? Or do they just say "Bondo" Like "band-aid" and " xerox"?
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 11-30-2007, 11:22 AM
911quest's Avatar
Bondo has become a generic name used for all fillers even thou it is a name of a type of filler. But I think they make different fillers to use on fiberglass specifically.
Tony Proasi
1969S
1957 VW Pickup
Old 11-30-2007, 12:40 PM
Sorry I should elaborate. People do use bondo. My beautiful 66 has a tiny skim coat covering a 7 sq/in area of actual parts store bondo. This is not something I am proud of but it is true, I was doing a tiny fix and the hood had to go to paint. There are higher performance fillers out there that adhere better, sand smoother, and work better overall. Think of it like this, Bondo is a Miller Genuine Draft and the other ones are more like Heinekin. They are both beers but Bondo is made for the masses, perhaps a guy with a Nissan could just fill in a small spot with it or so but you would use something a little more durable and higher in quality for a Porsche. No problem using it but just letting you know there is better stuff out there. Go to a Mattos store and you can pickup the better stuff if you please.
Old 11-30-2007, 02:20 PM
