Monkey Butt Forespin
84_Carrera's Avatar
Ignition Switch Replacement (Pretty Sure Anyway...)
So I have had the '84 Cab for 3 years / 31k miles now. From day one the ignition switch (mechanical and electrical) have been occasionally flukey - key doesn't want to turn sometimes, electrical part will occasionally not trip but on 2nd / 3rd attempt always does, etc.
So the other night I'm parked at work & it took about 5 minutes of turning the key to get the electrical side to work & start the car. I am fairly broke right now, especially with the holidays, etc. I am also in the process of selling my 2nd car before the snows hit, trying to pick up a $500 beater prior to snows falling, but we'll see - I may need to COUNT on the 911 for a month or so.
ASSUMING it's the electrical side of the ignition switch that's finally given up the ghost, do I...
1) Replace the electrical only;
2) Replace both at one time while it's got to come apart anyway;
3) Go used to save some coin;
4) Find the wires I need on the electrical side & splice in a simple toggle switch under the dash until spring
Ideally, I'd like to replace the entire setup, have re-keyed, etc. - This would definitely be a credit card situation.
I need to know the step-by-step on this too. Does the electrical side require the disassembly & removal of the entire mechanical side (like, new shear-bolts)?
Do I bother with re-keying or just add one to the keyring?
I have manual (rotary) locks, no (factory) alarm in the door.
If option #4 will suffice until I can do it right, can someone outline the wires I need?
I haven't checked the Bentley or 101 I have (also have the Up-Fixin series but haven't opened them up yet). If the process is well documented in one of those, please let me know. If I need to order the parts from Wayne, please let me know ASAP so I can get this in-hand quickly.
Thanks very much to all!
Fred Hurder Jr
For Tech Questions:
'84 911 Carrera Cabriolet (US)
Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler
22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks
ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars
Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans
Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Old 11-30-2007, 05:26 AM
Danny_Ocean's Avatar
If on a budget, I'd go with "4". Then, after you have the coin, you can do the entire job the right way as opposed to the "cheap" way.
Old 11-30-2007, 05:40 AM
Temporary Ignition Switch........
Fred,
I've seen used ignition switches (electrical side) for sale at this board for $30 or less. New ignition switch from local auto stores (Pep Boys) costs between $8-$10. It's difficult and tedious to disconnect the electrical part under dashboard. Once it's disconnected, the next steps are simple. So whether you go for replacement or not, you still have to dismount the electrical tumbler under the dashboard. I can provide you wiring diagram for temporary ignition switch.
Speaking of broke and cheapo, look at the ignition switch with screw driver on it(very left side of pic). The front brace with holes was a old 'No Parking' traffic sign post.
Tony
Old 11-30-2007, 06:45 AM
84_Carrera's Avatar
So Tony,
The factory-style Ign. Switch CAN be replaced in-car, under the dash? I'd searched prior to posting & saw some posts that indicated yes and some were no.
Wouldn't mind that electrical schematic / info. fhurderjr@cox.net will work. What kind of amperage draw are we talking about through that segment... ie, an aircraft-style switch w/ safety cover for... 15A? 30A? 40A? I have an NIB nitrous arming switch w/ cover kicking around the toolbox from days gone by, but I doubt it's rated for more than 15A. If I have to buy a replacement switch like that, a 40A for example will cost me more than half the electrical side factory switch, etc.
Thanks again all. Much appreciated!
Fred Hurder Jr
For Tech Questions:
Old 11-30-2007, 07:12 AM
There's been a number of threads about this recently. Must be the time of year...
I just went through this exact hell.
For the lock portion, soak the heck out of it with something that doesn't go sticky and contains solvent, and work the pins with the key in every possible direction for a good few minutes, repeat until bored. Do it again until the lock doesn't stick, feel "clicky" or "crunchy" or require excessive pressure to start turning. The solvent needs to wash out the old grease and gunge that's gumming up the pins and making them stick, and you need to free the pins.
