freefly
Guest
Posts: n/a
Post What to send with a 3.2 engine if it's going into an SC??
I almost forgot,
The guy who is buying my 3.2L is putting it into an `83 SC. So far, I am sending him the engine, (with flywheel and exhaust), brain, wiring harness, fuel pump relay, fuel pump, and tach. He has purchased a Mocal fender oil cooler that I assume will work. Will he need anything else from me to help the install? I will be sending wiring diagrams and little knik-knack parts like grommets,clamps, mount bolts, etc. as well. Any other ideas (things I am forgetting) would be great!
-EJ
Old 03-08-2001, 12:32 PM
cary
Guest
Posts: n/a
I'm by no means an expert. But my 77 Carrera 3.0 has a 3.2 in it. There is a TDC and a RPM sensor in the gearbox also. The harness was hooked to them. I think they have to go also. Hopefully some one with some expertise will help out. Good Luck
Cary Kutter
77 Euro Carrera w/3.2
Rennlist Member
PCA Region - Big Sky
Old 03-08-2001, 03:13 PM
john walker's workshop
Guest
Posts: n/a
Post
how about the coil? send him a template of the cutout on the bellhousing for the sensors too.
Old 03-08-2001, 06:56 PM
