Mike the mechanic
Guest
Posts: n/a
Question injector part #
Can anyone tell me the Bosch injector part # for 3.2 Carreras? >
Mike
86 Carrera t
[This message has been edited by Mike the mechanic (edited 03-05-2001).]
Old 03-05-2001, 03:19 PM
Mike the mechanic
Guest
Posts: n/a
Question
(Edit won't work)
Can anyone tell me the Bosch part # for the injectors found on 3.2 Carreras? >
Mike
86 Carrera t
Old 03-05-2001, 03:23 PM
KTL
Guest
Posts: n/a
Post
Porsche #930.606.120.00
Injector # 0 280 150 158 and there is a 060 number above the 10 digit number which is closer to the fuel supply side of the injector.
They're not cheap! Around $80 new and $55 rebuilt (plus core charge sometimes). Maybe you can avoid the Porsche cost if you can locate the injector elsewhere with the Bosch number?
Kevin
87 Carrera
[This message has been edited by KTL (edited 03-05-2001).]
Old 03-05-2001, 06:47 PM
Mike the mechanic
Guest
Posts: n/a
Post
Thanks KTL, thay's just what I needed. Actually, I needed the number as a reference, because I want to upgrade to larger injectors.
Thanks again.
Mike
86 Carrera t
Old 03-06-2001, 03:50 PM