I like silicon lube for this, and the biggest mistake I made was being half-hearted with it the first few times. Once I eventually hit the spot, the lock was great - and I haven't had to do it again for over a year... In fact, all my locks now work wonderfully...
If the idiot lights don't come on and the fuel pumps, CDI etc. don't run when you turn it to "Start", then that's definately the electrical portion of the switch, and it should be replaced.
You can test this easily by borrowing a switch, popping the harness off the old switch, connecting it in place and turning it with a screwdriver. Don't drive the car without unlocking the steering lock....
If everything looks "right" except that turning to "Start" does nothing, it could be more complicated. Ho ho ho.
I had that exact problem and thought replacing the switch had sorted my problem - until it returned as a "mostly-solid" problem 6 weeks later. And this time, using other ignition switches made no difference.
Replaced ground straps, re-made the solenoid connection etc - and that didn't get it either. Sometimes got a "click" from the solenoid, sometimes not. Oh, new lightweight starter 3,000 miles earlier. Fairly sure it wasn't that.
Eventually cleaned and spread the contacts on the 14-pin connector in the engine bay and the bulkhead plug where the ignition harness plugs in, and I haven't had a problem since. Which basically meant we touched, cleaned or replaced about every part, except the factory wiring harnesses.
On the up side, I think my battery gets a better charge now, though
You can replace simply the electrical portion of the switch, but it's a bear because of the limited access, and you'll never get the top screw out without the right tool. This is the only tool I own that will get anywhere close to the top screw, I bought it from Rat Shack years ago:
Once the ignition harness is removed from the back of the switch, this will fit between the switch barrel and underside of the dash and get on the top screw. Just.
After loosening it with the rachet (edit: and you only have room to turn the wheel), you can wind the screw out with just the screwdriver bit between thumb and forefinger, which is easier/quicker than lining the whole tool up everytime it slips off - which it will. Expect this little exercise to take about an hour - for the top screw alone - if you've not done it before..
If I'd had an electric drill, pretty sure I'd have drilled out the shear bolts - it would have been way faster and less frustrating to remove the entire lock.
Good luck!
Edit: One thing - the later (PET lists them as 84 up) 964 ignition switches force you to switch to "Off", and turn through to "Start" again, whereas the 911 part # switches you can go from "Run" to "Start", back to "Run" and then to "Start" again as many times as you like. The 911 switches are twice the price, though
'77 S with '78 930 power and a few other things.
Old 11-30-2007, 07:29 AM
84_Carrera's Avatar
Yes, I get lights & key buzzer fine, no solenoid click or anything, just flat over to start & no-go.
Of course, this is the weekend that buddy #1 is coming over to have me help him replace his throttle position sensor in his SVT Contour (dude, it's onoly 2 screws...), and co-worker #2 who's just discovered his rear brakes are gone in his Audi TT is swinging down too. So much for time on my own car. At least they bring beer.
Thanks guys, the more info I have the better.
Fred Hurder Jr
For Tech Questions:
Old 11-30-2007, 07:37 AM
A More Logical Course Of Action........
Fred,
If I were you, I would do option #1. The time and effort you'll spend in making a temporary fix is not worth it. As you said, it will cost you half the cost of an OEM (used) part. The final decision is yours but take the logical course of action instead of thinking how to SAVE. Just my two-cents.
Tony
Old 11-30-2007, 07:55 AM
Two yellow wires out of the back of the switch harness. The fatter of the two should have 12V on it when you turn the switch to "Start".
If it doesn't, replace the switch.
If it does, you get to check the 12V makes it to the solenoid connector and play all the games with ground straps, plugs/connectors etc. until it finally works.
Oh, and just getting 12V to the solenoid doesn't mean it's getting enough current there to actually activate the solenoid. Mine would sometimes click and sometimes not. It was probably always getting 12V to the solenoid, only sometimes would it have enough current to make it click...
