Guest
Posts: n/a
Can anyone tell me the Bosch injector part # for 3.2 Carreras? >
![]() Thanks Mike 86 Carrera t [This message has been edited by Mike the mechanic (edited 03-05-2001).] |
Guest
Posts: n/a
(Edit won't work)
Can anyone tell me the Bosch part # for the injectors found on 3.2 Carreras? > ![]() Thanks Mike 86 Carrera t |
Guest
Posts: n/a
Porsche #930.606.120.00
Injector # 0 280 150 158 and there is a 060 number above the 10 digit number which is closer to the fuel supply side of the injector. They're not cheap! Around $80 new and $55 rebuilt (plus core charge sometimes). Maybe you can avoid the Porsche cost if you can locate the injector elsewhere with the Bosch number? ------------------ Kevin 87 Carrera [This message has been edited by KTL (edited 03-05-2001).] |
Guest
Posts: n/a
Thanks KTL, thay's just what I needed. Actually, I needed the number as a reference, because I want to upgrade to larger injectors.
Thanks again. Mike 86 Carrera t |
