Guest
Posts: n/a
I almost forgot,
The guy who is buying my 3.2L is putting it into an `83 SC. So far, I am sending him the engine, (with flywheel and exhaust), brain, wiring harness, fuel pump relay, fuel pump, and tach. He has purchased a Mocal fender oil cooler that I assume will work. Will he need anything else from me to help the install? I will be sending wiring diagrams and little knik-knack parts like grommets,clamps, mount bolts, etc. as well. Any other ideas (things I am forgetting) would be great! -EJ |
Guest
Posts: n/a
I'm by no means an expert. But my 77 Carrera 3.0 has a 3.2 in it. There is a TDC and a RPM sensor in the gearbox also. The harness was hooked to them. I think they have to go also. Hopefully some one with some expertise will help out. Good Luck
------------------ Cary Kutter 77 Euro Carrera w/3.2 Rennlist Member PCA Region - Big Sky |
Guest
Posts: n/a
how about the coil? send him a template of the cutout on the bellhousing for the sensors too.