It's almost impossible to fix when it's an intermittant problem - it happened to me twice in 8,000 miles, both at inconvenient times/places.
Wasn't until the car was 100% not starting that you could troubleshoot and fix it. Even flat-bedded the car to my wrench after it failed to start for 3 days straight - it worked perfectly (1 failure to crank out of 50, so at least they knew I wasn't making it up) the instant it rolled off the truck, and 100% failed the next day on my driveway, whereupon I had to fix it.
I was pretty sure that there was nothing suspect under the car, as he'd replaced out the ground strap and re-made the solenoid connection.
So I dug out the Fluke, pulled the 14 pin connection, and tested. Didn't see 12V on the yellow. Pulled the ignition harness, plugged in another, with a spare switch. Started. Tried the switch in the original harness. Started. Tried the original switch with original harness. Started.
Cleaned and spread the connectors in the engine bay and the ignition harness, no issues since.
Old 11-30-2007, 08:08 AM
3.2 CAB's Avatar
I had a problem with my ignition switch/lock once before, after I turned it off in front of a liquor store. When I got back in to leave, I could not turn the key, just like they do after a first try to start then having to go back to the OFF position before you can try it again. I would just not turn at all, just like the interlock acts after the first attempt. I guess something in the key safety interlock was either broken or stuck. This was before I carried a can of spray cleaner and spray type lube at all times in the trunk. There were no other type of stores in the area. I had already checked with the person at the store, that I knew quite well, and they didn't have anything like WD40 there. I had already screwed around with it for about 15 minutes when a lady pulled up to the liquor store, and had her mother and her two little boys in the car also. I noticed the boys playing with some squirt guns in the car, but they didn't have anything in them to actually squirt each other, but I got an idea, and I went in the store to ask the lady about here kids squirt guns. I wanted to buy one of them. I told her of my problem and she said that they had just been to a store to pick up party favors for her twins birthday party, and that she had bought a package of the small water squirt guns to give out to her boys friends at the party. I asked her if I could buy one of them from her, she said NO, she would give me one of them. She gave me a little red squirt gun. When the clerk at the store finished ringing up the ladies purchase, I told the clerk that I would be paying for her items, wasn't very much, about $10.00. She gave me the little red squirt gun, and I bought a bottle of EVERCLEAR. I filled up the squirt gun with it and used a large paper clip to hold the little door on the lock cyl. opened, and I held some paper towels all around the ignition switch cyl. and I began to spray the everclear into the keyhole. I was amazed at how much crap it flushed out. I would squirt a little, the try the key. I repeated this process 5 or 6 times. I finally got it where the run off was just about clean, and I kept wiggling the key and trying to turn. It got free again, and the lockout had reset itself, then the key worked like it should and I got it started. The first place I went to was a parts house and bought some spray cleaner and spray lube, to repeat the process of cleaning, then lubing the lock cylinder. Since that day, I have not had any issues like that again. It has now been about 5yrs and all is well. If you find that it is the ignition lock cylinder at fault, try to clean it out as mentioned before and lube it. Hopefully it is just some crap in the lock cylinder part that you can get cleaned out, and don't have to go through the PITA and expense of changing out the parts. Good luck, Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 11-30-2007, 08:38 AM
I don't think anything short of replacing the electrical side of the switch will do because the contacts are going out, and when they do all sorts of things on the 911 will go screwy, including the ignition, fuel system, windows, radio, headlights, etc.
