What's this glue stuff behind my engine oil cooler?
Any ideas?
1979 911 SC Silver 2002 996 race car 2005 Ford Excursion |
Maybe it's Aviation Permatex that was ceremonially misplaced...
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
those are potential leak areas. there's a steel tube case into the case and sometimes there is seepage there. someone was prudent in applying epoxy there.
UFLYICU
JB weld to reinforce potential leak areas where the underlying casting may be thin. Wayne's rebuild book shows similar areas on the engine case and chain housings where it is used.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Martin,
There is a cast-in-place pipe there that is part of the oil system. For whatever reason (casting I suppose) some of the pipe was intentionally left exposed. Porsche covered the exposed parts with epoxy. Virtually every 911 is like that. BTW, Thanks again for your hospitality the last time I was there. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Thanks guys. Just thought I'd better make sure that was OK. Hope you are all around when I get into my 915 next week!
