VIPRKLR
Guest
Posts: n/a
Question one window is faster than the other
The electric windows in a friends 81 SC are acting strange. The drivers side works fine, but the passenger is a bit slow. Could this be the motor going out, or do you think a clean and lube of the window regulator would work? There are no odd sounds, and while slow, the glass goes down smoothly.
He is heading out of town for a couple of days and we want to check this out n case he runs into foul weather.
Old 03-07-2001, 06:37 AM
retnug
Guest
Posts: n/a
Post
I had the same problem. Clean and lube the mechanism and also make sure all the electrical connections are clean and tight. Doing that definitell helped my window move faster.
Gunter
'82 SC Targa
Old 03-07-2001, 07:08 AM
Nickshu
Guest
Posts: n/a
Clean and lube worked on mine.
Nick.
_ ______ _
Nick Shumaker
1982 911SC Coupe
Old 03-07-2001, 07:42 AM
JDaniel
Guest
Posts: n/a
A clean and lube of the regulator may help. You can also try to spray some silicon(sp) onto the felt channels. I did this for quite a while, but eventually the window stoppped going up/down.
I decided to remove the window motor, bench test it with an A/C source (it still worked) and then replace it. Window worked fine (but slow) for 2 days, then it stopped. I removed, tested and replaced again. Window worked for 1 day. I finally bit the bullet and bought a new motor ($135+/-).
Now the passenger side goes up/down as smooth as silk, and just as fast as the drivers side.
If you've ever r&r'd a window motor, you'll unnderstand why I bought a new one after 2 attempts at fixing... a real wrist turning PITA!
Dan Tolley
1987 911 coupe
Old 03-07-2001, 07:59 AM
JackOlsen
Guest
Posts: n/a
Post
Mine were like watching turtles race when I got them. Very, very slow. I put grease wherever I could get my hand in, and blew graphite-based lube in the channels. Now the 28-year-old motors work as good as new.
Jack Olsen
1973 911 T (3.6) sunroof coupe
jackolsen@mediaone.net
Old 03-07-2001, 12:22 PM
john walker's workshop
Guest
Posts: n/a
Post
the fuzz wears off the felt channel and the glass drags on the rubber. lube of any sort just makes the problem worse. fresh felts work wonders. of course the mechanism may be dry, or the motor may be tired, but try the felt 1st. it's easiest and usually the problem.
Old 03-08-2001, 07:13 PM
JackOlsen
Guest
Posts: n/a
Post
Can you replace the felt without removing the window frame?
Jack Olsen
Old 03-08-2001, 08:07 PM
82SC
Guest
Posts: n/a
Post
hey jack
what kind of grease did you use for the motor. Mine gets worse in the rain. during dry days it is slow, but rainy weather it is frozen...
Old 03-08-2001, 11:12 PM
Guest
Posts: n/a
Post
73 and earlier 911s had metal backed felt channels that were glued in, requiring removal of the frame and lots of chiseling and pulling to get it out. later ones had a slip in channel that you could pull out. use a wet style silicone spray down the window frame and on the rubber only on the length that goes into the door. slip in as far as possible, roll up glass 3", stick a screwdriver blade @ 45 degree angle firmly into the channel with the shaft resting on the corner of the glass, roll down window, the channel will follow, repeat until top corner lines up w/frame. glue top 6" of channel so it doesn't slip down. piece of cake!
Old 03-09-2001, 09:21 AM
Senior Member
Superman's Avatar
Apparently I watched him do a later model. It was cake.
Mocha 1978 911SC. "Coco"
Old 11-03-2004, 08:35 AM
Designer King
Paulporsche's Avatar
JW and/or Super,
Is this done w/ the interior door panel on or off?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 11-03-2004, 09:09 AM
although I've never done it.. Warren once suggested that the motor get relays.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-03-2004, 09:13 AM
Designer King
OK, I just read Harlequin's thread also curent on this BB. Apparently this can be done w/ the door panel & window frame in place.
Paul
Old 11-03-2004, 09:14 AM
Designer King
Now I see tobluforu has joined that thread and says the panel must be removed.
Paul
Old 11-03-2004, 09:28 AM