I'd look into a used electrical switch if funds are low. Ideally you want to get a new one because the job is a big pain in the butt. Some tips, learned the hard way:
(1) take out the drivers seat, and work with a good light facing up at the underside of the dash;
(2) carefully move all of the wires out of the way, and don't try to remove the hazzard switch. Those ears are brittle and will break;
(3) to remove the 2 shear off bolts, you can use either a bolt extractor (I recommend Craftsman), or you may use an air chisel, and hit the bolts at an angle to get them started. Then you can simply unscrew them with a pair of pliers;
(4) have a pair of replacement allen, cap, or shear bolts ready to reinstall the ignition switch;
(5) the little allen bolt that secures the steering wheel lock to the steering column is hard to reach. I used a little allen key that came with some Bombay furniture. It worked, and I was able to tighten it the rest of the way with a regular allen wrench. Don't leave out re-tightening this little bolt though, or your steering wheel lock may bind;
(6) the mechanical portion (key side) of the switch is very difficult to disassemble. I know some guys on this board have done it, but I took one look at it and decided it was too much work. I'd like to have replaced the little tumbler blades.
Good luck. I don't think you can use a simple toggle switch. The other electrics will stay off, and your car won't run. Even if you could, you'd want to buy a generic keyed switch anyway.
Old 11-30-2007, 01:09 PM
84_Carrera's Avatar
I found a new one on FleaBay for $42 shipped (electrical side only). Not OE, but budget-friendly.
I cleaned the lock fairly well tonight, using Berryman's B-12 followed by some spray silicone, on the key only, and worked it until the key kept coming out clean.
I was able to start the car maybe 1 in 25-50 rotations. The lights / everything else work fine when the key's turned over to run position.
Fred Hurder Jr
For Tech Questions:
Old 11-30-2007, 02:57 PM
peritus's Avatar
follow the KISS model, Fred.
this happened to me - I was just about to drop several hundred on a new ignition, but when I crawled under the dash to look, I noticed that the screw was loose - it's tiny, and holds the back of the ignition to the inside of the dash. Half a turn with a screw driver, and it's worked perfectly ever since.
James
91 Black on Balck 964 C4 (DD)
82 Metallic Red SC 3.6 Varioram (sold)
Old 12-01-2007, 07:18 AM
84_Carrera's Avatar
Well, I'll be diving underneath tonight / tomorrow anyway - I started the car up nice & quickly this morning, no problem. Drove down the street to bring the Mrs. a cup of coffee before she went off to work, and the car wouldn't turn over at the coffeehaus. Whoops.
What a PITA to pop-start this car also - I never had to push the car so fast on my Taurii...
Got her home, and after doing the brakes on the co-worker's Audi TT & the buggered throttle position sensor on the buddy's SVT Contour, I needed to push the 911 into the bay... still no-fire.
So, I'll pull the front seat in prep, fiddle with the elec-side until the replacement comes in & get back to you guys next week after replacement.
Fred Hurder Jr
For Tech Questions:
Old 12-01-2007, 12:31 PM
Metal Guru
911nut's Avatar
+1 on cleaning the lock. I flushed mine and it improved the function 100%.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 12-01-2007, 02:00 PM
84_Carrera's Avatar
Update:
Yep, plan on at least an hour if you're trying to get to the top screw, removing the electrical side from under the dash.
Also mark the connectors on the firewall for when you remove them. I removed (3) connectors from the firewall, plus the pigtail next to the main switch connector, and the switch connector itself.
I used a small philips bit, with a 6.5mm short socket, and a 1/4" drive ratchet to remove the top screw.
I also cut a 15 1/2" x 17 1/2" piece of 5/8" plywood, with (4) drywall screws in it to set on top of the seat rail mounts. The screws hold the ply in place while you're squirming around, protecting the DME unit, etc., after removing the driver's seat.
I have the electrical part of the ignition switch out now, waiting for the new one to come in.
Fred Hurder Jr
For Tech Questions:
Old 12-02-2007, 10:49 AM
Walt Fricke's Avatar
If it is the starter positon that is getting funky, and hosing down the key lock part doesn't help, and you find the electrical part is firmly screwed on, you might consider adding a push button starter control. You can purchase nice high capacity ones pretty easily (I spotted one in my local high end hardware store, and bought it) that have a black rubber cap over them. Mount it in the dash up toward the top between the left two gauges and you'll hardly notice it is there. You will still have your ignition switch to deter casual thievery, but when the key won't go all the way to the start position, or doesn't do anything when it gets there, push the button.
Not hard to set up. Just look at the wiring schematic and figure out suitable places to connect your push button switch in parallel with the wiring that goes from batter through starter switch to the starter.
That said, it is not all that hard to replace the electrical portion of things (though the top screw is tough to get at. And the "must return to off before turning all the way to start again" mechanism is inside the electrical portion, not the key portion, of things. The switches are not all that robust, however. The weak plastic part is connected to the thin pot metal part by some crimping. The wiring plug is tough to pry off of the electrical part, so there is a tendency to break the electrical part when doing so. Is a good idea to have a new electrical switch unit handy before starting down this road.
Old 12-02-2007, 08:34 PM
notmytarga's Avatar
In my 1975 the "must turn to off before you can go to start" is in the Mechanical portion NOT the electrical portion. I took the whole thing apart last May and wrote it up, with pictures - no one cared - see what you think:
Ignition switch disassembly writeup
rekeying the tumbler as I went. No cash spent except for some TriFlow - an excellent lock lubricant. Working well to date.
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016
<ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07
Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted.
2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon
Old 12-02-2007, 09:17 PM
Interesting, I missed your post - looks great, very thorough. When I thought I was going to re-key my replacement lock set, I was gonna use a VW guide I found on the web.
I have what I thought was an early lock assembly (bought a set, the glove box and trunk key covers have a chromed cover, my '77 doesn't have a lock on the trunk and the glove box one is black), and that has absolutely no lockout on the mechanical portion of the ignition lock whatsoever - moves completely freely from one end of the range to the other.
And I know the detent and lockout stuff happens with the later electrical portion, because the one I borrowed and was testing with a screwdriver did it
Old 12-03-2007, 12:39 PM
Like Spuggy, when our '84 wouldn't start (wife called from a parking lot, able to come to rescue and push start in the few feet available), I replaced the electrical part. It had a start block-out function, because I turned the piece with a screw driver before installing it. Then I pulled the failed one apart. Don't think I still have the pieces, but could see what had broken, and that there was a cam action lockout system in there.
I've replaced the electrical part on my '77 a couple of times (due to the part breaking when removing the wiring plug), and they worked that way also. A quick look suggests that the electrical switch part was the same from '74 through '84.
But Notmytarga's post is great. Maybe this feature is found in both places? Or got moved later, but an updated switch worked redundantly? Still, he has removed my fear of messing with the mechanical part. I rekeyed when I replaced door handles, so that part causes only minor trepidation. Pulling the whole assembly out, however, is not something I plan to do any time soon unless I can't get the key to give me the run position.
Walt Fricke
Old 12-03-2007, 02:49 PM
Pelican even list the 964 part for 74-89, whereas PET lists it from 84 up, and a 911 part for the period you quite. Both parts seem to be identical from a size/fitment perspective, and, if there's an electrical difference, it doesn't cause any problems on the '77...
My wrench said he'd replaced 911 ignition switches Back In The Day that had come fitted from the factory with a 928 part #. I just looked, and sure enough, Pelican lists the same 964 ignition switch for the 928 and the 944 as well.
The test switch I borrowed was from an '84 930 that was being re-keyed, and it had the Start lockout - just like the switch that was fitted to the '77 when I got it.
The switch from what I believe is an earlier lock has no Start lockout. I think this is the 911 part - which is available from the Porsche dealer for twice the price of the 964 part... No biggie, but I really prefer no Start lockout. Period-correct - and no, I'm not one of the toothbrush brigade..
I bought the lock set because I believed that the mechanical portion of the ignition lock would fit too. Certainly looks very similar. I forget what the Ebay description said it was from - may have been a '74 - but I looked the part up and it seemed to be right...
Old 12-03-2007, 03:48 PM
